How I can overwrite the dojo claro css
1473
10-31-2016 05:20 PM
ParkSeungHyun
I am developing a map open api.
By the way dojo`s 'claro' theme overwrites the other system`s css.
so.. I had to change the code as follows:
<before>
require([ "dojo/domReady!" ], function() {
dojo.addClass(document.body, "claro");
<after>
dojo.addClass(my widget.domNode, "claro");
I added the style of each widget domNode.
but .. dijit popup and combobox css  not changed.
Is it possible they must be used to add style to the body?
How can I use dojo 'claro' css not cover the other systems?
RobertScheitlin__GISP
Park,
  Normally you see developer just use claro in the body and then write css rules to overwrite the claro rules that they want to change in their custom css file.
