Avoid Proxy page for Print Task, Print Template; Geometry Service
4567
13
11-09-2016 02:24 PM
PitersonPaulgek
Hi there,
Is it possible to avoid using proxy page when
1) create pdf file with Print Task, Print Template?
2) use Geometry Service for Buffer
Any help would be appreciated.
esriConfig.defaults.geometryService = new GeometryService("some URL");
esriConfig.defaults.io.proxyUrl = "/proxy/"; - HERE WE MUST PUT CORRECT ADDRESS
esriConfig.defaults.io.alwaysUseProxy = false;
RobertScheitlin__GISP
Pieterson,
  Any particular reason why? You do not have to use a proxy when using the PrintTask but the use the proxy will be necessary when buffering a complex polygon as the text limit for url params will likely be exceeded and the use of a put request will need to be made.
PitersonPaulgek
Thanks for reply, Robert.
How I configure PrintTask not to use proxy?
We have an error
init.js:140 GET http://localhost:55549/proxy/?https://user.domain.com/arcgis/rest/services/DownloadWebMap/GPServer/E... 404 (Not Found)
when run the JavaScript
app.printUrl = "some URL";
var printInfo = esriRequest({
 "url": app.printUrl,
 "content": { "f": "json" }
printInfo.then(handlePrintInfo, handleError);
function handlePrintInfo(resp) {
var layoutTemplate, templateNames, mapOnlyIndex, templates;
layoutTemplate = arrayUtils.filter(resp.parameters, function (param, idx) {
return param.name === "Template123";
if (layoutTemplate.length === 0) {
console.log("print service parameters name for templates must be \"Template123\"");
return;
templateNames = layoutTemplate[0].choiceList;
// remove the MAP_ONLY template then add it to the end of the list of templates
mapOnlyIndex = arrayUtils.indexOf(templateNames, "MAP_ONLY");
if (mapOnlyIndex > -1) {
var mapOnly = templateNames.splice(mapOnlyIndex, mapOnlyIndex + 1)[0];
templateNames.push(mapOnly);
// create a print template for each choice
templates = arrayUtils.map(templateNames, function (ch) {
var plate = new PrintTemplate();
plate.layout = plate.label = ch;
plate.format = "PDF";
plate.layoutOptions = {
"authorText": "Made by: ZZZ",
"copyrightText": "<copyright info here>",
"legendLayers": [],
"titleText": "<Test Title Here>",
"scalebarUnit": "Miles"
return plate;
// create the print dijit
app.printer = new Print({
"map": app.map,
"templates": templates,
url: app.printUrl
}, dom.byId("print_button"));
app.printer.startup();
function handleError(err) {
console.log("Something broke: ", err);
Piterson,
   It sounds like you just need to configure your proxy url properly or just comment out those lines
The proxy should only be used when the text limit for the url params has been exceeded or you have that specific url setup in your proxy.config.
PitersonPaulgek
Robert,
I commented out
and now have an error
esri.config.defaults.io.proxyUrl is not set. If making a request to a CORS enabled server, please push the domain into esri.config.defaults.io.corsEnabledServers.
EsriVisualisation.js:576 Something broke: Error: esri.config.defaults.io.proxyUrl is not set. If making a request to a CORS enabled server, please push the domain into esri.config.defaults.io.corsEnabledServers.
at Object.c.getProxyUrl (https://js.arcgis.com/3.17/init.js:701:63)
at u (https://js.arcgis.com/3.17/init.js:859:368)
at e (https://js.arcgis.com/3.17/init.js:864:490)
at z (https://js.arcgis.com/3.17/init.js:871:60)
at initialiseMap (http://localhost:55549/Scripts/EsriVisualisation.js:526:25)
at initApp (http://localhost:55549/Scripts/EsriVisualisation.js:195:9)
at http://localhost:55549/Scripts/EsriVisualisation.js:186:5
at ia (https://js.arcgis.com/3.17/init.js:28:3)
at https://js.arcgis.com/3.17/init.js:28:256
at ja (https://js.arcgis.com/3.17/init.js:28:125)
Piterson,
   So as the error message is saying you are attempting to connect to a server that is not the one the app is running on so you need to have the server you are contacting be CORS enabled and add that server to the esri.config.defaults.io.corsEnabledServers or you need to get your proxy configured properly to by-pass the need for CORS.
PitersonPaulgek
Robert,
Thank you. Could you provide more details how to
1) check "server you are contacting be CORS enabled"
2) and add that server to the esri.config.defaults.io.corsEnabledServers.
It is 10 times easier to setup the proxy then to enable CORS on your server.
PitersonPaulgek
Should I
esri.config.defaults.io.corsEnabledServers.push("?????server.com");
if yes, what I do for local environment?
esri.config.defaults.io.corsEnabledServers.push("localhost:55549");
Piterson,
   Normally you would not have to add the machine that is running the app to the corsEnabledServers. It is the other servers (any other url you are using in your code). Is your web server the same machine as your ArcGIS Server?
