Publishing Map as a Feature Service Ends up as a Map Server
1221
10-28-2016 11:10 AM
BruceGreen
Following ESRI documentation at Here
I am trying to publish a Map as Feature Server by enabling the Feature Access on Capability bur when I publish the Map the result looks like
As you can see the URL ends with /MapServer while I need to get a /FeatureServer like
Can you please let me know what I am doing wrong?
JakeSkinner
Esri Esteemed Contributor
Hi Behrouz,
If you click on 'Feature Access' in Server Manager you will see the FeatureServer URL.  Also, you can go to your REST Services Directory to obtain this.  Ex:
http://<server>:6080/arcgis/rest/services
BruceGreen
Thanks for comment Jake, but as you can see in the URL I am not getting any FeatureService but MapServer instead!
DerekLaw
Hi Behrouz,
Allow me to help clarify Jake's comment. In your 2nd screenshot showing the Select and configure capabilities section, if you click on the Feature Access text (not just check the checkbox, but click on the actual text), this will change what is displayed underneath and you should see a section called Feature Access Configuration - which should show you a REST URL and SOAP URL ending in /FeatureServer.
Hope this helps,
JayantaPoddar
MVP Esteemed Contributor
When you publish a feature service, it creates a Map Service and Feature Service (MapServer/FeatureServer).
You should see both the links under http://<ServerName>:6080/arcgis/rest/services
Did you receive any error while analyzing the service before publishing? Could you also ensure the data in your MXD is coming from an enterprise GDB?
Think Location
