Displaying survey points on map
1474
11-02-2016 06:26 AM
Hernando_CountyProperty_Apprai
This seems like an easy enough thing to want to do but I can't seem to find anyone doing it.  As a person(s) enters a survey and plots the point on the map, why isn't it showing it?  I'm just wondering how I would know if I'd already answered a survey on a piece of property if I can't see it on the map?  Since it's creating a feature class, how do I show that feature class on the map?
JamesTedrick
Esri Esteemed Contributor
Hi Priscilla,
Currently, we don't support showing the existing survey points on the map inside Survey123. We do envision needing this functionality as part of editing existing features, so it's on our road map.
You can visualize the results as they are coming ing on a device by combining Survey123 with Explorer or Collector, which are map centric applications.
janderson_ksninc
Is this still the case or has this been fixed. I would like to display survey points on a map. If not, has there been a work-around to make the possible?
