Union geometry service
2011
5
11-08-2016 02:48 PM
by Anonymous User
Not applicable
Hi all,
I am trying to make the geometry service work but I am unsuccessful. Any idea why?
Here is my code
 var map;
        require([
          "esri/InfoTemplate",
          "esri/map",
          "esri/layers/FeatureLayer",
          "esri/symbols/SimpleFillSymbol",
          "esri/symbols/SimpleLineSymbol",
          "esri/tasks/query",
          "esri/toolbars/draw",
          "esri/tasks/GeometryService",
          "esri/dijit/editing/Union",
          "dojo/dom",
          "dojo/on",
          "dojo/parser",
          "dojo/_base/array",
          "esri/Color",
          "dijit/form/Button",
          "dojo/domReady!"
          function (
            InfoTemplate, Map, FeatureLayer, SimpleFillSymbol, SimpleLineSymbol,
            Query, Draw, GeometryService, Union, dom, on, parser, arrayUtil, Color
              parser.parse();
              var geometryService = new GeometryService("https://utility.arcgisonline.com/ArcGIS/rest/services/Geometry/GeometryServer");
              var selectionToolbar, featureLayer;
              map = new Map("map", {
                  basemap: "streets",
                  center: [-97.395, 37.537],
                  zoom: 11
              map.on("load", initSelectToolbar);
              var fieldsSelectionSymbol =
                new SimpleFillSymbol(SimpleFillSymbol.STYLE_SOLID,
                  new SimpleLineSymbol(SimpleLineSymbol.STYLE_DASHDOT,
                new Color([255, 0, 0]), 2), new Color([255, 255, 0, 0.5]));
              featureLayer = new FeatureLayer("https://sampleserver3.arcgisonline.com/ArcGIS/rest/services/Petroleum/KSPetro/MapServer/1",
                    mode: FeatureLayer.MODE_SNAPSHOT
              featureLayer.setSelectionSymbol(fieldsSelectionSymbol);
              map.addLayer(featureLayer);
              $("#selectFieldsButton").click(function () {
                  selectionToolbar.activate(Draw.EXTENT);
              $("#clearSelectionButton").click(function () {
                  featureLayer.clearSelection();
              function initSelectToolbar(event) {
                  selectionToolbar = new Draw(event.map);
                  var selectQuery = new Query();
                  on(selectionToolbar, "DrawEnd", function (geometry) {
                      selectQuery.geometry = geometry;
                      featureLayer.selectFeatures(selectQuery,
                        FeatureLayer.SELECTION_NEW);
                  on(featureLayer, "onSelectionComplete", function (features) {
                      if (features.length === 1) {
                          var targetGeometry = features[0].geometry;
                          geometryService.union(targetGeometry);
                  on(geometryService, "union-complete", function (uniongeometries) {
                      var targetGraphic = featureLayer.getSelectedFeatures()[0].setGeometry(uniongeometries);
                      featureLayer.applyEdits(null, [targetGraphic], null);
RobertScheitlin__GISP
Alex,
   I think you may be confused about the GeomtryService (GS). The GS knows nothing about selected features or a feature layer in general. When you use
GS.union([this is the array of all geometries that you want combined]);
So your function may look like this:
require([
  "esri/graphicsUtils", ...
], function(graphicsUtils, ... ) {
                      if (features.length > 1) {
                          var targetGeometry = graphicsUtils.getGeometries(featureLayer.getSelectedFeatures());
Alex,
   The GeometryService.union is suppose to called on an array of geometries that you want to union. In your code you are only passing one geometry.
by Anonymous User
Not applicable
Right thank you Robert, I corrected it:
 var targetGeometry = features.geometry;
featureLayer.getSelectedFeatures().setGeometry(uniongeometries);
However I am still unsuccessful.
The selection is made and shows up but not the union.
Alex,
require([
by Anonymous User
Not applicable
Yes I am confused by the GS and the end result of OnselectionComplete. I thought the OnselectionComplete results would be enough as geometries to pass into the GS. Thanks for the help here Robert.
by Anonymous User
Not applicable
The union tool looks like a charm now . For some reasons the first draw does not accomplish the union, the second draw does the job.
Now, for any of you wondering what the full code would be:
geometryService.union(targetGeometry, function (geometry) {
var symbol = new SimpleFillSymbol("none", new SimpleLineSymbol("solid", new Color([255, 255, 255]), 2), new Color([255, 255, 255, 0.25]));
var graphic = new Graphic(geometry, symbol);
map.graphics.add(graphic);
console.log(targetGeometry);
