Feature Table Show/Hide Issue
3843
6
11-04-2016 01:59 PM
ChristopherJohnson1
I have a map on which I am loading a couple feature layers.  Additionally, I am adding 2 feature tables, each one associated with one of the feature layers.  Because the layers are scale-dependent, I am only showing one table at a time using jQuery's show() and hide() functions.
At the initial extent, only one table is shown.  When a user zooms in a couple levels, that first table disappears and the second table appears.  The show/hide function is working well, for the most part.  The issue that I am encountering is that when the second table appears, the column headers are not present in the feature table.  If I add/hide a column through the "Options" menu, then the column headers appear again.
An interesting twist...if I leave both tables visible at the initial extent and zoom in, when the second table re-appears, it shows with the column headers.
Any idea what could be causing this issue?
Thanks...Chris
RobertScheitlin__GISP
Chris,
   I have seen this before and the issue seems to be that the FeatureTable need to be created and added to the DOM to a div that is not "display: none" but visibility: hidden or just set to the outside bounds of the view display. If you share your code then I can provide more help.
ChristopherJohnson1
Thanks for the reply, Robert.  Please see the code below.
<!DOCTYPE html>
<html>
<head>
  <title>Using FeatureTable</title>
  <link rel="stylesheet" href="https://js.arcgis.com/3.16/dijit/themes/claro/claro.css">
  <link rel="stylesheet" href="https://js.arcgis.com/3.16/esri/css/esri.css">
  <script src="https://js.arcgis.com/3.16/"></script>
     <script src="https://ajax.googleapis.com/ajax/libs/jquery/3.1.1/jquery.min.js"></script>
  <style>
    html, body, #map{
      width:100%;
      height:500px;
      margin:0;
      padding:0;
#divGrid     {
     width: 100%;
     height: 200px;
     margin-bottom: 20px;
.tableheight {
     height: 300px;
  </style>
  <script>
    require([
      "esri/geometry/Extent",
       "esri/layers/ArcGISDynamicMapServiceLayer", "esri/layers/ImageParameters",
       "esri/layers/FeatureLayer",
      "esri/dijit/FeatureTable",
       "esri/renderers/SimpleRenderer",
       "esri/renderers/ClassBreaksRenderer", "esri/tasks/GenerateRendererParameters", "esri/tasks/GenerateRendererTask",
    "esri/tasks/ClassBreaksDefinition",
     "esri/tasks/AlgorithmicColorRamp",
     "esri/symbols/SimpleMarkerSymbol",
     "esri/symbols/SimpleLineSymbol",
     "esri/symbols/SimpleFillSymbol",
     "esri/Color",
      "esri/geometry/webMercatorUtils",
      "esri/map",  "esri/layers/LayerDrawingOptions",
      "dojo/dom-construct",
      "dojo/dom",
      "dojo/parser",
      "dojo/ready",
      "dojo/on",
      "dojo/_base/lang",
      "dijit/registry",
      "esri/tasks/query",
      "dijit/form/Button",
      "dijit/layout/ContentPane",
      "dijit/layout/BorderContainer",
      "dijit/form/TextBox"
    ], function (  Extent,ArcGISDynamicMapServiceLayer, ImageParameters,
      FeatureLayer, FeatureTable, SimpleRenderer, ClassBreaksRenderer, GenerateRendererParameters, GenerateRendererTask, ClassBreaksDefinition, AlgorithmicColorRamp,SimpleMarkerSymbol, SimpleLineSymbol, SimpleFillSymbol, Color, webMercatorUtils, Map,  LayerDrawingOptions,
      domConstruct, dom, parser, ready, on,lang,
      registry, Query, Button, ContentPane, BorderContainer, TextBox
      parser.parse();
      ready(function(){
     var initialExtent = new esri.geometry.Extent({
          "xmin": -14901092.916080378,
          "ymin": 2570827.677759068,
          "xmax": -7382135.317726159,
          "ymax": 7046980.0541378,
          "spatialReference": { "wkid": 102100 }
     var map, citypointFT, citypolyFT, tractpolyFT, citypointlayer, citypolygonlayer, tractpolygonlayer, fl_url;
     var fieldsoutputted, fieldsarray, renderedField = "col1", MoreDetails = "col2";
     var myFeatureLayer, renderer, DynamicMapServiceURL = "xxx";
           // define the dynamic map service layer
     var imageParameters = new ImageParameters();
     imageParameters.format = "png";
     var dynamicMapServiceLayer = new ArcGISDynamicMapServiceLayer(DynamicMapServiceURL, {
          "opacity": 1.0,
          "imageParameters": imageParameters
        map = new Map("map",{
          basemap: "gray", extent: initialExtent
          var pointSymbol = new SimpleMarkerSymbol().setStyle(SimpleMarkerSymbol.STYLE_CIRCLE).setSize(8).setOutline(new SimpleLineSymbol(SimpleLineSymbol.STYLE_SOLID, new Color([85, 85, 85]), 1)).setColor(new Color([153, 153, 153]));
          var polygonSymbol = new SimpleFillSymbol().setStyle(SimpleFillSymbol.STYLE_SOLID).setOutline(new SimpleLineSymbol(SimpleLineSymbol.STYLE_SOLID, new Color([85, 85, 85]), 1)).setColor(new Color([153, 153, 153]));
          // load the feature table and its accompanying data on map load
          map.on("load", loadTable);
           // show/hide table, based on scale
          map.on("extent-change", showHideGridAndLegend);
          // the function below displays an error message and hides the div in which the map is drawn
     function showErr(err)
          'use strict;'
          console.log("Error Details: " + err);
     function AddGrid(lyrid, gridloc)
          var existingGrid = dijit.byId(gridloc);
          if (existingGrid)
               existingGrid.destroyRecursive(true);
          if (lyrid === 4)
               tractpolyFT = new FeatureTable({
                    "featureLayer": tractpolygonlayer,
                    "map": map,
                    "showStatistics": false,
                    "zoomToSelection": false,
                    "syncSelection": true,
                    "outFields": ["PlaceName", "StateAbbr", "plc_tract2010", renderedField, MoreDetails, "PlcTrPop2010"],
                    "fieldInfos": [{
                         alias: 'City',
                         alias: 'State',
                         alias: 'Census Tract ID',
                         alias: 'Column 1',
                         alias: 'More Details',
                         alias: '2010 Census Population'
                    //"gridOptions": [{
                    //     noDataMessage: "No Data",
                    //     allowSelectAll: false,
                    //     columnHider: false,
                    //     sort: {
                    //          field: "PlaceName", ascending: true,
                    //          field: "StateAbbr", ascending: true,
                    //          field: "plc_tract2010", ascending: true
               }, gridloc);
               tractpolyFT.startup();
          } else
               if (lyrid === 0)
                    citypointFT = new FeatureTable({
                         "featureLayer": citypointlayer,
                         "map": map,
                         "outFields": ["NAME", "ST", renderedField, MoreDetails, MoreDetails2, MoreDetails3
                         "fieldInfos": [{
                              alias: 'City',
                              alias: 'State',
                              alias: 'Column 1',
                              alias: 'More Details 2',
                              alias: 'More Details 3'
                         //     name: 'POP2010',
                         //     alias: '2010 Census Population'
                         //"gridOptions": [{
                         //     sort: {
                         //          field: "NAME", ascending: true,
                         //          field: "ST", ascending: true,
                    }, gridloc);
                    citypointFT.startup();
               else
                    citypolyFT = new FeatureTable({
                         "featureLayer": citypolygonlayer,
                         "map": map,
                         "outFields": ["NAME", "ST", renderedField, MoreDetails, MoreDetails2, MoreDetails3, "POP2010"],
                         "fieldInfos": [{
                              alias: 'City',
                              alias: 'State',
                              alias: 'Column 1',
                         //"gridOptions": [{
                         //     sort: {
                    }, gridloc);
                    citypolyFT.startup();
     function showHideGridAndLegend()
          console.log(map.getScale());
          switch (true)
               case (map.getScale() >= 36978595.474472):
                    $('#citypointgrid').show();
                    $('#citypolygongrid').hide();
                    break;
               case (map.getScale() < 36978595.474472 && map.getScale() >= 6000000):
                    $('#citypointgrid').hide();
                    $('#citypolygongrid').show();
                    break;
               case (map.getScale() < 6000000 && map.getScale() > 2311162.217155):
                    break;
               case (map.getScale() <= 2311162.217155):
                    break;
               default:
                    break;
          // the functions below dynamically render the data
     // the function below applies the renderer generated by the createRenderer function above to the featureLayer and adds labels.
     function applyCPRenderer(citypointrenderer)
          'use strict;'
          citypointrenderer.defaultLabel = "Data unavailable";
          citypointrenderer.defaultSymbol = pointSymbol;
          citypointlayer.setRenderer(citypointrenderer);
          citypointlayer.renderer.setOpacityInfo(0.7);
          map.addLayer(citypointlayer);
     function applyRenderer(renderer)
          'use strict;'
          renderer.defaultSymbol = polygonSymbol;
          citypolygonlayer.setRenderer(renderer);
          citypolygonlayer.renderer.setOpacityInfo(0.7);
          map.addLayer(citypolygonlayer);
     function createRenderer(lyr,field)
          'use strict;'
          var classDef = new ClassBreaksDefinition();
          classDef.classificationField = field;
          classDef.classificationMethod = "natural-breaks";
          classDef.breakCount = 7;
          classDef.baseSymbol = lyr === 0 ? pointSymbol : polygonSymbol;
          var colorRamp = new AlgorithmicColorRamp();
          colorRamp.fromColor = new Color.fromHex("#F0F9E8");
          colorRamp.toColor = new Color.fromHex("#2b8cbe");
          colorRamp.algorithm = "hsv";
          classDef.colorRamp = colorRamp;
          var params = new GenerateRendererParameters();
          params.classificationDefinition = classDef;
          var generateRenderer = new GenerateRendererTask(DynamicMapServiceURL + "/" + lyr);
          if (lyr === 0)
               generateRenderer.execute(params, applyCPRenderer, showErr);
          else
               generateRenderer.execute(params, applyRenderer, showErr);
        function loadTable(){
                      fieldsoutputted = 'NAME,ST,' + renderedField + ',' + CI + ',' + renderedField.replace('CrudePrev', 'AdjPrev') + ',' + CI.replace('Crude95CI', 'Adj95CI') + ',POP2010';
                  fieldsarray = fieldsoutputted.split(",");
                  fl_url = DynamicMapServiceURL + "/0";
                    citypointlayer = new FeatureLayer(fl_url, {
                                   mode: FeatureLayer.MODE_ONDEMAND,
                                   outFields: fieldsarray,
                                   //infoTemplate: infotemp,
                         , orderByFields: ["NAME"]
                    createRenderer(0, renderedField);
                  AddGrid(0, "citypointgrid");
                    fl_url = DynamicMapServiceURL + "/3";
                    citypolygonlayer = new FeatureLayer(fl_url, {
                         ,orderByFields: ["ST"]
                    createRenderer(3, renderedField);
                    AddGrid(3, "citypolygongrid");
                    showHideGridAndLegend();
  </script>
</head>
<body class="claro esri">
    <div id="map"></div>
     <div id="divGrid">
          <!--<div id="citypt">-->
               <!--<h3>City Point Grid</h3>-->
               <div id="citypointgrid"></div>
          <!--</div>
          <div id="citypoly">-->
               <!--<h3>City Poly Grid</h3>-->
               <div id="citypolygongrid"></div>
          <!--</div>-->
     </div>
</body>
</html>‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
Christopher,
   I removed the JQuery library as esri has a show hide class (and this was all you were loading that heavy library for) I also removed one legacy style line of code and changed where the on extent change handler was set. With the extent change handler setting changed I think it will take care of your issue.
<!DOCTYPE html>
<html>
<head>
    <style>
        html,
        body,
        #map {
            width: 100%;
            height: 500px;
            margin: 0;
            padding: 0;
        #divGrid {
            width: 100%;
            height: 200px;
        .tableheight {
            height: 300px;
    </style>
    <script>
        require([
            "esri/Color",
            "dojo/dom",
            "dojo/parser",
            "dojo/on",
            "dojo/_base/lang",
            "dijit/registry",
            "esri/tasks/query",
            "esri/domUtils",
            "dijit/form/TextBox",
            "dojo/domReady!"
        ], function(Extent, ArcGISDynamicMapServiceLayer, ImageParameters,
            FeatureLayer, FeatureTable, SimpleRenderer, ClassBreaksRenderer, GenerateRendererParameters, GenerateRendererTask, ClassBreaksDefinition, AlgorithmicColorRamp, SimpleMarkerSymbol, SimpleLineSymbol, SimpleFillSymbol, Color,
            domConstruct, dom, parser, on, lang,
            registry, Query, domUtils, Button, ContentPane, BorderContainer, TextBox
            parser.parse();
            var initialExtent = new Extent({
                    "wkid": 102100
                "opacity": 1.0,
            map = new Map("map", {
                basemap: "gray",
                153
            function showErr(err) {
                'use strict;'
            function AddGrid(lyrid, gridloc) {
                if (existingGrid) {
                if (lyrid === 4) {
                        "map": map,
                        "fieldInfos": [{
                                alias: 'City',
                                alias: 'State',
                                alias: 'Column 1',
                            //"gridOptions": [{
                            //     sort: {
                    }, gridloc);
                } else {
                    if (lyrid === 0) {
                            "map": map,
                            "outFields": ["NAME", "ST", renderedField, MoreDetails, MoreDetails2, MoreDetails3],
                            "fieldInfos": [{
                                        alias: 'City',
                                        alias: 'State',
                                        alias: 'Column 1',
                                    //     name: 'POP2010',
                                //"gridOptions": [{
                                //     sort: {
                        }, gridloc);
                    } else {
                            "map": map,
                            "fieldInfos": [{
                                    alias: 'City',
                                    alias: 'State',
                                    alias: 'Column 1',
                                //"gridOptions": [{
                                //     sort: {
                        }, gridloc);
            function showHideGridAndLegend() {
                switch (true) {
                        domUtils.show(dom.byId('citypointgrid'));
                        domUtils.hide(dom.byId('citypolygongrid'));
                        break;
                        domUtils.hide(dom.byId('citypointgrid'));
                        domUtils.show(dom.byId('citypolygongrid'));
                        break;
                        break;
                        break;
                    default:
                        break;
            function applyCPRenderer(citypointrenderer) {
                'use strict;'
            function applyRenderer(renderer) {
                'use strict;'
            function createRenderer(lyr, field) {
                'use strict;'
                if (lyr === 0) {
                } else {
            function loadTable() {
    </script>
</head>
    <div id="divGrid">
        <!--</div>
        <!--</div>-->
    </div>
</body>
</html>
ChristopherJohnson1
Robert, as always, thanks for the response.  Unfortunately, I am still seeing the same behavior.  The column headers on citypolyFT do not appear when the table appears.
Thanks...Chris
Chris,
   Strange. I would have to do some work changing your field names and url to be able to test your exact code. Have you tried to use citypolyFT.refresh()?
ChristopherJohnson1
Hi, Robert.  Yes, I have tried that.
Thanks...Chris
