Hide Sublayer in Layer List TOC
5019
11
10-13-2016 02:20 PM
LloydBronn
I have a group layer from a dynamic map service. Right now I have it set to showsubLayers: true under the layerlist function. I want to exclude one of the sublayers from this. It's a mask that I want to always be on and not be visible in the list. Is this possible?
RobertScheitlin__GISP
Lloyd,
   Sure you can with some dom manipulation:
<!DOCTYPE html>
<html>
<head>
<title>Layer List Dijit</title>
<link rel="stylesheet" href="https://js.arcgis.com/3.17/dijit/themes/claro/claro.css">
<link rel="stylesheet" href="https://js.arcgis.com/3.17/esri/css/esri.css">
<style>
html, body, .container, #map {
    height:100%;
    width:100%;
    margin:0;
    padding:0;
    margin:0;
    font-family: "Open Sans";
#map {
    padding:0;
#layerListPane{
    width:25%;
.esriLayer{
  background-color: #fff;
.esriLayerList .esriList{
    border-top:none;
.esriLayerList .esriTitle {
  border-bottom:none;
.esriLayerList .esriList ul{
</style>
<script>var dojoConfig = { parseOnLoad: true };</script>
<script src="https://js.arcgis.com/3.17/"></script>
<script>
require([
    "esri/map",
    "esri/layers/ArcGISDynamicMapServiceLayer",
    "esri/dijit/LayerList",
    "dojo/query",
    "dojo/dom-class",
    "dojo/dom-style",
    "dojo/NodeList-traverse",
    "dijit/layout/BorderContainer",
    "dijit/layout/ContentPane",
    "dojo/domReady!"
], function(
    Map,
    ArcGISDynamicMapServiceLayer,
    LayerList,
    query,
    domClass,
    domStyle
  var map = new Map("map", {
    basemap: "topo",
    center: [-123, 47],
    zoom: 8,
    sliderStyle: "small"
  var atlasLayer = new ArcGISDynamicMapServiceLayer("http://sampleserver6.arcgisonline.com/arcgis/rest/services/Census/MapServer", {
    "id": "atlasLayer",
    "showAttribution": false
  var atlasLayer2 = new ArcGISDynamicMapServiceLayer("http://sampleserver6.arcgisonline.com/arcgis/rest/services/911CallsHotspot/MapServer", {
    "id": "911CallsHotspot",
  var atlasLayer3 = new ArcGISDynamicMapServiceLayer("http://sampleserver6.arcgisonline.com/arcgis/rest/services/CommunityAddressing/MapServer", {
    "id": "CommunityAddressing",
  map.addLayers([atlasLayer, atlasLayer2, atlasLayer3]);
  var llWidget = new LayerList({
     map: map,
     layers: [{
       layer: atlasLayer,
        subLayers: true
       layer: atlasLayer2,
        id: "911 Calls Hotspot",
        subLayers: true
       layer: atlasLayer3,
        id: "Community Addressing",
        subLayers: true
  },"layerList");
  llWidget.startup();
  llWidget.on('load', function(){
    expandLayerList();
  function expandLayerList() {
  //This is where you find your sub layer and hide it
    query('.esriSubList > .esriSubListLayer > .esriTitle > .esriTitleContainer > .esriLabel').forEach(function(node, index){
      if(node.innerHTML === "Output_Features"){
        domStyle.set(node.parentNode.parentNode.parentNode, "display", "none");
    query('.esriLayer').forEach(function(node, index){
      if(index < 2){
        domClass.add(node, "esriListExpand");
    query('.esriToggleButton').forEach(function(node, index){
      if(index < 2){
        domClass.replace(node, "esri-icon-down", "esri-icon-right");
</script>
</head>
<body class="claro">
<div class="container" data-dojo-type="dijit/layout/BorderContainer"
data-dojo-props="design:'headline',gutters:false">
<div id="layerListPane" data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'right'">
    <div id="layerList"></div>
</div>
<div id="map" data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'center'"></div>
</div>
</body>
</html>
Lloyd,
<!DOCTYPE html>
<html>
<head>
<style>
    height:100%;
    width:100%;
    margin:0;
    padding:0;
    margin:0;
#map {
    padding:0;
#layerListPane{
    width:25%;
.esriLayer{
    border-top:none;
  border-bottom:none;
</style>
<script>
require([
    "esri/map",
    "dojo/query",
    "dojo/dom-class",
    "dojo/dom-style",
    "dojo/domReady!"
], function(
    Map,
    LayerList,
    query,
    domClass,
    domStyle
    basemap: "topo",
    center: [-123, 47],
    zoom: 8,
    "id": "atlasLayer",
     map: map,
     layers: [{
       layer: atlasLayer,
        subLayers: true
       layer: atlasLayer2,
        subLayers: true
       layer: atlasLayer3,
        subLayers: true
  },"layerList");
  llWidget.startup();
    expandLayerList();
      if(index < 2){
      if(index < 2){
</script>
</head>
</div>
</div>
</body>
</html>
LloydBronn
OK. I'm looking at your example here. Is it only possible to gray the layers out like this? I don't want it to be visible in the TOC at all.
Lloyd,
   I am not sure why you are thinking that it is graying out the layer when it is changing the css display mode to none (which means it is removed from the display).
LloydBronn
I just opened your example code here in a browser and some of the layers are greyed out. I'll add this into my code and check it out. Thanks!
Lloyd,
   That is built in functionality to show scale dependency for that layer.
These lines hide the layer:
Lloyd,
Don't forget to mark this question as answered by clicking on the "Correct Answer" link on the reply that answered your question.
LloydBronn
Thank you!
LloydBronn
One more question about this. The layer is successfully hidden in the layer list, but it still shows up in the legend. Is there a way to hide it there as well?
Lloyd,
  As this is a whole other question you should start a new thread.
