CSV Layer JS Id
1792
10-26-2016 08:32 AM
ChristopherSchreiber
Hello all,
I have been working on adding a layer to a map that is based on a CSV table. I am using v3.18 of Esri's JS API to do this. I am having an issue that when I set the "id" of the CSV layer to "Incidents" it still shows up in the layer-list as "csv".
Layer:
       csvLayer: new CSVLayer("/csv/Incidents_test.csv", {
              copyright: "Knowledge Center",
              refreshInterval: 2,
              infoTemplate: kcPopup.csvPopup
What shows in the Layer-list widget:
I am guessing that somewhere the "id" property is being overwritten. I am not sure where though.
Thanks!
Chris
Tags (4)
RobertScheitlin__GISP
Chris,
   Sure all you need to do is supply a title property in the LayerList layers constructor:
            var myWidget = new LayerList({
               map: map,
               layers: [{
                 layer: csv,
                 subLayers: true,
                 title: "Blah Blah"
            },"layerList");
Chris,
               map: map,
               layers: [{
                 layer: csv,
                 subLayers: true,
                 title: "Blah Blah"
            },"layerList");
Thanks Robert,
I was using the "layers" array but I was not including the "Title" property. That is what I was missing.
Chris
