How hide a route?
2380
10-15-2016 09:38 AM
CloudingSoft
Hello, I have this example of Vehicle Routing Problem Service:
http://optimocamino.cloudingsoft.net/tasks/html/optimo.html
3 tours are red, green and blue.
how I can make 3 buttons to hide each route?
red button hidden red route
green button hidden green route
blue button hidden blue route
Thank you
CloudingSoft
sorry, this on the map with 2 routes
They would then be 2 buttons to hide each route
how could I?
RobertScheitlin__GISP
Fabien,
   Here is your code with that ability:
<html>
<head>
    <link rel="stylesheet" href="https://js.arcgis.com/3.16/esri/themes/calcite/dijit/calcite.css">
    <link rel="stylesheet" href="https://js.arcgis.com/3.16/esri/themes/calcite/esri/esri.css">
    <link rel="stylesheet" href="https://js.arcgis.com/3.16/esri/css/esri.css">
</head>
<body>
    <style>
      .Button {
        width: 40px;
        height: 18px;
        color: white;
        border-radius: 3px;
        border: 1px solid gray;
        line-height: 18px;
        text-align: center;
        float: left;
        margin-left: 8px;
        cursor: pointer;
       .redButton {
         background-color: red;
       .blueButton {
         background-color: blue;
       #routes_reasignados,
       #routes_sync2,
       #routes_sync,
       #routes {
         float: left;
         margin-right: 3px;
    </style>
    <script src="https://js.arcgis.com/3.16/"></script>
    <script>
        var renderer, map, GRAPHICLAYER;
        require([
            "esri/map",
            "esri/dijit/HomeButton",
            "esri/symbols/PictureMarkerSymbol",
            "esri/geometry/webMercatorUtils",
            "dojo/on",
            "dijit/registry",
            "dojo/parser",
            "esri/graphic",
            "esri/graphicsUtils",
            "esri/InfoTemplate",
            "esri/geometry/Point",
            "esri/geometry/Polyline",
            "esri/SpatialReference",
            "esri/symbols/SimpleLineSymbol",
            "esri/renderers/UniqueValueRenderer",
            "esri/Color",
            "dojo/_base/array",
            "dojo/_base/lang",
            "dojo/dom",
            "dojo/json",
            "esri/layers/GraphicsLayer",
            "esri/geometry/jsonUtils",
            "esri/symbols/SimpleMarkerSymbol",
            "esri/symbols/TextSymbol"
        ], function(Map,
            HomeButton,
            PictureMarkerSymbol,
            webMercatorUtils,
            on,
            registry,
            parser,
            Graphic,
            graphicsUtils,
            InfoTemplate,
            Point,
            Polyline,
            SpatialReference,
            SimpleLineSymbol,
            UniqueValueRenderer,
            Color,
            dojoArray,
            lang,
            dom,
            json,
            GraphicsLayer,
            jsonUtils,
            SimpleMarkerSymbol,
            TextSymbol) {
            parser.parse();
            map = new Map("map_camino", {
                basemap: "gray"
            var dsls = new SimpleLineSymbol(SimpleLineSymbol.STYLE_DASH, new Color([0, 0, 0]), 3);
            var rsls = new SimpleLineSymbol(SimpleLineSymbol.STYLE_DASH, new Color([255, 0, 0]), 3);
            var gsls = new SimpleLineSymbol(SimpleLineSymbol.STYLE_DASH, new Color([0, 255, 0]), 3);
            var bsls = new SimpleLineSymbol(SimpleLineSymbol.STYLE_DASH, new Color([0, 0, 255]), 3);
            renderer = new UniqueValueRenderer(dsls, "Name");
            renderer.addValue("Chofer2Insitu_4", gsls);
            renderer.addValue("Chofer3Insitu_5", bsls);
            renderer.addValue("Chofer5Insitu_7", rsls);
            renderer.defaultSymbol = new SimpleLineSymbol(SimpleLineSymbol.STYLE_NULL, new Color([0, 0, 0, 0]), 1);
            on(map, 'load', function(map) {
                load_routes_reasignados();
            on(dom.byId("redBtn"), "click", toggleRoute);
            on(dom.byId("blueBtn"), "click", toggleRoute);
            function toggleRoute(evt){
              //console.info(evt);
              for (var g = 0; g < GRAPHICLAYER.graphics.length; g++){
                var gra = GRAPHICLAYER.graphics[g];
                if(gra.attributes.Name === "Chofer3Insitu_5" && evt.target.id === "blueBtn"){
                  if(uvInfoExists("Chofer3Insitu_5")){
                    renderer.removeValue("Chofer3Insitu_5");
                  }else{
                if(gra.attributes.Name === "Chofer5Insitu_7" && evt.target.id === "redBtn"){
                  if(uvInfoExists("Chofer5Insitu_7")){
                    renderer.removeValue("Chofer5Insitu_7");
                  }else{
              GRAPHICLAYER.refresh();
            function uvInfoExists(value){
                for(var u = 0; u < renderer.infos.length; u++){
                  var ui = renderer.infos[u];
                  if(ui.value === value){
                    return true;
                return false;
            function load_routes_reasignados() {
                var routes = dom.byId("routes_reasignados").innerHTML; //get data example from http://optimocamino.cloudingsoft.net/tasks/responses/output_routes.js
                parsedRoutes = json.parse(routes);
                console.log(parsedRoutes);
                data = parsedRoutes.features;
                console.log(data);
                GRAPHICLAYER = new GraphicsLayer();
                map.addLayer(GRAPHICLAYER);
                GRAPHICLAYER.setRenderer(renderer);
                for (var j = 0; j < data.length; j++) {
                    var route = data[j];
                    var pl = new Polyline(new SpatialReference({
                        wkid: 4326
                    for (var i = 0; i < route.geometry.paths.length; i++) {
                        pl.addPath(route.geometry.paths[i]);
                    var gra = new Graphic();
                    gra.setGeometry(pl);
                    gra.setAttributes(route.attributes);
                    console.info(route.attributes);
                    GRAPHICLAYER.add(gra);
                map.setExtent(graphicsUtils.graphicsExtent(GRAPHICLAYER.graphics), true);
            function setMark(pnt, nombre, direccion, telefono, color, _width, _height, showNumber, Sequence) {
                if (typeof chofer_asignado === 'undefined') {
                    chofer_asignado = '';
                if (typeof ventana_tiempo === 'undefined') {
                    ventana_tiempo = '';
                if (typeof par_id === 'undefined') {
                    par_id = '';
                numberStop = Sequence;
                if (color instanceof Object) {
                    var Symbol = new SimpleMarkerSymbol({
                        "color": color,
                        "size": 15,
                        "angle": -30,
                        "xoffset": 0,
                        "yoffset": 0,
                        "type": "esriSMS",
                        "style": "esriSMSCircle",
                        "outline": {
                            "color": [0, 0, 0, 255],
                            "width": 1,
                            "type": "esriSLS",
                            "style": "esriSLSSolid"
                } else {
                    var Symbol = new PictureMarkerSymbol("https://static.arcgis.com/images/Symbols/Shapes/" + color + "Pin1LargeB.png", _width, _height);
                var textSymbol = new TextSymbol(numberStop).setOffset(0, -4).setColor(new Color([255, 255, 255]));
                info_template = "<i><font color='grey'>Dirección:</font></i> ${Direccion}<br /><i><font color='grey'>Telefono:</font></i> ${Contacto}<br />";
                if (chofer_asignado != "")
                    info_template += "<i><font color='grey'>Vehiculo Asignado:</font></i> ${Vehiculo Asignado}<br />";
                if (ventana_tiempo != "")
                    info_template += "<i><font color='grey'>Ventana de Tiempo:</font></i> ${Ventana de Tiempo}<br />";
                var Template = new InfoTemplate("${Nombre}", info_template);
                var mark = new Graphic(
                    pnt,
                    Symbol, {
                        "Nombre": nombre,
                        "Direccion": "<br/>" + direccion,
                        "Contacto": "<br/>" + telefono,
                        "Ventana de Tiempo": "<br/>" + ventana_tiempo,
                        "Vehiculo Asignado": "<br/>" + chofer_asignado
                    Template);
                map.graphics.add(mark);
                var textMark = new Graphic(
                    pnt,
                    textSymbol);
                map.graphics.add(textMark);
                map.infoWindow.resize(270, 350);
    </script>
    <div id="map_camino" style="width: 100%; height: 94%;"></div>
    <textarea id="routes_reasignados">{"fieldAliases":{"ObjectID":"ObjectID","Name":"Name","FirstStopID":"FirstStopID","LastStopID":"LastStopID","StopCount":"StopCount","Total_TravelTime":"Total_TravelTime","Total_Kilometers":"Total_Kilometers","Total_Miles":"Total_Miles","TotalWait_TravelTime":"TotalWait_TravelTime","TotalViolation_TravelTime":"TotalViolation_TravelTime","StartTime":"StartTime","EndTime":"EndTime","StartTimeUTC":"StartTimeUTC","EndTimeUTC":"EndTimeUTC","Shape_Length":"Shape_Length"},"geometryType":"esriGeometryPolyline","spatialReference":{"wkid":4326,"latestWkid":4326},"features":[{"attributes":{"ObjectID":1,"Name":"Chofer3Insitu_5","FirstStopID":1,"LastStopID":26,"StopCount":15,"Total_TravelTime":294.04809741889511,"Total_Kilometers":202.75990089150434,"Total_Miles":125.98916135487751,"TotalWait_TravelTime":0,"TotalViolation_TravelTime":0,"StartTime":1470355200000,"EndTime":1470372842886,"StartTimeUTC":1470366000000,"EndTimeUTC":1470383642886,"Shape_Length":2.0436788831587647},"geometry":{"paths":[[[-57.90362457599997,-34.942400121999981],[-57.903849999999977,-34.942609999999945],[-57.90301999999997,-34.943189999999959],[-57.903869999999984,-34.943969999999979],[-57.90468999999996,-34.943369999999959],[-57.905499999999961,-34.942739999999958],[-57.907239999999945,-34.944299999999942],[-57.908069999999952,-34.943689999999947],[-57.908909999999935,-34.943089999999984],[-57.909739999999942,-34.943669999999941],[-57.909849999999949,-34.943469999999934],[-57.910109999999975,-34.943509999999947],[-57.910579999999982,-34.943949999999973],[-57.912139999999965,-34.942779999999971],[-57.913139999999942,-34.942029999999932],[-57.916169999999966,-34.939759999999978],[-57.919659999999965,-34.937209999999936],[-57.922749999999951,-34.934949999999958],[-57.927399999999977,-34.931449999999984],[-57.921669999999949,-34.926199999999938],[-57.921269999999936,-34.925839999999937],[-57.921199999999942,-34.925779999999975],[-57.920409999999947,-34.925049999999942],[-57.920199999999966,-34.924699999999973],[-57.919559999999933,-34.923729999999978],[-57.918979999999976,-34.92238999999995],[-57.918729999999982,-34.92133999999993],[-57.918619999999976,-34.920579999999973],[-57.918609999999944,-34.920389999999941],[-57.918599999999969,-34.92002999999994],[-57.918609999999944,-34.919889999999953],[-57.918659999999932,-34.919489999999939],[-57.918709999999976,-34.919099999999958],[-57.918919999999957,-34.91835999999995],[-57.91984999999994,-34.916159999999934],[-57.920779999999979,-34.915159999999958],[-57.921729999999968,-34.914389999999969],[-57.921819999999968,-34.91432999999995],[-57.921899999999937,-34.914259999999956],[-57.922289999999975,-34.913969999999949],[-57.922979999999939,-34.913299999999936],[-57.924019999999985,-34.912159999999972],[-57.924879999999973,-34.910849999999982],[-57.925729999999987,-34.908379999999966],[-57.925789999999949,-34.908149999999978],[-57.926549999999963,-34.907539999999983],[-57.926969999999983,-34.907249999999976],[-57.927469999999971,-34.906889999999976],[-57.932009999999934,-34.903549999999939],[-57.933319999999981,-34.902579999999944],[-57.933459999999968,-34.902339999999981],[-57.933469999999943,-34.90226999999993],[-57.933639999999968,-34.902109999999936],[-57.93411999999995,-34.901939999999968],[-57.934869999999933,-34.901379999999961],[-57.947389999999984,-34.892069999999933],[-57.949639999999931,-34.890399999999943],[-57.953159999999968,-34.887809999999945],[-57.953479999999956,-34.887579999999957],[-57.954189999999983,-34.887049999999931],[-57.956729999999936,-34.885199999999941],[-57.956789999999955,-34.884509999999977],[-57.956899999999962,-34.883129999999937],[-57.956989999999962,-34.881809999999973],[-57.956979999999987,-34.88167999999996],[-57.956989999999962,-34.881539999999973],[-57.956999999999937,-34.881399999999928],[-57.956999999999937,-34.881289999999979],[-57.956959999999981,-34.88098999999994],[-57.956759999999974,-34.880549999999971],[-57.956229999999948,-34.880389999999977],[-57.955799999999954,-34.880599999999959],[-57.955789999999979,-34.881089999999972],[-57.956109999999967,-34.88131999999996],[-57.956729999999936,-34.881399999999928],[-57.957149999999956,-34.881399999999928],[-57.957669999999951,-34.881389999999953],[-57.960119999999961,-34.881179999999972],[-57.961059999999975,-34.881029999999953],[-57.962899999999934,-34.880489999999952],[-57.964199999999948,-34.87982999999997],[-57.96805999999998,-34.877079999999978],[-57.969989999999939,-34.875759999999957],[-57.972199999999987,-34.874639999999943],[-57.974929999999972,-34.873659999999973],[-57.976999999999975,-34.873149999999953],[-57.983209999999985,-34.871609999999976],[-57.999189999999942,-34.867669999999976],[-58.007049999999936,-34.865689999999972],[-58.009969999999953,-34.864969999999971],[-58.012509999999963,-34.864139999999963],[-58.017239999999958,-34.862179999999967],[-58.068659999999966,-34.839509999999962],[-58.070049999999981,-34.838869999999929],[-58.071489999999983,-34.838229999999953],[-58.073219999999935,-34.837469999999939],[-58.074759999999969,-34.836769999999945],[-58.076589999999953,-34.835949999999968],[-58.086959999999976,-34.831339999999955],[-58.089899999999943,-34.829789999999946],[-58.093339999999955,-34.827599999999961],[-58.110269999999957,-34.815429999999935],[-58.114819999999952,-34.811669999999935],[-58.126359999999977,-34.801139999999975],[-58.129269999999963,-34.798459999999977],[-58.132939999999962,-34.79544999999996],[-58.137079999999969,-34.792409999999961],[-58.14015999999998,-34.790349999999933],[-58.144339999999943,-34.787629999999979],[-58.152929999999969,-34.781979999999976],[-58.153279999999938,-34.781549999999982],[-58.153509999999983,-34.780969999999968],[-58.153069999999957,-34.780599999999936],[-58.152469999999937,-34.780779999999936],[-58.152189999999962,-34.781299999999931],[-58.152209999999968,-34.782169999999951],[-58.152799999999957,-34.783349999999984],[-58.153239999999983,-34.784239999999954],[-58.15399999999994,-34.78547999999995],[-58.154399999999953,-34.786179999999945],[-58.154909999999973,-34.786999999999978],[-58.15680999999995,-34.790079999999932],[-58.158599999999979,-34.793019999999956],[-58.159159999999986,-34.793929999999932],[-58.16143999999997,-34.797589999999957],[-58.163079999999979,-34.799679999999967],[-58.164369999999963,-34.800989999999956],[-58.167049999999961,-34.803259999999966],[-58.167399999999986,-34.803529999999967],[-58.174889999999948,-34.80971999999997],[-58.178899999999942,-34.812999999999931],[-58.18077999999997,-34.814569999999947],[-58.185149999999965,-34.818199999999933],[-58.185469999999953,-34.818459999999959],[-58.186559999999986,-34.819369999999935],[-58.188339999999982,-34.82084999999995],[-58.189509999999984,-34.822079999999971],[-58.19023999999996,-34.823039999999935],[-58.191369999999949,-34.825049999999976],[-58.192049999999938,-34.827179999999942],[-58.192279999999982,-34.829449999999952],[-58.192069999999944,-34.831409999999948],[-58.191979999999944,-34.831749999999943],[-58.191929999999957,-34.831989999999962],[-58.190819999999974,-34.83564999999993],[-58.190519999999935,-34.836599999999976],[-58.190359999999941,-34.837139999999977],[-58.19014999999996,-34.838999999999942],[-58.189769999999953,-34.839939999999956],[-58.18972999999994,-34.840409999999963],[-58.189789999999959,-34.840469999999982],[-58.190529999999967,-34.840479999999957],[-58.191249999999968,-34.840169999999944],[-58.202729999999974,-34.835279999999955],[-58.209279999999978,-34.832429999999931],[-58.212809999999934,-34.830979999999954],[-58.217139999999972,-34.829099999999983],[-58.218369999999936,-34.828589999999963],[-58.218879999999956,-34.828359999999975],[-58.220599999999934,-34.827619999999968],[-58.221569999999986,-34.827199999999948],[-58.222779999999943,-34.826709999999935],[-58.223029999999937,-34.826599999999928],[-58.223679999999945,-34.826319999999953],[-58.224089999999933,-34.826129999999978],[-58.224909999999966,-34.825589999999977],[-58.225749999999948,-34.824779999999976],[-58.22620999999998,-34.82400999999993],[-58.226389999999981,-34.823499999999967],[-58.226519999999937,-34.822749999999928],[-58.226389999999981,-34.820929999999976],[-58.226099999999974,-34.818669999999941],[-58.226149999999961,-34.818009999999958],[-58.226429999999937,-34.817069999999944],[-58.227059999999938,-34.81601999999998],[-58.227129999999931,-34.81592999999998],[-58.227559999999983,-34.815359999999941],[-58.228039999999964,-34.814709999999934],[-58.228549999999984,-34.814029999999946],[-58.228639999999984,-34.813899999999933],[-58.228969999999947,-34.813459999999964],[-58.229739999999936,-34.812469999999962],[-58.230619999999988,-34.81129999999996],[-58.231769999999983,-34.809759999999983],[-58.232429999999965,-34.808889999999963],[-58.232849999999985,-34.808329999999955],[-58.233289999999954,-34.807759999999973],[-58.233749999999986,-34.807159999999953],[-58.234489999999937,-34.806169999999952],[-58.234809999999982,-34.805759999999964],[-58.234989999999982,-34.805519999999945],[-58.235299999999938,-34.805109999999956],[-58.235719999999958,-34.804559999999981],[-58.236089999999933,-34.804079999999942],[-58.236149999999952,-34.803999999999974],[-58.236569999999972,-34.803439999999966],[-58.237149999999986,-34.802659999999946],[-58.237519999999961,-34.802179999999964],[-58.237639999999942,-34.802009999999939],[-58.237869999999987,-34.801709999999957],[-58.238279999999975,-34.80114999999995],[-58.238799999999969,-34.800519999999949],[-58.238929999999982,-34.800379999999961],[-58.239489999999932,-34.799849999999935],[-58.240069999999946,-34.799349999999947],[-58.240639999999985,-34.798929999999984],[-58.240979999999979,-34.798679999999933],[-58.241319999999973,-34.798419999999965],[-58.241759999999942,-34.798089999999945],[-58.242599999999982,-34.797449999999969],[-58.243579999999952,-34.796709999999962],[-58.245909999999981,-34.794959999999946],[-58.246819999999957,-34.794279999999958],[-58.248679999999979,-34.793169999999975],[-58.250229999999931,-34.792309999999929],[-58.250729999999976,-34.791999999999973],[-58.251709999999946,-34.791319999999985],[-58.252509999999972,-34.790609999999958],[-58.253129999999942,-34.789939999999945],[-58.253219999999942,-34.78983999999997],[-58.253709999999955,-34.789309999999944],[-58.253889999999956,-34.789119999999969],[-58.25422999999995,-34.788759999999968],[-58.254549999999938,-34.788399999999967],[-58.254759999999976,-34.78816999999998],[-58.255239999999958,-34.787669999999935],[-58.255329999999958,-34.78756999999996],[-58.256049999999959,-34.786889999999971],[-58.256049999999959,-34.786799999999971],[-58.256139999999959,-34.786699999999939],[-58.259339999999952,-34.78311999999994],[-58.260509999999954,-34.781829999999957],[-58.261649999999975,-34.780579999999929],[-58.26192999999995,-34.780269999999973],[-58.262559999999951,-34.779579999999953],[-58.262770488999934,-34.779342524999947],[-58.263339999999971,-34.778699999999958],[-58.263469999999984,-34.778539999999964],[-58.262489999999957,-34.777999999999963],[-58.261669999999981,-34.777569999999969],[-58.26085999999998,-34.778649999999971],[-58.260139999999978,-34.77953999999994],[-58.253569999999968,-34.775899999999979],[-58.249319999999955,-34.773629999999969],[-58.247079999999983,-34.772429999999929],[-58.246119999999962,-34.772069999999928],[-58.244099999999946,-34.770829999999933],[-58.243999999999971,-34.770789999999977],[-58.239809999999977,-34.768549999999948],[-58.234729999999956,-34.765719999999931],[-58.234579999999937,-34.765639999999962],[-58.232429999999965,-34.764479999999935],[-58.22996999999998,-34.763159999999971],[-58.225079999999934,-34.760519999999929],[-58.220959999999934,-34.758359999999982],[-58.22079999999994,-34.75825999999995],[-58.220649999999978,-34.758159999999975],[-58.220479999999952,-34.758109999999931],[-58.218979999999931,-34.757309999999961],[-58.218839999999943,-34.757229999999936],[-58.219029999999975,-34.756979999999942],[-58.218339999999955,-34.756629999999973],[-58.217139999999972,-34.755999999999972],[-58.215929999999958,-34.755369999999971],[-58.214709999999968,-34.754719999999963],[-58.215469999999982,-34.75371999999993],[-58.216152826999974,-34.754069739999977],[-58.216699999999946,-34.754349999999931],[-58.217069999999978,-34.753849999999943],[-58.216089999999951,-34.752879999999948],[-58.215769999999964,-34.752569999999935],[-58.215679999999963,-34.752489999999966],[-58.215589999999963,-34.75237999999996],[-58.218529999999987,-34.751009999999951],[-58.222099999999955,-34.750079999999969],[-58.222629999999981,-34.749949999999956],[-58.223339999999951,-34.749359999999967],[-58.225369999999941,-34.747649999999965],[-58.224699999999984,-34.74721999999997],[-58.224069999999983,-34.746819999999957],[-58.222899999999981,-34.746069999999975],[-58.22172999999998,-34.745419999999967],[-58.22043999999994,-34.744759999999928],[-58.220819999999947,-34.74407999999994],[-58.221169999999972,-34.743479999999977],[-58.221549999999979,-34.742869999999982],[-58.22226999999998,-34.74162999999993],[-58.223089999999956,-34.740529999999978],[-58.222419999999943,-34.740149999999971],[-58.222899999999981,-34.739039999999932],[-58.223199999999963,-34.738239999999962],[-58.223429999999951,-34.73768999999993],[-58.223059999999975,-34.73748999999998],[-58.222729999999956,-34.737339999999961],[-58.222429999999974,-34.737189999999941],[-58.222119999999961,-34.737039999999979],[-58.222039999999936,-34.736999999999966],[-58.221794750999948,-34.736873871999933],[-58.222039999999936,-34.736999999999966],[-58.222119999999961,-34.737039999999979],[-58.222429999999974,-34.737189999999941],[-58.222729999999956,-34.737339999999961],[-58.223059999999975,-34.73748999999998],[-58.223429999999951,-34.73768999999993],[-58.223829999999964,-34.737889999999936],[-58.224069999999983,-34.737999999999943],[-58.224409999999978,-34.738159999999937],[-58.22482999999994,-34.738389999999981],[-58.225539999999967,-34.737549999999942],[-58.225969999999961,-34.737039999999979],[-58.227019999999982,-34.737599999999929],[-58.228099999999984,-34.738169999999968],[-58.228619999999978,-34.738419999999962],[-58.229139999999973,-34.738719999999944],[-58.229329999999948,-34.738819999999976],[-58.229849999999942,-34.738099999999974],[-58.230379999999968,-34.737389999999948],[-58.230939999999975,-34.736669999999947],[-58.231499999999983,-34.735929999999939],[-58.23243999999994,-34.736429999999984],[-58.233119999999985,-34.736769999999979],[-58.23390999999998,-34.737169999999935],[-58.23461999999995,-34.737529999999936],[-58.235559999999964,-34.738019999999949],[-58.235251210999934,-34.738197308999929],[-58.234519999999975,-34.738519999999937],[-58.235519999999951,-34.739039999999932],[-58.236589999999978,-34.738549999999975],[-58.237559999999974,-34.739049999999963],[-58.238199999999949,-34.739409999999964],[-58.243609999999933,-34.733879999999942],[-58.246419999999944,-34.730979999999931],[-58.245859999999936,-34.730599999999981],[-58.244969999999967,-34.730099999999936],[-58.245849999999962,-34.72891999999996],[-58.246689999999944,-34.727809999999977],[-58.247489999999971,-34.726689999999962],[-58.24801999999994,-34.725979999999936],[-58.248609999999985,-34.725209999999947],[-58.249209999999948,-34.724389999999971],[-58.249789999999962,-34.72357999999997],[-58.250339999999937,-34.722819999999956],[-58.250909999999976,-34.722009999999955],[-58.251199999999983,-34.721629999999948],[-58.252389999999934,-34.719979999999964],[-58.252629999999954,-34.719679999999983],[-58.253219999999942,-34.718899999999962],[-58.253799999999956,-34.718129999999974],[-58.254379999999969,-34.717379999999935],[-58.254929999999945,-34.716619999999978],[-58.255569999999977,-34.715759999999932],[-58.25640999999996,-34.714639999999974],[-58.257299999999987,-34.715049999999962],[-58.258279999999957,-34.715549999999951],[-58.258889999999951,-34.714749999999981],[-58.259469999999965,-34.713999999999942],[-58.260129999999947,-34.71324999999996],[-58.260939999999948,-34.713679999999954],[-58.260389999999973,-34.714429999999936],[-58.260088131999964,-34.714846369999975],[-58.259809999999959,-34.715229999999963],[-58.26076999999998,-34.715739999999983],[-58.261639999999943,-34.716179999999952],[-58.262579999999957,-34.716689999999971],[-58.263529999999946,-34.717179999999985],[-58.263799999999947,-34.717339999999979],[-58.264519999999948,-34.717699999999979],[-58.264169999999979,-34.718189999999936],[-58.265089999999987,-34.718679999999949],[-58.265199999999936,-34.718729999999937],[-58.265829999999937,-34.71787999999998],[-58.266569999999945,-34.717059999999947],[-58.267189999999971,-34.716239999999971],[-58.267769999999985,-34.715469999999982],[-58.268589999999961,-34.714799999999968],[-58.269339999999943,-34.715169999999944],[-58.270289999999932,-34.715659999999957],[-58.270479999999964,-34.715749999999957],[-58.271079999999984,-34.716069999999945],[-58.271239999999977,-34.716159999999945],[-58.271689999999978,-34.715599999999938],[-58.271879999999953,-34.715379999999982],[-58.272009999999966,-34.715199999999982],[-58.272479999999973,-34.714619999999968],[-58.272939999999949,-34.714069999999936],[-58.273589999999956,-34.713329999999928],[-58.274219999999957,-34.712599999999952],[-58.274479999999983,-34.712299999999971],[-58.275109999999984,-34.712009999999964],[-58.276349999999979,-34.711379999999963],[-58.277619999999956,-34.710779999999943],[-58.278799999999933,-34.710219999999936],[-58.278869999999984,-34.710289999999929],[-58.279592696999941,-34.710824730999946],[-58.278869999999984,-34.710289999999929],[-58.27768999999995,-34.710859999999968],[-58.280089999999973,-34.712379999999939],[-58.282289999999932,-34.713649999999973],[-58.28293999999994,-34.714019999999948],[-58.283279999999934,-34.71420999999998],[-58.283159999999953,-34.715089999999975],[-58.283529999999985,-34.71527999999995],[-58.283189999999934,-34.715999999999951],[-58.284119999999973,-34.716509999999971],[-58.285049999999956,-34.717009999999959],[-58.28598999999997,-34.717519999999979],[-58.286999999999978,-34.718029999999942],[-58.28801999999996,-34.718519999999955],[-58.289029999999968,-34.719029999999975],[-58.288339999999948,-34.719959999999958],[-58.289409999999975,-34.720519999999965],[-58.288759999999968,-34.721409999999935],[-58.28825999999998,-34.722099999999955],[-58.287639999999953,-34.722949999999969],[-58.288149999999973,-34.723189999999931],[-58.299639999999954,-34.728839999999934],[-58.300649999999962,-34.729379999999935],[-58.300689999999975,-34.729399999999941],[-58.31033999999994,-34.734029999999962],[-58.311179999999979,-34.734459999999956],[-58.312449999999956,-34.735089999999957],[-58.313009999999963,-34.735429999999951],[-58.31374999999997,-34.735869999999977],[-58.314209999999946,-34.736149999999952],[-58.315399999999954,-34.736879999999928],[-58.317409999999938,-34.738279999999975],[-58.318879999999979,-34.739209999999957],[-58.31926999999996,-34.739299999999957],[-58.319369999999935,-34.739239999999938],[-58.319729999999936,-34.739359999999976],[-58.319739999999967,-34.739489999999932],[-58.320149999999956,-34.739969999999971],[-58.331679999999949,-34.746869999999944],[-58.333879999999965,-34.748029999999972],[-58.338529999999935,-34.750209999999981],[-58.339359999999942,-34.750439999999969],[-58.339549999999974,-34.750499999999931],[-58.341659999999933,-34.751369999999952],[-58.342779999999948,-34.752009999999984],[-58.348049999999944,-34.754769999999951],[-58.349039999999945,-34.755249999999933],[-58.34946999999994,-34.755459999999971],[-58.350129999999979,-34.755779999999959],[-58.350779999999986,-34.756119999999953],[-58.351479999999981,-34.756439999999941],[-58.352149999999938,-34.75676999999996],[-58.352349999999944,-34.756869999999935],[-58.353599999999972,-34.757489999999962],[-58.353649999999959,-34.757519999999943],[-58.354659999999967,-34.758009999999956],[-58.355089999999961,-34.758219999999937],[-58.35576999999995,-34.758559999999932],[-58.356159999999932,-34.758759999999938],[-58.356449999999938,-34.758929999999964],[-58.357289999999978,-34.759329999999977],[-58.357479999999953,-34.759419999999977],[-58.358489999999961,-34.759939999999972],[-58.359239999999943,-34.760299999999972],[-58.359549999999956,-34.760459999999966],[-58.360639999999933,-34.760999999999967],[-58.359899999999982,-34.762049999999931],[-58.359269999999981,-34.762939999999958],[-58.358469999999954,-34.763809999999978],[-58.357959999999935,-34.764399999999966],[-58.357419999999934,-34.765109999999936],[-58.356889999999964,-34.765859999999975],[-58.356229999999982,-34.766729999999939],[-58.355702089999966,-34.767456957999968],[-58.355619999999988,-34.767569999999978],[-58.356569999999977,-34.768059999999934],[-58.357539999999972,-34.768549999999948],[-58.358509999999967,-34.769089999999949],[-58.359969999999976,-34.769869999999969],[-58.36146999999994,-34.770259999999951],[-58.362349999999935,-34.770739999999932],[-58.362539999999967,-34.770839999999964],[-58.362529999999936,-34.772119999999973],[-58.362539999999967,-34.77285999999998],[-58.362539999999967,-34.77332999999993],[-58.362529999999936,-34.774719999999945],[-58.362539999999967,-34.775259999999946],[-58.362499999999955,-34.776159999999948],[-58.362509999999986,-34.776769999999942],[-58.362509999999986,-34.777019999999936],[-58.363479999999981,-34.777539999999931],[-58.364539999999977,-34.778169999999932],[-58.364609999999971,-34.778249999999957],[-58.365479999999934,-34.778709999999933],[-58.366809999999987,-34.779399999999953],[-58.368149999999957,-34.780109999999979],[-58.36949999999996,-34.780819999999949],[-58.370819999999981,-34.781529999999975],[-58.372149999999976,-34.78222999999997],[-58.373459999999966,-34.782929999999965],[-58.374799999999937,-34.783649999999966],[-58.376179999999977,-34.784359999999936],[-58.377479999999935,-34.78505999999993],[-58.377509429999975,-34.785022614999946],[-58.377479999999935,-34.78505999999993],[-58.378789999999981,-34.78574999999995],[-58.380119999999977,-34.786449999999945],[-58.380979999999965,-34.786899999999946],[-58.381379999999979,-34.787129999999934],[-58.381849999999986,-34.787359999999978],[-58.382749999999987,-34.787819999999954],[-58.383449999999982,-34.786899999999946],[-58.384169999999983,-34.78589999999997],[-58.384829999999965,-34.78496999999993],[-58.38594999999998,-34.783559999999966],[-58.386939999999981,-34.782349999999951],[-58.388139999999964,-34.780839999999955],[-58.388709999999946,-34.780119999999954],[-58.390079999999955,-34.780859999999961],[-58.390189999999961,-34.780579999999929],[-58.390569999999968,-34.77968999999996],[-58.390709999999956,-34.77944999999994],[-58.390789999999981,-34.778989999999965],[-58.391099999999938,-34.778249999999957],[-58.391569999999945,-34.777129999999943],[-58.392949999999985,-34.777939999999944],[-58.393689999999935,-34.778349999999932],[-58.396119999999939,-34.779629999999941],[-58.396399999999971,-34.779769999999928],[-58.398629999999969,-34.780929999999955],[-58.398939999999982,-34.781169999999975],[-58.400379999999984,-34.781989999999951],[-58.401519999999948,-34.782599999999945],[-58.402659999999969,-34.783219999999972],[-58.403819999999939,-34.783839999999941],[-58.404879999999935,-34.784429999999929],[-58.40546999999998,-34.783669999999972],[-58.405679999999961,-34.783609999999953],[-58.406029999999987,-34.78371999999996],[-58.407109999999932,-34.783549999999934],[-58.408799999999985,-34.784389999999973],[-58.409909999999968,-34.784979999999962],[-58.410719999999969,-34.783919999999966],[-58.411859999999933,-34.784519999999929],[-58.412651879999942,-34.784955533999948],[-58.411859999999933,-34.784519999999929],[-58.412729999999954,-34.783419999999978],[-58.411599999999964,-34.782819999999958],[-58.412369999999953,-34.781849999999963],[-58.412429999999972,-34.781759999999963],[-58.413209999999935,-34.780779999999936],[-58.413999999999987,-34.779819999999972],[-58.414709999999957,-34.778919999999971],[-58.415339999999958,-34.77810999999997],[-58.41608999999994,-34.777149999999949],[-58.416899999999941,-34.776119999999935],[-58.417699999999968,-34.775109999999984],[-58.418469999999957,-34.774099999999976],[-58.419299999999964,-34.773069999999962],[-58.420179999999959,-34.771949999999947],[-58.421549999999968,-34.771739999999966],[-58.422409999999957,-34.771639999999934],[-58.42298999999997,-34.77156999999994],[-58.423629999999946,-34.771509999999978],[-58.423569999999984,-34.770949999999971],[-58.423449999999946,-34.769649999999956],[-58.423469999999952,-34.765979999999956],[-58.422369999999944,-34.76114999999993],[-58.422079999999937,-34.759909999999934],[-58.422369999999944,-34.76114999999993],[-58.423209999999983,-34.761029999999948],[-58.430009999999982,-34.760039999999947],[-58.430129999999963,-34.760029999999972],[-58.431209999999965,-34.759909999999934],[-58.431359999999984,-34.759389999999939],[-58.431899999999985,-34.758019999999931],[-58.432169999999985,-34.75736999999998],[-58.432979999999986,-34.756199999999978],[-58.435199999999952,-34.753009999999961],[-58.435919999999953,-34.751829999999984],[-58.435909999999978,-34.751439999999945],[-58.435589999999934,-34.75097999999997],[-58.43402999999995,-34.75010999999995],[-58.432319999999947,-34.749259999999936],[-58.431219999999939,-34.748689999999954],[-58.430389999999932,-34.747799999999984],[-58.429779999999937,-34.74554999999998],[-58.429589999999962,-34.744619999999941],[-58.429539999999974,-34.743749999999977],[-58.430049999999937,-34.742899999999963],[-58.430969999999945,-34.741679999999974],[-58.431889999999953,-34.74049999999994],[-58.432459999999935,-34.739749999999958],[-58.432769999999948,-34.739359999999976],[-58.433469999999943,-34.738339999999937],[-58.433689999999956,-34.737879999999961],[-58.434729999999945,-34.735969999999952],[-58.43638999999996,-34.733619999999974],[-58.436789999999974,-34.733099999999979],[-58.437909999999931,-34.731599999999958],[-58.439409999999953,-34.729679999999973],[-58.439859999999953,-34.729129999999941],[-58.440709999999967,-34.728039999999964],[-58.441469999999981,-34.726609999999937],[-58.442009999999982,-34.725839999999948],[-58.441479999999956,-34.725579999999979],[-58.440289999999948,-34.725019999999972],[-58.439149999999984,-34.724459999999965],[-58.43796999999995,-34.723909999999933],[-58.43680999999998,-34.723329999999976],[-58.435619999999972,-34.722699999999975],[-58.434979999999939,-34.723479999999938],[-58.434369999999944,-34.724209999999971],[-58.433899999999937,-34.724879999999985],[-58.433839999999975,-34.724989999999934],[-58.432789999999954,-34.724449999999933],[-58.431859999999972,-34.723949999999945],[-58.431299999999965,-34.72473999999994],[-58.43157675599997,-34.724882939999929],[-58.431299999999965,-34.72473999999994],[-58.431859999999972,-34.723949999999945],[-58.432789999999954,-34.724449999999933],[-58.433839999999975,-34.724989999999934],[-58.433899999999937,-34.724879999999985],[-58.434369999999944,-34.724209999999971],[-58.434979999999939,-34.723479999999938],[-58.435619999999972,-34.722699999999975],[-58.43680999999998,-34.723329999999976],[-58.43796999999995,-34.723909999999933],[-58.439149999999984,-34.724459999999965],[-58.440289999999948,-34.725019999999972],[-58.441479999999956,-34.725579999999979],[-58.442009999999982,-34.725839999999948],[-58.44250999999997,-34.725219999999979],[-58.442809999999952,-34.72482999999994],[-58.443779999999947,-34.724139999999977],[-58.444299999999942,-34.723459999999932],[-58.444939999999974,-34.722619999999949],[-58.44653999999997,-34.720559999999978],[-58.447709999999972,-34.719089999999937],[-58.448649999999986,-34.717909999999961],[-58.454449999999952,-34.710789999999974],[-58.456459999999936,-34.708479999999952],[-58.458059999999932,-34.707269999999937],[-58.458339999999964,-34.706659999999943],[-58.458449999999971,-34.706359999999961],[-58.45870999999994,-34.70623999999998],[-58.459639999999979,-34.705539999999928],[-58.461059999999975,-34.704579999999964],[-58.461799999999982,-34.704069999999945],[-58.462779999999952,-34.703509999999937],[-58.467429999999979,-34.700429999999983],[-58.468969999999956,-34.699229999999943],[-58.472159999999974,-34.696459999999945],[-58.473869999999977,-34.695219999999949],[-58.477439999999945,-34.692699999999945],[-58.47936999999996,-34.69121999999993],[-58.480309999999974,-34.690519999999935],[-58.480609999999956,-34.690309999999954],[-58.481129999999951,-34.689909999999941],[-58.481749999999977,-34.689439999999934],[-58.48234999999994,-34.688989999999933],[-58.485159999999951,-34.686869999999942],[-58.48530999999997,-34.686759999999936],[-58.488509999999962,-34.68435999999997],[-58.489969999999971,-34.683279999999968],[-58.49939999999998,-34.676139999999975],[-58.502009999999984,-34.674159999999972],[-58.504339999999956,-34.672369999999944],[-58.505999999999972,-34.671109999999942],[-58.513879999999972,-34.66519999999997],[-58.514549999999986,-34.66468999999995],[-58.521419999999978,-34.659479999999974],[-58.522779999999955,-34.658419999999978],[-58.525289999999984,-34.656609999999944],[-58.527129999999943,-34.655129999999929],[-58.527789999999982,-34.654349999999965],[-58.527909999999963,-34.654189999999971],[-58.528549999999939,-34.652949999999976],[-58.529139999999984,-34.646129999999971],[-58.529099999999971,-34.645019999999931],[-58.529349999999965,-34.641539999999964],[-58.529429999999934,-34.64017999999993],[-58.529809999999941,-34.635199999999941],[-58.529839999999979,-34.634759999999972],[-58.529939999999954,-34.633119999999963],[-58.529949999999985,-34.632929999999931],[-58.530059999999935,-34.630539999999939],[-58.530079999999941,-34.63009999999997],[-58.530109999999979,-34.629299999999944],[-58.530119999999954,-34.62913999999995],[-58.530119999999954,-34.628969999999981],[-58.530159999999967,-34.627869999999973],[-58.530269999999973,-34.626089999999976],[-58.530309999999986,-34.62537999999995],[-58.530449999999973,-34.623179999999934],[-58.530459999999948,-34.622999999999934],[-58.530479999999955,-34.622609999999952],[-58.530699999999968,-34.618949999999984],[-58.53073999999998,-34.61818999999997],[-58.530759999999987,-34.617829999999969],[-58.530769999999961,-34.617729999999938],[-58.530769999999961,-34.615509999999972],[-58.530589999999961,-34.614939999999933],[-58.530519999999967,-34.614759999999933],[-58.528919999999971,-34.611339999999984],[-58.528879999999958,-34.611249999999984],[-58.528839999999946,-34.611159999999984],[-58.527749999999969,-34.608879999999942],[-58.526759999999967,-34.606759999999952],[-58.526669999999967,-34.606579999999951],[-58.526089999999954,-34.60534999999993],[-58.526009999999985,-34.605179999999962],[-58.524569999999983,-34.602089999999976],[-58.52267999999998,-34.598589999999945],[-58.521199999999965,-34.594889999999964],[-58.520289999999932,-34.592999999999961],[-58.520059999999944,-34.59245999999996],[-58.519979999999975,-34.59227999999996],[-58.519929999999931,-34.592179999999985],[-58.519559999999956,-34.591439999999977],[-58.519209999999987,-34.590999999999951],[-58.518539999999973,-34.590139999999963],[-58.518459999999948,-34.589939999999956],[-58.518269999999973,-34.58949999999993],[-58.518629999999973,-34.58940999999993],[-58.518769999999961,-34.589369999999974],[-58.518979999999942,-34.589309999999955],[-58.519179999999949,-34.589249999999936],[-58.519409999999937,-34.589169999999967],[-58.519869999999969,-34.589039999999954],[-58.520459999999957,-34.588899999999967],[-58.52225999999996,-34.58833999999996],[-58.523159999999962,-34.588069999999959],[-58.524069999999938,-34.587799999999959],[-58.525859999999966,-34.587229999999977],[-58.526539999999954,-34.586499999999944],[-58.527149999999949,-34.585789999999974],[-58.527809999999931,-34.585019999999929],[-58.528329999999983,-34.584439999999972],[-58.528819999999939,-34.583909999999946],[-58.529349999999965,-34.583299999999952],[-58.530149999999935,-34.58397999999994],[-58.530899999999974,-34.584639999999979],[-58.530772977999959,-34.584746343999939],[-58.53046999999998,-34.58499999999998],[-58.529889999999966,-34.585439999999949],[-58.52899999999994,-34.58615999999995],[-58.528459999999939,-34.586569999999938],[-58.527669999999944,-34.587189999999964],[-58.527189999999962,-34.587629999999933],[-58.526959999999974,-34.587899999999934],[-58.526089999999954,-34.587359999999933],[-58.525859999999966,-34.587229999999977],[-58.520459999999957,-34.588899999999967],[-58.519869999999969,-34.589039999999954],[-58.519409999999937,-34.589169999999967],[-58.519179999999949,-34.589249999999936],[-58.519249999999943,-34.589519999999936],[-58.51971999999995,-34.591379999999958],[-58.520069999999976,-34.592119999999966],[-58.520129999999938,-34.592239999999947],[-58.520219999999938,-34.592419999999947],[-58.520419999999945,-34.592869999999948],[-58.521359999999959,-34.594829999999945],[-58.522819999999967,-34.598519999999951],[-58.524739999999952,-34.602059999999938],[-58.526179999999954,-34.605129999999974],[-58.526259999999979,-34.605309999999974],[-58.526839999999936,-34.606539999999939],[-58.526929999999936,-34.606719999999939],[-58.527769999999975,-34.608539999999948],[-58.528959999999984,-34.611069999999984],[-58.52899999999994,-34.611159999999984],[-58.529039999999952,-34.611249999999984],[-58.530669999999986,-34.614689999999939],[-58.530749999999955,-34.614869999999939],[-58.530909999999949,-34.615299999999934],[-58.531019999999955,-34.615989999999954],[-58.530919999999981,-34.617719999999963],[-58.530919999999981,-34.617829999999969],[-58.530899999999974,-34.61818999999997],[-58.530849999999987,-34.618949999999984],[-58.53064999999998,-34.622609999999952],[-58.530619999999942,-34.622999999999934],[-58.530609999999967,-34.623179999999934],[-58.530459999999948,-34.625389999999982],[-58.530429999999967,-34.625999999999976],[-58.530329999999935,-34.627849999999967],[-58.530309999999986,-34.62842999999998],[-58.530289999999979,-34.628979999999956],[-58.530279999999948,-34.62913999999995],[-58.530269999999973,-34.629299999999944],[-58.530239999999935,-34.630109999999945],[-58.530219999999986,-34.630549999999971],[-58.530239999999935,-34.630859999999984],[-58.530249999999967,-34.632929999999931],[-58.530239999999935,-34.633119999999963],[-58.530259999999942,-34.633219999999937],[-58.530239999999935,-34.63349999999997],[-58.530809999999974,-34.634879999999953],[-58.530619999999942,-34.63525999999996],[-58.53022999999996,-34.635509999999954],[-58.529489999999953,-34.635519999999929],[-58.528959999999984,-34.635269999999934],[-58.528669999999977,-34.635189999999966],[-58.528209999999945,-34.635059999999953],[-58.527499999999975,-34.635139999999978],[-58.526839999999936,-34.635319999999979],[-58.526069999999947,-34.63561999999996],[-58.523999999999944,-34.636639999999943],[-58.522309999999948,-34.636879999999962],[-58.520689999999945,-34.636739999999975],[-58.51840999999996,-34.636119999999949],[-58.51655999999997,-34.635689999999954],[-58.513999999999953,-34.635329999999954],[-58.51219999999995,-34.635209999999972],[-58.51052999999996,-34.635369999999966],[-58.507779999999968,-34.63614999999993],[-58.506059999999934,-34.636409999999955],[-58.504219999999975,-34.636359999999968],[-58.499019999999973,-34.635739999999942],[-58.497779999999977,-34.635869999999954],[-58.496719999999982,-34.63621999999998],[-58.495669999999961,-34.636919999999975],[-58.495259999999973,-34.63728999999995],[-58.493769999999984,-34.639209999999935],[-58.491809999999987,-34.64146999999997],[-58.490489999999966,-34.642579999999953],[-58.490129999999965,-34.642889999999966],[-58.48775999999998,-34.64462999999995],[-58.486259999999959,-34.645449999999983],[-58.485039999999969,-34.646019999999965],[-58.48312999999996,-34.646729999999934],[-58.482599999999934,-34.646919999999966],[-58.481669999999951,-34.647229999999979],[-58.479309999999941,-34.647959999999955],[-58.478129999999965,-34.648259999999937],[-58.476299999999981,-34.64874999999995],[-58.47575999999998,-34.648899999999969],[-58.474449999999933,-34.64916999999997],[-58.473149999999976,-34.649329999999964],[-58.470949999999959,-34.649499999999932],[-58.469719999999938,-34.649609999999939],[-58.469499999999982,-34.649629999999945],[-58.469259999999963,-34.649659999999983],[-58.469079999999963,-34.649679999999933],[-58.468639999999937,-34.649719999999945],[-58.468089999999961,-34.649769999999933],[-58.46676999999994,-34.649799999999971],[-58.465849999999932,-34.649839999999983],[-58.465509999999938,-34.649869999999964],[-58.464549999999974,-34.649959999999965],[-58.464049999999986,-34.649989999999946],[-58.463219999999978,-34.650039999999933],[-58.462579999999946,-34.650089999999977],[-58.461119999999937,-34.650179999999978],[-58.459889999999973,-34.650279999999952],[-58.457629999999938,-34.650469999999984],[-58.456889999999987,-34.650539999999978],[-58.45512999999994,-34.650729999999953],[-58.454609999999946,-34.650799999999947],[-58.454169999999976,-34.650849999999934],[-58.453829999999982,-34.650889999999947],[-58.453349999999944,-34.650939999999935],[-58.453019999999981,-34.650959999999941],[-58.449089999999956,-34.651159999999948],[-58.445629999999937,-34.651039999999966],[-58.445299999999975,-34.65101999999996],[-58.444829999999968,-34.650999999999954],[-58.444629999999961,-34.651029999999935],[-58.444469999999967,-34.651039999999966],[-58.443689999999947,-34.651129999999966],[-58.443279999999959,-34.651149999999973],[-58.443179999999984,-34.651149999999973],[-58.441839999999956,-34.650869999999941],[-58.441269999999975,-34.650849999999934],[-58.440919999999949,-34.650829999999928],[-58.438839999999971,-34.650719999999978],[-58.434149999999931,-34.650489999999934],[-58.433829999999944,-34.650469999999984],[-58.433099999999968,-34.650409999999965],[-58.432059999999979,-34.650359999999978],[-58.431339999999977,-34.650349999999946],[-58.430889999999977,-34.650349999999946],[-58.430759999999964,-34.650349999999946],[-58.430389999999932,-34.65032999999994],[-58.428539999999941,-34.650229999999965],[-58.426279999999963,-34.650119999999959],[-58.425319999999942,-34.650109999999984],[-58.424979999999948,-34.650339999999971],[-58.424009999999953,-34.65101999999996],[-58.423429999999939,-34.651429999999948],[-58.422229999999956,-34.652329999999949],[-58.418259999999975,-34.655239999999935],[-58.418189999999981,-34.655309999999929],[-58.418109999999956,-34.655419999999935],[-58.416929999999979,-34.656559999999956],[-58.416629999999941,-34.656779999999969],[-58.416489999999953,-34.656839999999931],[-58.416499999999985,-34.657159999999976],[-58.41650999999996,-34.657359999999983],[-58.41659999999996,-34.658869999999979],[-58.416619999999966,-34.659039999999948],[-58.416649999999947,-34.659289999999942],[-58.416709999999966,-34.659749999999974],[-58.416719999999941,-34.659849999999949],[-58.416759999999954,-34.660129999999981],[-58.416859999999986,-34.660809999999969],[-58.416879999999935,-34.660939999999982],[-58.417059999999935,-34.661619999999971],[-58.417159999999967,-34.662139999999965],[-58.417229999999961,-34.662579999999934],[-58.41737999999998,-34.663219999999967],[-58.417439999999942,-34.663649999999961],[-58.417649999999981,-34.665039999999976],[-58.41710999999998,-34.668669999999963],[-58.414349999999956,-34.670769999999948],[-58.413519999999949,-34.671369999999968],[-58.412679999999966,-34.671979999999962],[-58.413459999999986,-34.672699999999963],[-58.414189999999962,-34.673399999999958],[-58.414949999999976,-34.674119999999959],[-58.41414999999995,-34.674669999999935],[-58.414049999999975,-34.674739999999929],[-58.413669999999968,-34.674619999999948],[-58.413319999999942,-34.676159999999982],[-58.41301999999996,-34.677379999999971],[-58.412779999999941,-34.678209999999979],[-58.412369999999953,-34.678549999999973],[-58.413419999999974,-34.678999999999974],[-58.414799999999957,-34.679649999999981],[-58.414059999999949,-34.680719999999951],[-58.413329999999974,-34.681729999999959],[-58.412949999999967,-34.682229999999947],[-58.412679999999966,-34.682639999999935],[-58.411959999999965,-34.683599999999956],[-58.411339999999939,-34.684489999999983],[-58.411216433999982,-34.684661090999953],[-58.410949999999957,-34.685029999999983],[-58.410469999999975,-34.685719999999947],[-58.409549999999967,-34.685279999999977],[-58.409249999999986,-34.685129999999958],[-58.408449999999959,-34.684689999999932],[-58.407489999999939,-34.683439999999962],[-58.404499999999985,-34.679759999999931],[-58.404319999999984,-34.679619999999943],[-58.404069999999933,-34.679569999999956],[-58.400899999999979,-34.677419999999984],[-58.398499999999956,-34.675809999999956],[-58.397979999999961,-34.675429999999949],[-58.397059999999954,-34.674599999999941],[-58.394519999999943,-34.672329999999931],[-58.394419999999968,-34.672409999999957],[-58.393869999999936,-34.672879999999964],[-58.393619999999942,-34.673089999999945],[-58.392619999999965,-34.672249999999963],[-58.391059999999982,-34.670949999999948],[-58.390769999999975,-34.67053999999996],[-58.390449999999987,-34.670259999999985],[-58.389209999999935,-34.66922999999997],[-58.388429999999971,-34.668549999999982],[-58.388009999999952,-34.66817999999995],[-58.387839999999983,-34.668029999999931],[-58.387499999999932,-34.667909999999949],[-58.385979999999961,-34.667389999999955],[-58.384899999999959,-34.667099999999948],[-58.384329999999977,-34.667049999999961],[-58.384029999999939,-34.666799999999967],[-58.383399999999938,-34.66626999999994],[-58.382209999999986,-34.665309999999977],[-58.381179999999972,-34.664479999999969],[-58.380079999999964,-34.66354999999993],[-58.379446576999953,-34.663026207999962],[-58.379039999999975,-34.662689999999941],[-58.377999999999986,-34.66187999999994],[-58.377039999999965,-34.66265999999996],[-58.376819999999952,-34.662669999999935],[-58.376759999999933,-34.66283999999996],[-58.376589999999965,-34.663329999999974],[-58.376419999999939,-34.663099999999929],[-58.376359999999977,-34.663009999999929],[-58.376259999999945,-34.662859999999966],[-58.375959999999964,-34.662419999999941],[-58.375689999999963,-34.662039999999934],[-58.375059999999962,-34.661099999999976],[-58.374709999999936,-34.660699999999963],[-58.374319999999955,-34.661329999999964],[-58.37361999999996,-34.661039999999957],[-58.372819999999933,-34.660709999999938],[-58.370919999999956,-34.660379999999975],[-58.370709999999974,-34.660089999999968],[-58.370539999999949,-34.659849999999949],[-58.370329999999967,-34.659549999999967],[-58.370049999999935,-34.659749999999974],[-58.369719999999973,-34.659999999999968],[-58.369459999999947,-34.660199999999975],[-58.367249999999956,-34.663089999999954],[-58.366449999999986,-34.664279999999962],[-58.365069999999946,-34.666489999999953],[-58.364879999999971,-34.666769999999929],[-58.364509999999939,-34.666539999999941],[-58.36197999999996,-34.664709999999957],[-58.361409999999978,-34.66432999999995],[-58.361049999999977,-34.664519999999982],[-58.358649999999955,-34.665759999999977],[-58.358299999999986,-34.665929999999946],[-58.35770999999994,-34.665209999999945],[-58.35478999999998,-34.66352999999998],[-58.354649999999936,-34.663449999999955],[-58.348659999999938,-34.660119999999949],[-58.348319999999944,-34.66056999999995],[-58.347989999999982,-34.660969999999963],[-58.347849999999937,-34.661159999999938],[-58.346499999999935,-34.662649999999928],[-58.344249999999931,-34.665319999999952],[-58.343999999999937,-34.665689999999984],[-58.342609999999979,-34.667739999999981],[-58.341929999999934,-34.668329999999969],[-58.341439999999977,-34.668699999999944],[-58.341199999999958,-34.668839999999932],[-58.337769999999978,-34.670869999999979],[-58.336209999999937,-34.67202999999995],[-58.33370999999994,-34.674069999999972],[-58.332329999999956,-34.675129999999967],[-58.330229999999972,-34.676639999999963],[-58.329339999999945,-34.677249999999958],[-58.328819999999951,-34.677539999999965],[-58.32765999999998,-34.678409999999928],[-58.326399999999978,-34.678889999999967],[-58.325269999999932,-34.67892999999998],[-58.324419999999975,-34.678949999999929],[-58.322709999999972,-34.679349999999943],[-58.320989999999938,-34.679879999999969],[-58.319319999999948,-34.680409999999938],[-58.315549999999973,-34.681569999999965],[-58.312289999999962,-34.682589999999948],[-58.311949999999968,-34.68268999999998],[-58.307739999999967,-34.683999999999969],[-58.296129999999948,-34.687509999999975],[-58.291129999999953,-34.688689999999951],[-58.288429999999948,-34.689709999999934],[-58.28705999999994,-34.690389999999979],[-58.283789999999954,-34.69250999999997],[-58.281849999999963,-34.69381999999996],[-58.279769999999985,-34.695329999999956],[-58.278209999999945,-34.696779999999933],[-58.277189999999962,-34.697979999999973],[-58.276419999999973,-34.698939999999936],[-58.275529999999947,-34.700089999999932],[-58.274059999999963,-34.701849999999979],[-58.272889999999961,-34.702879999999936],[-58.271379999999965,-34.703909999999951],[-58.269979999999975,-34.704629999999952],[-58.268209999999954,-34.705279999999959],[-58.264909999999986,-34.706039999999973],[-58.26279999999997,-34.706629999999961],[-58.260889999999961,-34.707349999999963],[-58.253269999999986,-34.711099999999931],[-58.25001999999995,-34.712429999999983],[-58.243249999999932,-34.714929999999981],[-58.241679999999974,-34.715399999999931],[-58.237949999999955,-34.716189999999983],[-58.235369999999932,-34.717019999999934],[-58.233409999999935,-34.717999999999961],[-58.231579999999951,-34.719299999999976],[-58.228019999999958,-34.722449999999981],[-58.219869999999958,-34.729709999999955],[-58.206949999999949,-34.741169999999954],[-58.192609999999945,-34.752149999999972],[-58.191379999999981,-34.753029999999967],[-58.186079999999947,-34.757079999999974],[-58.176229999999975,-34.764529999999979],[-58.166079999999965,-34.772249999999929],[-58.164789999999982,-34.773439999999937],[-58.164579999999944,-34.77365999999995],[-58.164299999999969,-34.773949999999957],[-58.163789999999949,-34.774369999999976],[-58.160819999999944,-34.776209999999935],[-58.15931999999998,-34.777339999999981],[-58.158759999999972,-34.777789999999982],[-58.155639999999948,-34.780129999999929],[-58.153049999999951,-34.782029999999963],[-58.150119999999959,-34.784019999999941],[-58.149889999999971,-34.784169999999961],[-58.146719999999959,-34.786239999999964],[-58.14549999999997,-34.787049999999965],[-58.144449999999949,-34.787729999999954],[-58.137099999999975,-34.792569999999955],[-58.133779999999945,-34.794969999999978],[-58.129669999999976,-34.798289999999952],[-58.126459999999952,-34.801209999999969],[-58.114919999999984,-34.811769999999967],[-58.110349999999983,-34.815519999999935],[-58.100149999999985,-34.822919999999954],[-58.090979999999945,-34.829299999999932],[-58.086029999999937,-34.831929999999943],[-58.076679999999953,-34.836059999999975],[-58.074039999999968,-34.83720999999997],[-58.073259999999948,-34.837549999999965],[-58.071509999999932,-34.838319999999953],[-58.070129999999949,-34.838949999999954],[-58.068709999999953,-34.839579999999955],[-58.014779999999973,-34.863389999999981],[-58.010829999999942,-34.864809999999977],[-58.007059999999967,-34.865809999999954],[-58.000509999999963,-34.867419999999981],[-57.999199999999973,-34.867739999999969],[-57.983289999999954,-34.871679999999969],[-57.974799999999959,-34.873819999999967],[-57.973359999999957,-34.874269999999967],[-57.971479999999985,-34.875079999999969],[-57.969539999999938,-34.876169999999945],[-57.968139999999948,-34.877149999999972],[-57.964609999999936,-34.879669999999976],[-57.963229999999953,-34.880459999999971],[-57.962429999999983,-34.880789999999934],[-57.960139999999967,-34.881329999999934],[-57.95915999999994,-34.88149999999996],[-57.957699999999932,-34.88200999999998],[-57.957199999999943,-34.882619999999974],[-57.957049999999981,-34.883089999999982],[-57.957019999999943,-34.883579999999938],[-57.956959999999981,-34.884499999999946],[-57.956929999999943,-34.885119999999972],[-57.956879999999956,-34.885819999999967],[-57.956799999999987,-34.887479999999982],[-57.957009999999968,-34.888029999999958],[-57.957529999999963,-34.888349999999946],[-57.957609999999931,-34.888709999999946],[-57.957529999999963,-34.888929999999959],[-57.957019999999943,-34.889279999999928],[-57.956879999999956,-34.889319999999941],[-57.956389999999942,-34.889259999999979],[-57.956119999999942,-34.889049999999941],[-57.954759999999965,-34.888299999999958],[-57.953479999999956,-34.887579999999957],[-57.953159999999968,-34.887809999999945],[-57.949639999999931,-34.890399999999943],[-57.947389999999984,-34.892069999999933],[-57.947269999999946,-34.892159999999933],[-57.941659999999956,-34.896349999999984],[-57.934869999999933,-34.901379999999961],[-57.93411999999995,-34.901939999999968],[-57.933959999999956,-34.902259999999956],[-57.933959999999956,-34.902329999999949],[-57.933749999999975,-34.902529999999956],[-57.933639999999968,-34.902499999999975],[-57.933319999999981,-34.902579999999944],[-57.932009999999934,-34.903549999999939],[-57.927469999999971,-34.906889999999976],[-57.927329999999984,-34.907399999999939],[-57.927429999999958,-34.907719999999983],[-57.927209999999945,-34.907969999999978],[-57.926899999999932,-34.907989999999984],[-57.926689999999951,-34.907909999999958],[-57.925909999999988,-34.90811999999994],[-57.925789999999949,-34.908149999999978],[-57.919959999999946,-34.912439999999947],[-57.916499999999985,-34.915009999999938],[-57.913139999999942,-34.917529999999942],[-57.904889999999966,-34.923739999999952],[-57.904719999999941,-34.924079999999947],[-57.903789999999958,-34.924779999999942],[-57.902469999999937,-34.925749999999937],[-57.901159999999948,-34.926729999999964],[-57.900479999999959,-34.927249999999958],[-57.900139999999965,-34.927509999999984],[-57.900139999999965,-34.927859999999953],[-57.900289999999984,-34.92799999999994],[-57.900169999999946,-34.928159999999934],[-57.900119999999959,-34.928169999999966],[-57.899979999999971,-34.928339999999935],[-57.900119999999959,-34.929469999999981],[-57.900299999999959,-34.930309999999963],[-57.90032999999994,-34.930429999999944],[-57.900529999999947,-34.93148999999994],[-57.90074999999996,-34.93268999999998],[-57.901189999999986,-34.934349999999938],[-57.901239999999973,-34.934559999999976],[-57.900799999999947,-34.934869999999933],[-57.900549999999953,-34.935049999999933],[-57.898629999999969,-34.936459999999954],[-57.899479999999983,-34.937239999999974],[-57.90032999999994,-34.938009999999963],[-57.90119999999996,-34.938789999999983],[-57.902089999999987,-34.939609999999959],[-57.903799999999933,-34.941179999999974],[-57.902979999999957,-34.941799999999944],[-57.90362457599997,-34.942400121999981]]]}},{"attributes":{"ObjectID":2,"Name":"Chofer5Insitu_7","FirstStopID":2,"LastStopID":27,"StopCount":12,"Total_TravelTime":109.56364042361592,"Total_Kilometers":52.924344643701872,"Total_Miles":32.885663129636619,"TotalWait_TravelTime":0,"TotalViolation_TravelTime":0,"StartTime":1470355200000,"EndTime":1470361773819,"StartTimeUTC":1470366000000,"EndTimeUTC":1470372573818,"Shape_Length":0.53829547426819935},"geometry":{"paths":[[[-58.377969061999977,-34.592843030999973],[-58.378579999999943,-34.592889999999954],[-58.380119999999977,-34.592859999999973],[-58.381639999999948,-34.592859999999973],[-58.381969999999967,-34.592889999999954],[-58.382109999999955,-34.592889999999954],[-58.382219999999961,-34.592889999999954],[-58.38227999999998,-34.59325999999993],[-58.382399999999961,-34.593819999999937],[-58.382489999999962,-34.594349999999963],[-58.382489999999962,-34.595229999999958],[-58.382359999999949,-34.595839999999953],[-58.382289999999955,-34.596469999999954],[-58.382259999999974,-34.596799999999973],[-58.382169999999974,-34.597649999999931],[-58.382089999999948,-34.598709999999983],[-58.382059999999967,-34.599059999999952],[-58.38200999999998,-34.600019999999972],[-58.381929999999954,-34.601109999999949],[-58.381909999999948,-34.601399999999956],[-58.381889999999942,-34.602599999999939],[-58.381889999999942,-34.602829999999983],[-58.381929999999954,-34.602979999999945],[-58.381949999999961,-34.603029999999933],[-58.382059999999967,-34.603219999999965],[-58.382229999999936,-34.60376999999994],[-58.38209999999998,-34.60409999999996],[-58.381839999999954,-34.604539999999929],[-58.381749999999954,-34.604719999999929],[-58.381749999999954,-34.60496999999998],[-58.381639999999948,-34.606139999999982],[-58.38158999999996,-34.607379999999978],[-58.381559999999979,-34.607929999999953],[-58.381529999999941,-34.60845999999998],[-58.381539999999973,-34.608699999999942],[-58.381539999999973,-34.609059999999943],[-58.381969999999967,-34.609089999999981],[-58.381969999999967,-34.60943999999995],[-58.381939999999986,-34.609679999999969],[-58.381889999999942,-34.610859999999946],[-58.381599999999935,-34.610839999999939],[-58.381449999999973,-34.610829999999964],[-58.38131999999996,-34.610819999999933],[-58.381159999999966,-34.610809999999958],[-58.381049999999959,-34.610809999999958],[-58.38080999999994,-34.610779999999977],[-58.380649999999946,-34.610759999999971],[-58.379119999999944,-34.610639999999933],[-58.379029999999943,-34.611729999999966],[-58.379044928999974,-34.612603325999942],[-58.37904999999995,-34.612899999999968],[-58.379009999999937,-34.614119999999957],[-58.380469999999946,-34.614199999999983],[-58.380819999999972,-34.614239999999938],[-58.380929999999978,-34.61424999999997],[-58.381119999999953,-34.614269999999976],[-58.381249999999966,-34.614279999999951],[-58.381219999999985,-34.615279999999984],[-58.381179999999972,-34.616479999999967],[-58.381159999999966,-34.617209999999943],[-58.381149999999934,-34.617669999999976],[-58.381529999999941,-34.617659999999944],[-58.381819999999948,-34.617669999999976],[-58.391249999999957,-34.618129999999951],[-58.391709999999932,-34.618199999999945],[-58.392679999999984,-34.618259999999964],[-58.397509999999954,-34.618479999999977],[-58.403449999999964,-34.618839999999977],[-58.406389999999988,-34.61943999999994],[-58.410819999999944,-34.620359999999948],[-58.412539999999979,-34.620689999999968],[-58.416109999999946,-34.620979999999975],[-58.417269999999974,-34.621049999999968],[-58.418969999999945,-34.621159999999975],[-58.424069999999972,-34.621519999999975],[-58.427809999999965,-34.622099999999932],[-58.428299999999979,-34.622159999999951],[-58.432829999999967,-34.622849999999971],[-58.436919999999986,-34.62328999999994],[-58.441899999999976,-34.622849999999971],[-58.443589999999972,-34.623069999999984],[-58.444979999999987,-34.623839999999973],[-58.44566999999995,-34.624259999999936],[-58.446509999999932,-34.624759999999981],[-58.446049999999957,-34.62588999999997],[-58.445591515999979,-34.626971330999936],[-58.445519999999988,-34.62713999999994],[-58.447089999999946,-34.627429999999947],[-58.448429999999973,-34.62773999999996],[-58.449329999999975,-34.627909999999929],[-58.450409999999977,-34.628109999999936],[-58.451479999999947,-34.628309999999942],[-58.452179999999942,-34.628439999999955],[-58.45256999999998,-34.62851999999998],[-58.45414999999997,-34.628909999999962],[-58.454449999999952,-34.628979999999956],[-58.454619999999977,-34.629009999999937],[-58.45545999999996,-34.629299999999944],[-58.456039999999973,-34.62949999999995],[-58.456529999999987,-34.629669999999976],[-58.457599999999957,-34.629999999999939],[-58.458749999999952,-34.630379999999946],[-58.460079999999948,-34.630799999999965],[-58.461729999999932,-34.631299999999953],[-58.463109999999972,-34.631709999999941],[-58.463579999999979,-34.630499999999984],[-58.463819999999942,-34.629879999999957],[-58.46411999999998,-34.629279999999937],[-58.464379999999949,-34.628639999999962],[-58.464649999999949,-34.628049999999973],[-58.464849999999956,-34.627639999999928],[-58.464929999999981,-34.62746999999996],[-58.465179999999975,-34.626849999999934],[-58.466599999999971,-34.627249999999947],[-58.467404337999938,-34.627489458999946],[-58.467909999999961,-34.627639999999928],[-58.469349999999963,-34.62806999999998],[-58.469769999999983,-34.626999999999953],[-58.470309999999984,-34.625939999999957],[-58.468899999999962,-34.625489999999957],[-58.467559999999935,-34.625079999999969],[-58.462629999999933,-34.623449999999934],[-58.462219999999945,-34.623309999999947],[-58.459959999999967,-34.622579999999971],[-58.459559999999954,-34.622459999999933],[-58.456859999999949,-34.621479999999963],[-58.456099999999935,-34.621199999999931],[-58.45503999999994,-34.620829999999955],[-58.450609999999983,-34.619049999999959],[-58.450219999999945,-34.618879999999933],[-58.448939999999936,-34.618299999999977],[-58.448009999999954,-34.617889999999932],[-58.446989999999971,-34.617629999999963],[-58.446609999999964,-34.617549999999937],[-58.445599999999956,-34.61731999999995],[-58.442699999999945,-34.616109999999935],[-58.442409999999938,-34.615979999999979],[-58.442279999999982,-34.615959999999973],[-58.441849999999931,-34.615959999999973],[-58.441929999999957,-34.615689999999972],[-58.441099999999949,-34.615069999999946],[-58.440709999999967,-34.614839999999958],[-58.440589999999986,-34.614799999999946],[-58.440689999999961,-34.614449999999977],[-58.440799999999967,-34.614179999999976],[-58.440889999999968,-34.613899999999944],[-58.441219999999987,-34.613249999999937],[-58.441369999999949,-34.61295999999993],[-58.442869999999971,-34.610909999999933],[-58.444409999999948,-34.60901999999993],[-58.444899999999961,-34.608389999999929],[-58.445079999999962,-34.60812999999996],[-58.445319999999981,-34.607779999999934],[-58.445469999999943,-34.60761999999994],[-58.445689999999956,-34.60734999999994],[-58.445819999999969,-34.607159999999965],[-58.445859999999982,-34.607099999999946],[-58.446889999999939,-34.605779999999982],[-58.447219999999959,-34.605429999999956],[-58.446759999999983,-34.605109999999968],[-58.442809999999952,-34.602399999999932],[-58.442529999999977,-34.602219999999932],[-58.442429999999945,-34.602139999999963],[-58.442379999999957,-34.60209999999995],[-58.442259999999976,-34.601979999999969],[-58.439149999999984,-34.600099999999941],[-58.438789999999983,-34.599839999999972],[-58.438359999999932,-34.59955999999994],[-58.436639999999954,-34.598439999999982],[-58.435559999999953,-34.597779999999943],[-58.434469999999976,-34.597079999999949],[-58.435559999999953,-34.597779999999943],[-58.435965259999932,-34.59734679099995],[-58.436429999999973,-34.596849999999961],[-58.437289999999962,-34.595909999999947],[-58.436199999999985,-34.595239999999933],[-58.435659999999984,-34.59490999999997],[-58.435579999999959,-34.594859999999983],[-58.435109999999952,-34.594559999999944],[-58.435959999999966,-34.593659999999943],[-58.436215745999959,-34.593394024999952],[-58.436709999999948,-34.59287999999998],[-58.437459999999987,-34.59203999999994],[-58.437999999999931,-34.591449999999952],[-58.438289999999938,-34.591629999999952],[-58.439139999999952,-34.591069999999945],[-58.438769999999977,-34.590679999999963],[-58.438559999999939,-34.590129999999931],[-58.438119999999969,-34.588929999999948],[-58.438539999999932,-34.588669999999979],[-58.44450999999998,-34.584629999999947],[-58.444809999999961,-34.584549999999979],[-58.446419999999932,-34.583819999999946],[-58.448519999999974,-34.582949999999983],[-58.448829999999987,-34.582749999999976],[-58.448769999999968,-34.582419999999956],[-58.448529999999948,-34.581719999999962],[-58.448439999999948,-34.581519999999955],[-58.450329999999951,-34.580789999999979],[-58.450589999999977,-34.580689999999947],[-58.451259999999934,-34.580449999999985],[-58.451689999999985,-34.580299999999966],[-58.453029999999956,-34.579869999999971],[-58.453579999999931,-34.579699999999946],[-58.45730999999995,-34.578579999999931],[-58.458519999999965,-34.578399999999931],[-58.458769999999959,-34.578389999999956],[-58.459659999999985,-34.578349999999944],[-58.459809999999948,-34.578339999999969],[-58.46026999999998,-34.578199999999981],[-58.460059999999942,-34.577999999999975],[-58.459869999999967,-34.576869999999928],[-58.459839999999986,-34.574979999999982],[-58.459839999999986,-34.574229999999943],[-58.46008999999998,-34.574109999999962],[-58.460499999999968,-34.573939999999936],[-58.461559999999963,-34.573469999999929],[-58.461689999999976,-34.573409999999967],[-58.463139999999953,-34.571809999999971],[-58.464139999999986,-34.570649999999944],[-58.463079999999934,-34.570029999999974],[-58.462992895999946,-34.570136459999958],[-58.462089999999932,-34.571239999999932],[-58.461389999999938,-34.572029999999984],[-58.460879999999975,-34.572599999999966],[-58.461689999999976,-34.573409999999967],[-58.463389999999947,-34.575059999999951],[-58.464249999999936,-34.575509999999952],[-58.464839999999981,-34.575849999999946],[-58.465039999999988,-34.575959999999952],[-58.465909999999951,-34.57645999999994],[-58.465819999999951,-34.576539999999966],[-58.465680874999975,-34.57646004299994],[-58.464949999999988,-34.576039999999978],[-58.465039999999988,-34.575959999999952],[-58.469479999999976,-34.578559999999982],[-58.474049999999977,-34.577579999999955],[-58.475619999999935,-34.577219999999954],[-58.477399999999932,-34.575889999999958],[-58.480729999999937,-34.573549999999955],[-58.482549999999947,-34.572109999999952],[-58.483229999999935,-34.571519999999964],[-58.483499999999935,-34.571279999999945],[-58.484129999999936,-34.570819999999969],[-58.484639999999956,-34.57048999999995],[-58.484999999999957,-34.570209999999975],[-58.485679999999945,-34.569649999999967],[-58.485799999999983,-34.569559999999967],[-58.486589999999978,-34.568919999999935],[-58.486689999999953,-34.568839999999966],[-58.487359999999967,-34.568239999999946],[-58.487859999999955,-34.568509999999947],[-58.48915999999997,-34.569229999999948],[-58.490289999999959,-34.569819999999936],[-58.491379999999936,-34.570409999999981],[-58.493089999999938,-34.571309999999983],[-58.497739999999965,-34.573749999999961],[-58.499589999999955,-34.574719999999957],[-58.50037999999995,-34.575129999999945],[-58.500639999999976,-34.575259999999957],[-58.500999999999976,-34.575019999999938],[-58.501479999999958,-34.574659999999938],[-58.501719999999978,-34.574469999999963],[-58.501479999999958,-34.574659999999938],[-58.50186999999994,-34.574919999999963],[-58.503009999999961,-34.575619999999958],[-58.503089999999986,-34.575669999999946],[-58.504159999999956,-34.576319999999953],[-58.505035127999975,-34.576854369999978],[-58.505289999999945,-34.577009999999973],[-58.505929999999978,-34.576299999999947],[-58.506579999999985,-34.575589999999977],[-58.507719999999949,-34.57627999999994],[-58.508279999999957,-34.576599999999928],[-58.508869999999945,-34.576949999999954],[-58.51001999999994,-34.577629999999942],[-58.513169999999946,-34.579499999999939],[-58.513639999999953,-34.57976999999994],[-58.51419999999996,-34.580919999999935],[-58.514409999999941,-34.581049999999948],[-58.515199999999936,-34.580969999999979],[-58.515609999999981,-34.581049999999948],[-58.515969999999982,-34.581259999999929],[-58.516089999999963,-34.58132999999998],[-58.516349999999932,-34.581489999999974],[-58.519129999999961,-34.583159999999964],[-58.520199999999932,-34.582689999999957],[-58.521239999999977,-34.582199999999943],[-58.52234999999996,-34.581719999999962],[-58.525089999999977,-34.58045999999996],[-58.525499999999965,-34.58072999999996],[-58.526789999999949,-34.58159999999998],[-58.528059999999982,-34.582449999999938],[-58.528709999999933,-34.582859999999982],[-58.529349999999965,-34.583299999999952],[-58.530149999999935,-34.58397999999994],[-58.530899999999974,-34.584639999999979],[-58.530772977999959,-34.584746343999939],[-58.53046999999998,-34.58499999999998],[-58.529889999999966,-34.585439999999949],[-58.52899999999994,-34.58615999999995],[-58.528459999999939,-34.586569999999938],[-58.527669999999944,-34.587189999999964],[-58.527189999999962,-34.587629999999933],[-58.526959999999974,-34.587899999999934],[-58.526089999999954,-34.587359999999933],[-58.525859999999966,-34.587229999999977],[-58.520459999999957,-34.588899999999967],[-58.519869999999969,-34.589039999999954],[-58.519409999999937,-34.589169999999967],[-58.519179999999949,-34.589249999999936],[-58.518979999999942,-34.589309999999955],[-58.518769999999961,-34.589369999999974],[-58.518629999999973,-34.58940999999993],[-58.518269999999973,-34.58949999999993],[-58.518059999999934,-34.589059999999961],[-58.517319999999984,-34.586619999999982],[-58.516899999999964,-34.585749999999962],[-58.516779999999983,-34.585489999999936],[-58.516699999999958,-34.585309999999936],[-58.515439999999955,-34.582649999999944],[-58.514909999999986,-34.58152999999993],[-58.514869999999974,-34.581449999999961],[-58.514829999999961,-34.581369999999936],[-58.514719999999954,-34.581109999999967],[-58.514639999999986,-34.580939999999941],[-58.514509999999973,-34.580679999999973],[-58.512729999999976,-34.576869999999928],[-58.512299999999982,-34.575979999999959],[-58.511459999999943,-34.574149999999975],[-58.511079999999936,-34.573339999999973],[-58.51043999999996,-34.57197999999994],[-58.509459999999933,-34.56979999999993],[-58.507929999999988,-34.567059999999969],[-58.507819999999981,-34.566739999999982],[-58.507439999999974,-34.565789999999936],[-58.506529999999941,-34.56365999999997],[-58.506479999999954,-34.563539999999932],[-58.503679999999974,-34.557519999999954],[-58.503619999999955,-34.557379999999966],[-58.503229999999974,-34.556529999999952],[-58.502999999999986,-34.556059999999945],[-58.502919999999961,-34.555859999999939],[-58.502859999999941,-34.555719999999951],[-58.502599999999973,-34.555279999999982],[-58.501799999999946,-34.553579999999954],[-58.501119999999958,-34.552129999999977],[-58.500369999999975,-34.550789999999949],[-58.499149999999986,-34.549619999999948],[-58.49721999999997,-34.548559999999952],[-58.496789999999976,-34.548359999999946],[-58.496649999999931,-34.548299999999983],[-58.496509999999944,-34.548249999999939],[-58.493479999999977,-34.546929999999975],[-58.49327999999997,-34.546829999999943],[-58.490709999999979,-34.545689999999979],[-58.488619999999969,-34.544729999999959],[-58.487259999999935,-34.544129999999939],[-58.486759999999947,-34.543899999999951],[-58.486229999999978,-34.54368999999997],[-58.486029999999971,-34.543599999999969],[-58.48381999999998,-34.542629999999974],[-58.48363999999998,-34.542549999999949],[-58.482099999999946,-34.541899999999941],[-58.480509999999981,-34.541189999999972],[-58.478479999999934,-34.540339999999958],[-58.475919999999974,-34.538969999999949],[-58.475819999999942,-34.538919999999962],[-58.472619999999949,-34.537609999999972],[-58.471389999999985,-34.537109999999984],[-58.471189999999979,-34.537019999999984],[-58.470729999999946,-34.536819999999977],[-58.469439999999963,-34.536269999999945],[-58.46805999999998,-34.535809999999969],[-58.46703999999994,-34.535789999999963],[-58.466759999999965,-34.53589999999997],[-58.466529999999977,-34.536299999999983],[-58.465199999999982,-34.538539999999955],[-58.465069999999969,-34.538749999999936],[-58.464719999999943,-34.539319999999975],[-58.464539999999943,-34.53959999999995],[-58.463839999999948,-34.540749999999946],[-58.463589999999954,-34.541159999999934],[-58.462989999999934,-34.541789999999935],[-58.46264999999994,-34.542119999999954],[-58.462139999999977,-34.542599999999936],[-58.461749999999938,-34.542969999999968],[-58.460139999999967,-34.544419999999946],[-58.459539999999947,-34.544969999999978],[-58.45924999999994,-34.545179999999959],[-58.458029999999951,-34.54613999999998],[-58.457919999999945,-34.54622999999998],[-58.457609999999931,-34.546469999999943],[-58.457009999999968,-34.54693999999995],[-58.456639999999936,-34.547259999999937],[-58.456379999999967,-34.547469999999976],[-58.455089999999984,-34.548629999999946],[-58.454799999999977,-34.548869999999965],[-58.454499999999939,-34.549109999999985],[-58.454339999999945,-34.549269999999979],[-58.454199999999958,-34.549399999999935],[-58.454069999999945,-34.549529999999947],[-58.453859999999963,-34.549699999999973],[-58.45336999999995,-34.550149999999974],[-58.453219999999988,-34.550299999999936],[-58.453069999999968,-34.550499999999943],[-58.452849999999955,-34.550749999999937],[-58.452589999999987,-34.55105999999995],[-58.451399999999978,-34.552439999999933],[-58.451299999999947,-34.552559999999971],[-58.451049999999952,-34.552849999999978],[-58.450959999999952,-34.552949999999953],[-58.450719999999933,-34.553219999999953],[-58.450379999999939,-34.553629999999941],[-58.45011999999997,-34.553919999999948],[-58.44933999999995,-34.554849999999931],[-58.448690857999964,-34.555623976999982],[-58.448559999999986,-34.55577999999997],[-58.448299999999961,-34.556069999999977],[-58.448009999999954,-34.55639999999994],[-58.447509999999966,-34.55693999999994],[-58.447369999999978,-34.557109999999966],[-58.447219999999959,-34.557279999999935],[-58.446559999999977,-34.558029999999974],[-58.446319999999957,-34.558299999999974],[-58.44584999999995,-34.558859999999981],[-58.445549999999969,-34.559199999999976],[-58.445259999999962,-34.559549999999945],[-58.443749999999966,-34.561309999999935],[-58.443689999999947,-34.561379999999929],[-58.443539999999985,-34.561529999999948],[-58.443259999999952,-34.561759999999936],[-58.442649999999958,-34.56207999999998],[-58.441739999999982,-34.56227999999993],[-58.441359999999975,-34.56236999999993],[-58.43954999999994,-34.562649999999962],[-58.43918999999994,-34.562709999999981],[-58.437799999999982,-34.563109999999938],[-58.437269999999955,-34.563289999999938],[-58.436789999999974,-34.563499999999976],[-58.43647999999996,-34.563669999999945],[-58.436149999999941,-34.563889999999958],[-58.435869999999966,-34.564049999999952],[-58.433339999999987,-34.565599999999961],[-58.431219999999939,-34.566809999999975],[-58.42781999999994,-34.568749999999966],[-58.427179999999964,-34.569109999999966],[-58.426809999999932,-34.569319999999948],[-58.42447999999996,-34.570629999999937],[-58.424029999999959,-34.57084999999995],[-58.423809999999946,-34.571029999999951],[-58.423299999999983,-34.571229999999957],[-58.42262999999997,-34.57144999999997],[-58.419269999999983,-34.572989999999947],[-58.417069999999967,-34.573969999999974],[-58.416609999999935,-34.57418999999993],[-58.415889999999933,-34.574619999999982],[-58.415379999999971,-34.574999999999932],[-58.414949999999976,-34.575249999999983],[-58.414229999999975,-34.575309999999945],[-58.413519999999949,-34.575679999999977],[-58.411409999999933,-34.576679999999953],[-58.411089999999945,-34.576819999999941],[-58.410909999999944,-34.576889999999935],[-58.410429999999963,-34.577099999999973],[-58.409949999999981,-34.577319999999929],[-58.408979999999985,-34.577739999999949],[-58.408189999999934,-34.578079999999943],[-58.407949999999971,-34.57818999999995],[-58.407239999999945,-34.578539999999975],[-58.406289999999956,-34.579209999999932],[-58.403529999999932,-34.581459999999936],[-58.399329999999964,-34.582769999999982],[-58.397239999999954,-34.583039999999983],[-58.395299999999963,-34.583659999999952],[-58.392429999999933,-34.584549999999979],[-58.391679999999951,-34.584779999999967],[-58.391159999999957,-34.584929999999929],[-58.390569999999968,-34.585019999999929],[-58.389539999999954,-34.585039999999935],[-58.388589999999965,-34.585249999999974],[-58.387079999999969,-34.585999999999956],[-58.386429999999962,-34.586329999999975],[-58.385899999999936,-34.586609999999951],[-58.385639999999967,-34.586739999999963],[-58.385339999999985,-34.586889999999983],[-58.385049999999978,-34.587039999999945],[-58.383919999999932,-34.58773999999994],[-58.382329999999968,-34.588549999999941],[-58.381909999999948,-34.588769999999954],[-58.381659999999954,-34.588869999999929],[-58.381459999999947,-34.588969999999961],[-58.38122999999996,-34.589089999999942],[-58.38089999999994,-34.589269999999942],[-58.380489999999952,-34.58949999999993],[-58.379059999999981,-34.590329999999938],[-58.376679999999965,-34.591889999999978],[-58.377069999999947,-34.592849999999942],[-58.377969061999977,-34.592843030999973]]]}}]}</textarea>
    <input type="hidden" name="json_stops" id="json_stops" value="{&quot;fieldAliases&quot;:{&quot;ObjectID&quot;:&quot;ObjectID&quot;,&quot;Name&quot;:&quot;Name&quot;,&quot;RouteName&quot;:&quot;RouteName&quot;,&quot;Sequence&quot;:&quot;Sequence&quot;,&quot;TimeWindowStart&quot;:&quot;TimeWindowStart&quot;,&quot;TimeWindowEnd&quot;:&quot;TimeWindowEnd&quot;,&quot;ArriveCurbApproach&quot;:&quot;ArriveCurbApproach&quot;,&quot;DepartCurbApproach&quot;:&quot;DepartCurbApproach&quot;,&quot;SourceID&quot;:&quot;SourceID&quot;,&quot;SourceOID&quot;:&quot;SourceOID&quot;,&quot;PosAlong&quot;:&quot;PosAlong&quot;,&quot;SideOfEdge&quot;:&quot;SideOfEdge&quot;,&quot;CurbApproach&quot;:&quot;CurbApproach&quot;,&quot;Status&quot;:&quot;Status&quot;,&quot;Attr_Minutes&quot;:&quot;Attr_Minutes&quot;,&quot;Attr_TravelTime&quot;:&quot;Attr_TravelTime&quot;,&quot;Attr_Miles&quot;:&quot;Attr_Miles&quot;,&quot;Attr_Kilometers&quot;:&quot;Attr_Kilometers&quot;,&quot;Attr_TimeAt1KPH&quot;:&quot;Attr_TimeAt1KPH&quot;,&quot;Attr_WalkTime&quot;:&quot;Attr_WalkTime&quot;,&quot;Attr_TruckTravelTime&quot;:&quot;Attr_TruckTravelTime&quot;,&quot;Cumul_TravelTime&quot;:&quot;Cumul_TravelTime&quot;,&quot;Cumul_Kilometers&quot;:&quot;Cumul_Kilometers&quot;,&quot;Cumul_Miles&quot;:&quot;Cumul_Miles&quot;},&quot;geometryType&quot;:&quot;esriGeometryPoint&quot;,&quot;spatialReference&quot;:{&quot;wkid&quot;:4326,&quot;latestWkid&quot;:4326},&quot;features&quot;:[{&quot;attributes&quot;:{&quot;ObjectID&quot;:1,&quot;Name&quot;:&quot;CABOMariaEulalia_1113&quot;,&quot;RouteName&quot;:&quot;Chofer7Insitu_9&quot;,&quot;Sequence&quot;:1,&quot;TimeWindowStart&quot;:null,&quot;TimeWindowEnd&quot;:null,&quot;ArriveCurbApproach&quot;:null,&quot;DepartCurbApproach&quot;:1,&quot;SourceID&quot;:1,&quot;SourceOID&quot;:1402114,&quot;PosAlong&quot;:0.6523641409647889,&quot;SideOfEdge&quot;:1,&quot;CurbApproach&quot;:0,&quot;Status&quot;:0,&quot;Attr_Minutes&quot;:0,&quot;Attr_TravelTime&quot;:0,&quot;Attr_Miles&quot;:0,&quot;Attr_Kilometers&quot;:0,&quot;Attr_TimeAt1KPH&quot;:0,&quot;Attr_WalkTime&quot;:0,&quot;Attr_TruckTravelTime&quot;:0,&quot;Cumul_TravelTime&quot;:0,&quot;Cumul_Kilometers&quot;:0,&quot;Cumul_Miles&quot;:0},&quot;geometry&quot;:{&quot;x&quot;:-58.586243999999965,&quot;y&quot;:-34.551129999999944}},{&quot;attributes&quot;:{&quot;ObjectID&quot;:2,&quot;Name&quot;:&quot;PISANOPascual_1076&quot;,&quot;RouteName&quot;:&quot;Chofer7Insitu_9&quot;,&quot;Sequence&quot;:2,&quot;TimeWindowStart&quot;:null,&quot;TimeWindowEnd&quot;:null,&quot;ArriveCurbApproach&quot;:2,&quot;DepartCurbApproach&quot;:2,&quot;SourceID&quot;:1,&quot;SourceOID&quot;:1326073,&quot;PosAlong&quot;:0.6880064946900538,&quot;SideOfEdge&quot;:2,&quot;CurbApproach&quot;:0,&quot;Status&quot;:0,&quot;Attr_Minutes&quot;:0,&quot;Attr_TravelTime&quot;:0,&quot;Attr_Miles&quot;:0,&quot;Attr_Kilometers&quot;:0,&quot;Attr_TimeAt1KPH&quot;:0,&quot;Attr_WalkTime&quot;:0,&quot;Attr_TruckTravelTime&quot;:0,&quot;Cumul_TravelTime&quot;:36.899695427466256,&quot;Cumul_Kilometers&quot;:20.5922061722754,&quot;Cumul_Miles&quot;:12.795403700063755},&quot;geometry&quot;:{&quot;x&quot;:-58.559508999999935,&quot;y&quot;:-34.67299299999996}},{&quot;attributes&quot;:{&quot;ObjectID&quot;:3,&quot;Name&quot;:&quot;GROETZNERMyriamRomina_1085&quot;,&quot;RouteName&quot;:&quot;Chofer7Insitu_9&quot;,&quot;Sequence&quot;:13,&quot;TimeWindowStart&quot;:null,&quot;TimeWindowEnd&quot;:null,&quot;ArriveCurbApproach&quot;:1,&quot;DepartCurbApproach&quot;:1,&quot;SourceID&quot;:1,&quot;SourceOID&quot;:1338351,&quot;PosAlong&quot;:0.597645731948751,&quot;SideOfEdge&quot;:2,&quot;CurbApproach&quot;:0,&quot;Status&quot;:0,&quot;Attr_Minutes&quot;:0,&quot;Attr_TravelTime&quot;:0,&quot;Attr_Miles&quot;:0,&quot;Attr_Kilometers&quot;:0,&quot;Attr_TimeAt1KPH&quot;:0,&quot;Attr_WalkTime&quot;:0,&quot;Attr_TruckTravelTime&quot;:0,&quot;Cumul_TravelTime&quot;:142.8017409006908,&quot;Cumul_Kilometers&quot;:92.83481451032753,&quot;Cumul_Miles&quot;:57.684879373413985},&quot;geometry&quot;:{&quot;x&quot;:-58.51448999999997,&quot;y&quot;:-34.66655999999995}},{&quot;attributes&quot;:{&quot;ObjectID&quot;:4,&quot;Name&quot;:&quot;TAIAHSara_1015&quot;,&quot;RouteName&quot;:&quot;Chofer7Insitu_9&quot;,&quot;Sequence&quot;:12,&quot;TimeWindowStart&quot;:null,&quot;TimeWindowEnd&quot;:null,&quot;ArriveCurbApproach&quot;:1,&quot;DepartCurbApproach&quot;:1,&quot;SourceID&quot;:1,&quot;SourceOID&quot;:1337905,&quot;PosAlong&quot;:0.31096960425498427,&quot;SideOfEdge&quot;:1,&quot;CurbApproach&quot;:0,&quot;Status&quot;:0,&quot;Attr_Minutes&quot;:0,&quot;Attr_TravelTime&quot;:0,&quot;Attr_Miles&quot;:0,&quot;Attr_Kilometers&quot;:0,&quot;Attr_TimeAt1KPH&quot;:0,&quot;Attr_WalkTime&quot;:0,&quot;Attr_TruckTravelTime&quot;:0,&quot;Cumul_TravelTime&quot;:137.80065530933956,&quot;Cumul_Kilometers&quot;:90.9428732169896,&quot;Cumul_Miles&quot;:56.509281556329555},&quot;geometry&quot;:{&quot;x&quot;:-58.51620399999996,&quot;y&quot;:-34.677809999999965}},{&quot;attributes&quot;:{&quot;ObjectID&quot;:5,&quot;Name&quot;:&quot;BRANDARIZRuben_1020&quot;,&quot;RouteName&quot;:&quot;Chofer7Insitu_9&quot;,&quot;Sequence&quot;:14,&quot;TimeWindowStart&quot;:null,&quot;TimeWindowEnd&quot;:null,&quot;ArriveCurbApproach&quot;:1,&quot;DepartCurbApproach&quot;:1,&quot;SourceID&quot;:1,&quot;SourceOID&quot;:1345208,&quot;PosAlong&quot;:0.5177293122326773,&quot;SideOfEdge&quot;:1,&quot;CurbApproach&quot;:0,&quot;Status&quot;:0,&quot;Attr_Minutes&quot;:0,&quot;Attr_TravelTime&quot;:0,&quot;Attr_Miles&quot;:0,&quot;Attr_Kilometers&quot;:0,&quot;Attr_TimeAt1KPH&quot;:0,&quot;Attr_WalkTime&quot;:0,&quot;Attr_TruckTravelTime&quot;:0,&quot;Cumul_TravelTime&quot;:152.38651968562576,&quot;Cumul_Kilometers&quot;:98.34876793696797,&quot;Cumul_Miles&quot;:61.11109118806671},&quot;geometry&quot;:{&quot;x&quot;:-58.52948203699998,&quot;y&quot;:-34.62403804099995}},{&quot;attributes&quot;:{&quot;ObjectID&quot;:6,&quot;Name&quot;:&quot;TAIAHSara_1176&quot;,&quot;RouteName&quot;:&quot;Chofer7Insitu_9&quot;,&quot;Sequence&quot;:11,&quot;TimeWindowStart&quot;:null,&quot;TimeWindowEnd&quot;:null,&quot;ArriveCurbApproach&quot;:1,&quot;DepartCurbApproach&quot;:1,&quot;SourceID&quot;:1,&quot;SourceOID&quot;:1337905,&quot;PosAlong&quot;:0.31096960425498427,&quot;SideOfEdge&quot;:1,&quot;CurbApproach&quot;:0,&quot;Status&quot;:0,&quot;Attr_Minutes&quot;:0,&quot;Attr_TravelTime&quot;:0,&quot;Attr_Miles&quot;:0,&quot;Attr_Kilometers&quot;:0,&quot;Attr_TimeAt1KPH&quot;:0,&quot;Attr_WalkTime&quot;:0,&quot;Attr_TruckTravelTime&quot;:0,&quot;Cumul_TravelTime&quot;:137.80065530933956,&quot;Cumul_Kilometers&quot;:90.9428732169896,&quot;Cumul_Miles&quot;:56.509281556329555},&quot;geometry&quot;:{&quot;x&quot;:-58.51620399999996,&quot;y&quot;:-34.677809999999965}},{&quot;attributes&quot;:{&quot;ObjectID&quot;:7,&quot;Name&quot;:&quot;PEREZCristian_1074&quot;,&quot;RouteName&quot;:&quot;Chofer7Insitu_9&quot;,&quot;Sequence&quot;:3,&quot;TimeWindowStart&quot;:null,&quot;TimeWindowEnd&quot;:null,&quot;ArriveCurbApproach&quot;:1,&quot;DepartCurbApproach&quot;:2,&quot;SourceID&quot;:1,&quot;SourceOID&quot;:1300415,&quot;PosAlong&quot;:0.7696569080024132,&quot;SideOfEdge&quot;:1,&quot;CurbApproach&quot;:0,&quot;Status&quot;:0,&quot;Attr_Minutes&quot;:0,&quot;Attr_TravelTime&quot;:0,&quot;Attr_Miles&quot;:0,&quot;Attr_Kilometers&quot;:0,&quot;Attr_TimeAt1KPH&quot;:0,&quot;Attr_WalkTime&quot;:0,&quot;Attr_TruckTravelTime&quot;:0,&quot;Cumul_TravelTime&quot;:70.41779356550359,&quot;Cumul_Kilometers&quot;:48.565718155801335,&quot;Cumul_Miles&quot;:30.17733819233261},&quot;geometry&quot;:{&quot;x&quot;:-58.54043215499996,&quot;y&quot;:-34.852607845999955}},{&quot;attributes&quot;:{&quot;ObjectID&quot;:8,&quot;Name&quot;:&quot;TORRESEduardoEstergidioSIDOMLanus_1018&quot;,&quot;RouteName&quot;:&quot;Chofer7Insitu_9&quot;,&quot;Sequence&quot;:5,&quot;TimeWindowStart&quot;:null,&quot;TimeWindowEnd&quot;:null,&quot;ArriveCurbApproach&quot;:2,&quot;DepartCurbApproach&quot;:2,&quot;SourceID&quot;:1,&quot;SourceOID&quot;:1306021,&quot;PosAlong&quot;:0.01356351455845603,&quot;SideOfEdge&quot;:1,&quot;CurbApproach&quot;:0,&quot;Status&quot;:0,&quot;Attr_Minutes&quot;:0,&quot;Attr_TravelTime&quot;:0,&quot;Attr_Miles&quot;:0,&quot;Attr_Kilometers&quot;:0,&quot;Attr_TimeAt1KPH&quot;:0,&quot;Attr_WalkTime&quot;:0,&quot;Attr_TruckTravelTime&quot;:0,&quot;Cumul_TravelTime&quot;:77.38854051340226,&quot;Cumul_Kilometers&quot;:50.928905916558996,&quot;Cumul_Miles&quot;:31.64575498871527},&quot;geometry&quot;:{&quot;x&quot;:-58.52517599999999,&quot;y&quot;:-34.86218299999996}},{&quot;attributes&quot;:{&quot;ObjectID&quot;:9,&quot;Name&quot;:&quot;TORRESEduardoEstergidioSIDOMLanus_1179&quot;,&quot;RouteName&quot;:&quot;Chofer7Insitu_9&quot;,&quot;Sequence&quot;:4,&quot;TimeWindowStart&quot;:null,&quot;TimeWindowEnd&quot;:null,&quot;ArriveCurbApproach&quot;:1,&quot;DepartCurbApproach&quot;:2,&quot;SourceID&quot;:1,&quot;SourceOID&quot;:1306021,&quot;PosAlong&quot;:0.01356351455845603,&quot;SideOfEdge&quot;:1,&quot;CurbApproach&quot;:0,&quot;Status&quot;:0,&quot;Attr_Minutes&quot;:0,&quot;Attr_TravelTime&quot;:0,&quot;Attr_Miles&quot;:0,&quot;Attr_Kilometers&quot;:0,&quot;Attr_TimeAt1KPH&quot;:0,&quot;Attr_WalkTime&quot;:0,&quot;Attr_TruckTravelTime&quot;:0,&quot;Cumul_TravelTime&quot;:77.38854051340226,&quot;Cumul_Kilometers&quot;:50.928905916558996,&quot;Cumul_Miles&quot;:31.64575498871527},&quot;geometry&quot;:{&quot;x&quot;:-58.52517599999999,&quot;y&quot;:-34.86218299999996}},{&quot;attributes&quot;:{&quot;ObjectID&quot;:10,&quot;Name&quot;:&quot;ROBLESMiguelAngel_1006&quot;,&quot;RouteName&quot;:&quot;Chofer7Insitu_9&quot;,&quot;Sequence&quot;:7,&quot;TimeWindowStart&quot;:null,&quot;TimeWindowEnd&quot;:null,&quot;ArriveCurbApproach&quot;:1,&quot;DepartCurbApproach&quot;:1,&quot;SourceID&quot;:1,&quot;SourceOID&quot;:1312567,&quot;PosAlong&quot;:0.5366670997198127,&quot;SideOfEdge&quot;:2,&quot;CurbApproach&quot;:0,&quot;Status&quot;:0,&quot;Attr_Minutes&quot;:0,&quot;Attr_TravelTime&quot;:0,&quot;Attr_Miles&quot;:0,&quot;Attr_Kilometers&quot;:0,&quot;Attr_TimeAt1KPH&quot;:0,&quot;Attr_WalkTime&quot;:0,&quot;Attr_TruckTravelTime&quot;:0,&quot;Cumul_TravelTime&quot;:95.96414632106546,&quot;Cumul_Kilometers&quot;:60.923904732379505,&quot;Cumul_Miles&quot;:37.85635931931242},&quot;geometry&quot;:{&quot;x&quot;:-58.47756251699997,&quot;y&quot;:-34.800104945999976}},{&quot;attributes&quot;:{&quot;ObjectID&quot;:11,&quot;Name&quot;:&quot;ROBLESMiguelAngel_1167&quot;,&quot;RouteName&quot;:&quot;Chofer7Insitu_9&quot;,&quot;Sequence&quot;:6,&quot;TimeWindowStart&quot;:null,&quot;TimeWindowEnd&quot;:null,&quot;ArriveCurbApproach&quot;:2,&quot;DepartCurbApproach&quot;:1,&quot;SourceID&quot;:1,&quot;SourceOID&quot;:1312567,&quot;PosAlong&quot;:0.5366670997198127,&quot;SideOfEdge&quot;:2,&quot;CurbApproach&quot;:0,&quot;Status&quot;:0,&quot;Attr_Minutes&quot;:0,&quot;Attr_TravelTime&quot;:0,&quot;Attr_Miles&quot;:0,&quot;Attr_Kilometers&quot;:0,&quot;Attr_TimeAt1KPH&quot;:0,&quot;Attr_WalkTime&quot;:0,&quot;Attr_TruckTravelTime&quot;:0,&quot;Cumul_TravelTime&quot;:95.96414632106546,&quot;Cumul_Kilometers&quot;:60.923904732379505,&quot;Cumul_Miles&quot;:37.85635931931242},&quot;geometry&quot;:{&quot;x&quot;:-58.47756251699997,&quot;y&quot;:-34.800104945999976}},{&quot;attributes&quot;:{&quot;ObjectID&quot;:12,&quot;Name&quot;:&quot;GALARZAAQUINOTomas_1025&quot;,&quot;RouteName&quot;:&quot;Chofer7Insitu_9&quot;,&quot;Sequence&quot;:9,&quot;TimeWindowStart&quot;:null,&quot;TimeWindowEnd&quot;:null,&quot;ArriveCurbApproach&quot;:1,&quot;DepartCurbApproach&quot;:2,&quot;SourceID&quot;:1,&quot;SourceOID&quot;:1337986,&quot;PosAlong&quot;:0.28368907959566536,&quot;SideOfEdge&quot;:1,&quot;CurbApproach&quot;:0,&quot;Status&quot;:0,&quot;Attr_Minutes&quot;:0,&quot;Attr_TravelTime&quot;:0,&quot;Attr_Miles&quot;:0,&quot;Attr_Kilometers&quot;:0,&quot;Attr_TimeAt1KPH&quot;:0,&quot;Attr_WalkTime&quot;:0,&quot;Attr_TruckTravelTime&quot;:0,&quot;Cumul_TravelTime&quot;:116.33211625229238,&quot;Cumul_Kilometers&quot;:79.02383326410052,&quot;Cumul_Miles&quot;:49.10313349047843},&quot;geometry&quot;:{&quot;x&quot;:-58.491089999999986,&quot;y&quot;:-34.69867099999993}},{&quot;attributes&quot;:{&quot;ObjectID&quot;:13,&quot;Name&quot;:&quot;GALARZAAQUINOTomas_1186&quot;,&quot;RouteName&quot;:&quot;Chofer7Insitu_9&quot;,&quot;Sequence&quot;:8,&quot;TimeWindowStart&quot;:null,&quot;TimeWindowEnd&quot;:null,&quot;ArriveCurbApproach&quot;:1,&quot;DepartCurbApproach&quot;:1,&quot;SourceID&quot;:1,&quot;SourceOID&quot;:1337986,&quot;PosAlong&quot;:0.28368907959566536,&quot;SideOfEdge&quot;:1,&quot;CurbApproach&quot;:0,&quot;Status&quot;:0,&quot;Attr_Minutes&quot;:0,&quot;Attr_TravelTime&quot;:0,&quot;Attr_Miles&quot;:0,&quot;Attr_Kilometers&quot;:0,&quot;Attr_TimeAt1KPH&quot;:0,&quot;Attr_WalkTime&quot;:0,&quot;Attr_TruckTravelTime&quot;:0,&quot;Cumul_TravelTime&quot;:116.33211625229238,&quot;Cumul_Kilometers&quot;:79.02383326410052,&quot;Cumul_Miles&quot;:49.10313349047843},&quot;geometry&quot;:{&quot;x&quot;:-58.491089999999986,&quot;y&quot;:-34.69867099999993}},{&quot;attributes&quot;:{&quot;ObjectID&quot;:14,&quot;Name&quot;:&quot;PASINISilvana_1155&quot;,&quot;RouteName&quot;:&quot;Chofer7Insitu_9&quot;,&quot;Sequence&quot;:10,&quot;TimeWindowStart&quot;:null,&quot;TimeWindowEnd&quot;:null,&quot;ArriveCurbApproach&quot;:1,&quot;DepartCurbApproach&quot;:1,&quot;SourceID&quot;:1,&quot;SourceOID&quot;:1339428,&quot;PosAlong&quot;:0.8025071980516006,&quot;SideOfEdge&quot;:1,&quot;CurbApproach&quot;:0,&quot;Status&quot;:0,&quot;Attr_Minutes&quot;:0,&quot;Attr_TravelTime&quot;:0,&quot;Attr_Miles&quot;:0,&quot;Attr_Kilometers&quot;:0,&quot;Attr_TimeAt1KPH&quot;:0,&quot;Attr_WalkTime&quot;:0,&quot;Attr_TruckTravelTime&quot;:0,&quot;Cumul_TravelTime&quot;:125.98378230673494,&quot;Cumul_Kilometers&quot;:83.42220044224794,&quot;Cumul_Miles&quot;:51.83615214786146},&quot;geometry&quot;:{&quot;x&quot;:-58.46164360599994,&quot;y&quot;:-34.68794301199995}},{&quot;attributes&quot;:{&quot;ObjectID&quot;:15,&quot;Name&quot;:&quot;OZANBeatriz_1151&quot;,&quot;RouteName&quot;:&quot;Chofer7Insitu_9&quot;,&quot;Sequence&quot;:23,&quot;TimeWindowStart&quot;:null,&quot;TimeWindowEnd&quot;:null,&quot;ArriveCurbApproach&quot;:2,&quot;DepartCurbApproach&quot;:2,&quot;SourceID&quot;:1,&quot;SourceOID&quot;:1346194,&quot;PosAlong&quot;:0.41109001726493793,&quot;SideOfEdge&quot;:2,&quot;CurbApproach&quot;:0,&quot;Status&quot;:0,&quot;Attr_Minutes&quot;:0,&quot;Attr_TravelTime&quot;:0,&quot;Attr_Miles&quot;:0,&quot;Attr_Kilometers&quot;:0,&quot;Attr_TimeAt1KPH&quot;:0,&quot;Attr_WalkTime&quot;:0,&quot;Attr_TruckTravelTime&quot;:0,&quot;Cumul_TravelTime&quot;:185.27633539629153,&quot;Cumul_Kilometers&quot;:111.94401377801901,&quot;Cumul_Miles&quot;:69.55878530508025},&quot;geometry&quot;:{&quot;x&quot;:-58.46833899999996,&quot;y&quot;:-34.643200999999976}},{&quot;attributes&quot;:{&quot;ObjectID&quot;:16,&quot;Name&quot;:&quot;CAPANOAnaCatalina_1117&quot;,&quot;RouteName&quot;:&quot;Chofer7Insitu_9&quot;,&quot;Sequence&quot;:24,&quot;TimeWindowStart&quot;:null,&quot;TimeWindowEnd&quot;:null,&quot;ArriveCurbApproach&quot;:1,&quot;DepartCurbApproach&quot;:1,&quot;SourceID&quot;:1,&quot;SourceOID&quot;:1346177,&quot;PosAlong&quot;:0.9636582257464781,&quot;SideOfEdge&quot;:2,&quot;CurbApproach&quot;:0,&quot;Status&quot;:0,&quot;Attr_Minutes&quot;:0,&quot;Attr_TravelTime&quot;:0,&quot;Attr_Miles&quot;:0,&quot;Attr_Kilometers&quot;:0,&quot;Attr_TimeAt1KPH&quot;:0,&quot;Attr_WalkTime&quot;:0,&quot;Attr_TruckTravelTime&quot;:0,&quot;Cumul_TravelTime&quot;:187.210088721119,&quot;Cumul_Kilometers&quot;:112.60371658016281,&quot;Cumul_Miles&quot;:69.96870562177067},&quot;geometry&quot;:{&quot;x&quot;:-58.46766650699993,&quot;y&quot;:-34.64222207699993}},{&quot;attributes&quot;:{&quot;ObjectID&quot;:17,&quot;Name&quot;:&quot;MORALESZulma_1147&quot;,&quot;RouteName&quot;:&quot;Chofer7Insitu_9&quot;,&quot;Sequence&quot;:25,&quot;TimeWindowStart&quot;:null,&quot;TimeWindowEnd&quot;:null,&quot;ArriveCurbApproach&quot;:2,&quot;DepartCurbApproach&quot;:2,&quot;SourceID&quot;:1,&quot;SourceOID&quot;:1346086,&quot;PosAlong&quot;:0.5456514041161477,&quot;SideOfEdge&quot;:1,&quot;CurbApproach&quot;:0,&quot;Status&quot;:0,&quot;Attr_Minutes&quot;:0,&quot;Attr_TravelTime&quot;:0,&quot;Attr_Miles&quot;:0,&quot;Attr_Kilometers&quot;:0,&quot;Attr_TimeAt1KPH&quot;:0,&quot;Attr_WalkTime&quot;:0,&quot;Attr_TruckTravelTime&quot;:0,&quot;Cumul_TravelTime&quot;:190.0539162577107,&quot;Cumul_Kilometers&quot;:114.01434160778508,&quot;Cumul_Miles&quot;:70.84522737698417},&quot;geometry&quot;:{&quot;x&quot;:-58.463096022999935,&quot;y&quot;:-34.63415533299997}},{&quot;attributes&quot;:{&quot;ObjectID&quot;:18,&quot;Name&quot;:&quot;PAULILLOIrmaHaydee_1044&quot;,&quot;RouteName&quot;:&quot;Chofer7Insitu_9&quot;,&quot;Sequence&quot;:26,&quot;TimeWindowStart&quot;:null,&quot;TimeWindowEnd&quot;:null,&quot;ArriveCurbApproach&quot;:2,&quot;DepartCurbApproach&quot;:1,&quot;SourceID&quot;:1,&quot;SourceOID&quot;:1346550,&quot;PosAlong&quot;:0.6363182261640294,&quot;SideOfEdge&quot;:1,&quot;CurbApproach&quot;:0,&quot;Status&quot;:0,&quot;Attr_Minutes&quot;:0,&quot;Attr_TravelTime&quot;:0,&quot;Attr_Miles&quot;:0,&quot;Attr_Kilometers&quot;:0,&quot;Attr_TimeAt1KPH&quot;:0,&quot;Attr_WalkTime&quot;:0,&quot;Attr_TruckTravelTime&quot;:0,&quot;Cumul_TravelTime&quot;:192.36878106594958,&quot;Cumul_Kilometers&quot;:114.91755698919452,&quot;Cumul_Miles&quot;:71.40645939537765},&quot;geometry&quot;:{&quot;x&quot;:-58.45660373599998,&quot;y&quot;:-34.63795736399993}},{&quot;attributes&quot;:{&quot;ObjectID&quot;:19,&quot;Name&quot;:&quot;ZAMSFeyga_1180&quot;,&quot;RouteName&quot;:&quot;Chofer7Insitu_9&quot;,&quot;Sequence&quot;:29,&quot;TimeWindowStart&quot;:null,&quot;TimeWindowEnd&quot;:null,&quot;ArriveCurbApproach&quot;:1,&quot;DepartCurbApproach&quot;:1,&quot;SourceID&quot;:1,&quot;SourceOID&quot;:1346793,&quot;PosAlong&quot;:0.4148711949534694,&quot;SideOfEdge&quot;:2,&quot;CurbApproach&quot;:0,&quot;Status&quot;:0,&quot;Attr_Minutes&quot;:0,&quot;Attr_TravelTime&quot;:0,&quot;Attr_Miles&quot;:0,&quot;Attr_Kilometers&quot;:0,&quot;Attr_TimeAt1KPH&quot;:0,&quot;Attr_WalkTime&quot;:0,&quot;Attr_TruckTravelTime&quot;:0,&quot;Cumul_TravelTime&quot;:200.98334676142272,&quot;Cumul_Kilometers&quot;:117.6098285504944,&quot;Cumul_Miles&quot;:73.07935938524923},&quot;geometry&quot;:{&quot;x&quot;:-58.472367077999934,&quot;y&quot;:-34.624532907999935}},{&quot;attributes&quot;:{&quot;ObjectID&quot;:20,&quot;Name&quot;:&quot;ZAMSFeyga_1019&quot;,&quot;RouteName&quot;:&quot;Chofer7Insitu_9&quot;,&quot;Sequence&quot;:28,&quot;TimeWindowStart&quot;:null,&quot;TimeWindowEnd&quot;:null,&quot;ArriveCurbApproach&quot;:1,&quot;DepartCurbApproach&quot;:1,&quot;SourceID&quot;:1,&quot;SourceOID&quot;:1346793,&quot;PosAlong&quot;:0.4148711949534694,&quot;SideOfEdge&quot;:2,&quot;CurbApproach&quot;:0,&quot;Status&quot;:0,&quot;Attr_Minutes&quot;:0,&quot;Attr_TravelTime&quot;:0,&quot;Attr_Miles&quot;:0,&quot;Attr_Kilometers&quot;:0,&quot;Attr_TimeAt1KPH&quot;:0,&quot;Attr_WalkTime&quot;:0,&quot;Attr_TruckTravelTime&quot;:0,&quot;Cumul_TravelTime&quot;:200.98334676142272,&quot;Cumul_Kilometers&quot;:117.6098285504944,&quot;Cumul_Miles&quot;:73.07935938524923},&quot;geometry&quot;:{&quot;x&quot;:-58.472367077999934,&quot;y&quot;:-34.624532907999935}},{&quot;attributes&quot;:{&quot;ObjectID&quot;:21,&quot;Name&quot;:&quot;QUEVEDOAdelaida_1160&quot;,&quot;RouteName&quot;:&quot;Chofer7Insitu_9&quot;,&quot;Sequence&quot;:30,&quot;TimeWindowStart&quot;:null,&quot;TimeWindowEnd&quot;:null,&quot;ArriveCurbApproach&quot;:1,&quot;DepartCurbApproach&quot;:1,&quot;SourceID&quot;:1,&quot;SourceOID&quot;:1346902,&quot;PosAlong&quot;:0.5209849745614188,&quot;SideOfEdge&quot;:2,&quot;CurbApproach&quot;:0,&quot;Status&quot;:0,&quot;Attr_Minutes&quot;:0,&quot;Attr_TravelTime&quot;:0,&quot;Attr_Miles&quot;:0,&quot;Attr_Kilometers&quot;:0,&quot;Attr_TimeAt1KPH&quot;:0,&quot;Attr_WalkTime&quot;:0,&quot;Attr_TruckTravelTime&quot;:0,&quot;Cumul_TravelTime&quot;:203.85297610570723,&quot;Cumul_Kilometers&quot;:118.65477681537767,&quot;Cumul_Miles&quot;:73.72866013442614},&quot;geometry&quot;:{&quot;x&quot;:-58.46737682799994,&quot;y&quot;:-34.61914837399996}},{&quot;attributes&quot;:{&quot;ObjectID&quot;:22,&quot;Name&quot;:&quot;TERCEIROdeATISMariaDigna_1057&quot;,&quot;RouteName&quot;:&quot;Chofer7Insitu_9&quot;,&quot;Sequence&quot;:27,&quot;TimeWindowStart&quot;:null,&quot;TimeWindowEnd&quot;:null,&quot;ArriveCurbApproach&quot;:2,&quot;DepartCurbApproach&quot;:2,&quot;SourceID&quot;:1,&quot;SourceOID&quot;:1346689,&quot;PosAlong&quot;:0.25396698524670636,&quot;SideOfEdge&quot;:2,&quot;CurbApproach&quot;:0,&quot;Status&quot;:0,&quot;Attr_Minutes&quot;:0,&quot;Attr_TravelTime&quot;:0,&quot;Attr_Miles&quot;:0,&quot;Attr_Kilometers&quot;:0,&quot;Attr_TimeAt1KPH&quot;:0,&quot;Attr_WalkTime&quot;:0,&quot;Attr_TruckTravelTime&quot;:0,&quot;Cumul_TravelTime&quot;:198.76807690059303,&quot;Cumul_Kilometers&quot;:116.84757412183886,&quot;Cumul_Miles&quot;:72.60571644212735},&quot;geometry&quot;:{&quot;x&quot;:-58.46754599999997,&quot;y&quot;:-34.62756899999994}},{&quot;attributes&quot;:{&quot;ObjectID&quot;:23,&quot;Name&quot;:&quot;PECORAROAngel_1045&quot;,&quot;RouteName&quot;:&quot;Chofer7Insitu_9&quot;,&quot;Sequence&quot;:22,&quot;TimeWindowStart&quot;:null,&quot;TimeWindowEnd&quot;:null,&quot;ArriveCurbApproach&quot;:2,&quot;DepartCurbApproach&quot;:2,&quot;SourceID&quot;:1,&quot;SourceOID&quot;:1346074,&quot;PosAlong&quot;:0.18283505572666633,&quot;SideOfEdge&quot;:1,&quot;CurbApproach&quot;:0,&quot;Status&quot;:0,&quot;Attr_Minutes&quot;:0,&quot;Attr_TravelTime&quot;:0,&quot;Attr_Miles&quot;:0,&quot;Attr_Kilometers&quot;:0,&quot;Attr_TimeAt1KPH&quot;:0,&quot;Attr_WalkTime&quot;:0,&quot;Attr_TruckTravelTime&quot;:0,&quot;Cumul_TravelTime&quot;:180.98497102947834,&quot;Cumul_Kilometers&quot;:110.01108946487142,&quot;Cumul_Miles&quot;:68.3577218201152},&quot;geometry&quot;:{&quot;x&quot;:-58.47758799999997,&quot;y&quot;:-34.638720999999975}},{&quot;attributes&quot;:{&quot;ObjectID&quot;:24,&quot;Name&quot;:&quot;MORALESMariano_1038&quot;,&quot;RouteName&quot;:&quot;Chofer7Insitu_9&quot;,&quot;Sequence&quot;:20,&quot;TimeWindowStart&quot;:null,&quot;TimeWindowEnd&quot;:null,&quot;ArriveCurbApproach&quot;:1,&quot;DepartCurbApproach&quot;:1,&quot;SourceID&quot;:1,&quot;SourceOID&quot;:1338452,&quot;PosAlong&quot;:0.7556701552479672,&quot;SideOfEdge&quot;:2,&quot;CurbApproach&quot;:0,&quot;Status&quot;:0,&quot;Attr_Minutes&quot;:0,&quot;Attr_TravelTime&quot;:0,&quot;Attr_Miles&quot;:0,&quot;Attr_Kilometers&quot;:0,&quot;Attr_TimeAt1KPH&quot;:0,&quot;Attr_WalkTime&quot;:0,&quot;Attr_TruckTravelTime&quot;:0,&quot;Cumul_TravelTime&quot;:176.700560913163,&quot;Cumul_Kilometers&quot;:107.94903156517945,&quot;Cumul_Miles&quot;:67.07641844452118},&quot;geometry&quot;:{&quot;x&quot;:-58.493023999999934,&quot;y&quot;:-34.645306999999946}},{&quot;attributes&quot;:{&quot;ObjectID&quot;:25,&quot;Name&quot;:&quot;MORALESMariano_1199&quot;,&quot;RouteName&quot;:&quot;Chofer7Insitu_9&quot;,&quot;Sequence&quot;:21,&quot;TimeWindowStart&quot;:null,&quot;TimeWindowEnd&quot;:null,&quot;ArriveCurbApproach&quot;:1,&quot;DepartCurbApproach&quot;:1,&quot;SourceID&quot;:1,&quot;SourceOID&quot;:1338452,&quot;PosAlong&quot;:0.7556701552479672,&quot;SideOfEdge&quot;:2,&quot;CurbApproach&quot;:0,&quot;Status&quot;:0,&quot;Attr_Minutes&quot;:0,&quot;Attr_TravelTime&quot;:0,&quot;Attr_Miles&quot;:0,&quot;Attr_Kilometers&quot;:0,&quot;Attr_TimeAt1KPH&quot;:0,&quot;Attr_WalkTime&quot;:0,&quot;Attr_TruckTravelTime&quot;:0,&quot;Cumul_TravelTime&quot;:176.700560913163,&quot;Cumul_Kilometers&quot;:107.94903156517945,&quot;Cumul_Miles&quot;:67.07641844452118},&quot;geometry&quot;:{&quot;x&quot;:-58.493023999999934,&quot;y&quot;:-34.645306999999946}},{&quot;attributes&quot;:{&quot;ObjectID&quot;:26,&quot;Name&quot;:&quot;TRICHILLONormaElena_1080&quot;,&quot;RouteName&quot;:&quot;Chofer7Insitu_9&quot;,&quot;Sequence&quot;:19,&quot;TimeWindowStart&quot;:null,&quot;TimeWindowEnd&quot;:null,&quot;ArriveCurbApproach&quot;:2,&quot;DepartCurbApproach&quot;:2,&quot;SourceID&quot;:1,&quot;SourceOID&quot;:1344755,&quot;PosAlong&quot;:0.5332582478747812,&quot;SideOfEdge&quot;:1,&quot;CurbApproach&quot;:0,&quot;Status&quot;:0,&quot;Attr_Minutes&quot;:0,&quot;Attr_TravelTime&quot;:0,&quot;Attr_Miles&quot;:0,&quot;Attr_Kilometers&quot;:0,&quot;Attr_TimeAt1KPH&quot;:0,&quot;Attr_WalkTime&quot;:0,&quot;Attr_TruckTravelTime&quot;:0,&quot;Cumul_TravelTime&quot;:174.18509162613682,&quot;Cumul_Kilometers&quot;:106.94043464001379,&quot;Cumul_Miles&quot;:66.4497053706441},&quot;geometry&quot;:{&quot;x&quot;:-58.49544499999996,&quot;y&quot;:-34.64288799999997}},{&quot;attributes&quot;:{&quot;ObjectID&quot;:27,&quot;Name&quot;:&quot;RIPPACelia_1004&quot;,&quot;RouteName&quot;:&quot;Chofer7Insitu_9&quot;,&quot;Sequence&quot;:16,&quot;TimeWindowStart&quot;:null,&quot;TimeWindowEnd&quot;:null,&quot;ArriveCurbApproach&quot;:2,&quot;DepartCurbApproach&quot;:2,&quot;SourceID&quot;:1,&quot;SourceOID&quot;:1345358,&quot;PosAlong&quot;:0.5814612773134307,&quot;SideOfEdge&quot;:2,&quot;CurbApproach&quot;:0,&quot;Status&quot;:0,&quot;Attr_Minutes&quot;:0,&quot;Attr_TravelTime&quot;:0,&quot;Attr_Miles&quot;:0,&quot;Attr_Kilometers&quot;:0,&quot;Attr_TimeAt1KPH&quot;:0,&quot;Attr_WalkTime&quot;:0,&quot;Attr_TruckTravelTime&quot;:0,&quot;Cumul_TravelTime&quot;:158.53139889109556,&quot;Cumul_Kilometers&quot;:100.90988963869015,&quot;Cumul_Miles&quot;:62.702498433330746},&quot;geometry&quot;:{&quot;x&quot;:-58.50879599999996,&quot;y&quot;:-34.622157999999956}},{&quot;attributes&quot;:{&quot;ObjectID&quot;:28,&quot;Name&quot;:&quot;RIPPACelia_1165&quot;,&quot;RouteName&quot;:&quot;Chofer7Insitu_9&quot;,&quot;Sequence&quot;:15,&quot;TimeWindowStart&quot;:null,&quot;TimeWindowEnd&quot;:null,&quot;ArriveCurbApproach&quot;:2,&quot;DepartCurbApproach&quot;:2,&quot;SourceID&quot;:1,&quot;SourceOID&quot;:1345358,&quot;PosAlong&quot;:0.5814612773134307,&quot;SideOfEdge&quot;:2,&quot;CurbApproach&quot;:0,&quot;Status&quot;:0,&quot;Attr_Minutes&quot;:0,&quot;Attr_TravelTime&quot;:0,&quot;Attr_Miles&quot;:0,&quot;Attr_Kilometers&quot;:0,&quot;Attr_TimeAt1KPH&quot;:0,&quot;Attr_WalkTime&quot;:0,&quot;Attr_TruckTravelTime&quot;:0,&quot;Cumul_TravelTime&quot;:158.53139889109556,&quot;Cumul_Kilometers&quot;:100.90988963869015,&quot;Cumul_Miles&quot;:62.702498433330746},&quot;geometry&quot;:{&quot;x&quot;:-58.50879599999996,&quot;y&quot;:-34.622157999999956}},{&quot;attributes&quot;:{&quot;ObjectID&quot;:29,&quot;Name&quot;:&quot;BIBINIHuberto_1109&quot;,&quot;RouteName&quot;:&quot;Chofer7Insitu_9&quot;,&quot;Sequence&quot;:17,&quot;TimeWindowStart&quot;:null,&quot;TimeWindowEnd&quot;:null,&quot;ArriveCurbApproach&quot;:2,&quot;DepartCurbApproach&quot;:2,&quot;SourceID&quot;:1,&quot;SourceOID&quot;:1345751,&quot;PosAlong&quot;:0.729858064315909,&quot;SideOfEdge&quot;:1,&quot;CurbApproach&quot;:0,&quot;Status&quot;:0,&quot;Attr_Minutes&quot;:0,&quot;Attr_TravelTime&quot;:0,&quot;Attr_Miles&quot;:0,&quot;Attr_Kilometers&quot;:0,&quot;Attr_TimeAt1KPH&quot;:0,&quot;Attr_WalkTime&quot;:0,&quot;Attr_TruckTravelTime&quot;:0,&quot;Cumul_TravelTime&quot;:163.6522094090549,&quot;Cumul_Kilometers&quot;:102.87555810263068,&quot;Cumul_Miles&quot;:63.9239081903128},&quot;geometry&quot;:{&quot;x&quot;:-58.49389851099994,&quot;y&quot;:-34.623492210999984}},{&quot;attributes&quot;:{&quot;ObjectID&quot;:30,&quot;Name&quot;:&quot;FORESTIEROCarlosAlfredo_1130&quot;,&quot;RouteName&quot;:&quot;Chofer7Insitu_9&quot;,&quot;Sequence&quot;:18,&quot;TimeWindowStart&quot;:null,&quot;TimeWindowEnd&quot;:null,&quot;ArriveCurbApproach&quot;:2,&quot;DepartCurbApproach&quot;:2,&quot;SourceID&quot;:1,&quot;SourceOID&quot;:1345771,&quot;PosAlong&quot;:0.7936531128805292,&quot;SideOfEdge&quot;:2,&quot;CurbApproach&quot;:0,&quot;Status&quot;:0,&quot;Attr_Minutes&quot;:0,&quot;Attr_TravelTime&quot;:0,&quot;Attr_Miles&quot;:0,&quot;Attr_Kilometers&quot;:0,&quot;Attr_TimeAt1KPH&quot;:0,&quot;Attr_WalkTime&quot;:0,&quot;Attr_TruckTravelTime&quot;:0,&quot;Cumul_TravelTime&quot;:165.7049194000832,&quot;Cumul_Kilometers&quot;:103.66750363416051,&quot;Cumul_Miles&quot;:64.41600032942652},&quot;geometry&quot;:{&quot;x&quot;:-58.487705999999946,&quot;y&quot;:-34.623621999999955}},{&quot;attributes&quot;:{&quot;ObjectID&quot;:31,&quot;Name&quot;:&quot;AGUIRREMarcielOrlando_1096&quot;,&quot;RouteName&quot;:&quot;Chofer7Insitu_9&quot;,&quot;Sequence&quot;:31,&quot;TimeWindowStart&quot;:null,&quot;TimeWindowEnd&quot;:null,&quot;ArriveCurbApproach&quot;:2,&quot;DepartCurbApproach&quot;:2,&quot;SourceID&quot;:1,&quot;SourceOID&quot;:1347796,&quot;PosAlong&quot;:0.6757317892352591,&quot;SideOfEdge&quot;:2,&quot;CurbApproach&quot;:0,&quot;Status&quot;:0,&quot;Attr_Minutes&quot;:0,&quot;Attr_TravelTime&quot;:0,&quot;Attr_Miles&quot;:0,&quot;Attr_Kilometers&quot;:0,&quot;Attr_TimeAt1KPH&quot;:0,&quot;Attr_WalkTime&quot;:0,&quot;Attr_TruckTravelTime&quot;:0,&quot;Cumul_TravelTime&quot;:216.61212784961188,&quot;Cumul_Kilometers&quot;:123.95668830522962,&quot;Cumul_Miles&quot;:77.02311519801226},&quot;geometry&quot;:{&quot;x&quot;:-58.49963299999996,&quot;y&quot;:-34.600728999999944}},{&quot;attributes&quot;:{&quot;ObjectID&quot;:32,&quot;Name&quot;:&quot;CANATTAAdriano_1116&quot;,&quot;RouteName&quot;:&quot;Chofer7Insitu_9&quot;,&quot;Sequence&quot;:32,&quot;TimeWindowStart&quot;:null,&quot;TimeWindowEnd&quot;:null,&quot;ArriveCurbApproach&quot;:2,&quot;DepartCurbApproach&quot;:null,&quot;SourceID&quot;:1,&quot;SourceOID&quot;:1347680,&quot;PosAlong&quot;:0.7346115984865649,&quot;SideOfEdge&quot;:1,&quot;CurbApproach&quot;:0,&quot;Status&quot;:0,&quot;Attr_Minutes&quot;:0,&quot;Attr_TravelTime&quot;:0,&quot;Attr_Miles&quot;:0,&quot;Attr_Kilometers&quot;:0,&quot;Attr_TimeAt1KPH&quot;:0,&quot;Attr_WalkTime&quot;:0,&quot;Attr_TruckTravelTime&quot;:0,&quot;Cumul_TravelTime&quot;:222.75213992732148,&quot;Cumul_Kilometers&quot;:125.96659476460248,&quot;Cumul_Miles&quot;:78.2720131709583},&quot;geometry&quot;:{&quot;x&quot;:-58.51393729399996,&quot;y&quot;:-34.593400507999945}},{&quot;attributes&quot;:{&quot;ObjectID&quot;:33,&quot;Name&quot;:&quot;JURICALydiaMatilde_1138&quot;,&quot;RouteName&quot;:&quot;Chofer4Insitu_6&quot;,&quot;Sequence&quot;:1,&quot;TimeWindowStart&quot;:null,&quot;TimeWindowEnd&quot;:null,&quot;ArriveCurbApproach&quot;:null,&quot;DepartCurbApproach&quot;:2,&quot;SourceID&quot;:1,&quot;SourceOID&quot;:1344319,&quot;PosAlong&quot;:0.22460275511464667,&quot;SideOfEdge&quot;:2,&quot;CurbApproach&quot;:0,&quot;Status&quot;:0,&quot;Attr_Minutes&quot;:0,&quot;Attr_TravelTime&quot;:0,&quot;Attr_Miles&quot;:0,&quot;Attr_Kilometers&quot;:0,&quot;Attr_TimeAt1KPH&quot;:0,&quot;Attr_WalkTime&quot;:0,&quot;Attr_TruckTravelTime&quot;:0,&quot;Cumul_TravelTime&quot;:0,&quot;Cumul_Kilometers&quot;:0,&quot;Cumul_Miles&quot;:0},&quot;geometry&quot;:{&quot;x&quot;:-58.52398619099995,&quot;y&quot;:-34.64869156499998}},{&quot;attributes&quot;:{&quot;ObjectID&quot;:34,&quot;Name&quot;:&quot;SANDERSergio_1090&quot;,&quot;RouteName&quot;:&quot;Chofer4Insitu_6&quot;,&quot;Sequence&quot;:11,&quot;TimeWindowStart&quot;:null,&quot;TimeWindowEnd&quot;:null,&quot;ArriveCurbApproach&quot;:2,&quot;DepartCurbApproach&quot;:1,&quot;SourceID&quot;:1,&quot;SourceOID&quot;:1321473,&quot;PosAlong&quot;:0.54081402595816,&quot;SideOfEdge&quot;:1,&quot;CurbApproach&quot;:0,&quot;Status&quot;:0,&quot;Attr_Minutes&quot;:0,&quot;Attr_TravelTime&quot;:0,&quot;Attr_Miles&quot;:0,&quot;Attr_Kilometers&quot;:0,&quot;Attr_TimeAt1KPH&quot;:0,&quot;Attr_WalkTime&quot;:0,&quot;Attr_TruckTravelTime&quot;:0,&quot;Cumul_TravelTime&quot;:71.61692572576713,&quot;Cumul_Kilometers&quot;:31.259328545730607,&quot;Cumul_Miles&quot;:19.423646246999148},&quot;geometry&quot;:{&quot;x&quot;:-58.640053999999964,&quot;y&quot;:-34.693502999999964}},{&quot;attributes&quot;:{&quot;ObjectID&quot;:35,&quot;Name&quot;:&quot;BRANDARIZRuben_1181&quot;,&quot;RouteName&quot;:&quot;Chofer4Insitu_6&quot;,&quot;Sequence&quot;:5,&quot;TimeWindowStart&quot;:null,&quot;TimeWindowEnd&quot;:null,&quot;ArriveCurbApproach&quot;:1,&quot;DepartCurbApproach&quot;:1,&quot;SourceID&quot;:1,&quot;SourceOID&quot;:1345208,&quot;PosAlong&quot;:0.5177293122326773,&quot;SideOfEdge&quot;:1,&quot;CurbApproach&quot;:0,&quot;Status&quot;:0,&quot;Attr_Minutes&quot;:0,&quot;Attr_TravelTime&quot;:0,&quot;Attr_Miles&quot;:0,&quot;Attr_Kilometers&quot;:0,&quot;Attr_TimeAt1KPH&quot;:0,&quot;Attr_WalkTime&quot;:0,&quot;Attr_TruckTravelTime&quot;:0,&quot;Cumul_TravelTime&quot;:20.262148336879687,&quot;Cumul_Kilometers&quot;:9.783395082191774,&quot;Cumul_Miles&quot;:6.079119866350372},&quot;geometry&quot;:{&quot;x&quot;:-58.52948203699998,&quot;y&quot;:-34.62403804099995}},{&quot;attributes&quot;:{&quot;ObjectID&quot;:36,&quot;Name&quot;:&quot;RAMOSRodolfo_1162&quot;,&quot;RouteName&quot;:&quot;Chofer4Insitu_6&quot;,&quot;Sequence&quot;:6,&quot;TimeWindowStart&quot;:null,&quot;TimeWindowEnd&quot;:null,&quot;ArriveCurbApproach&quot;:1,&quot;DepartCurbApproach&quot;:1,&quot;SourceID&quot;:1,&quot;SourceOID&quot;:1345260,&quot;PosAlong&quot;:0.9034492190545744,&quot;SideOfEdge&quot;:1,&quot;CurbApproach&quot;:0,&quot;Status&quot;:0,&quot;Attr_Minutes&quot;:0,&quot;Attr_TravelTime&quot;:0,&quot;Attr_Miles&quot;:0,&quot;Attr_Kilometers&quot;:0,&quot;Attr_TimeAt1KPH&quot;:0,&quot;Attr_WalkTime&quot;:0,&quot;Attr_TruckTravelTime&quot;:0,&quot;Cumul_TravelTime&quot;:23.587181753620765,&quot;Cumul_Kilometers&quot;:10.94282238111604,&quot;Cumul_Miles&quot;:6.799554589395457},&quot;geometry&quot;:{&quot;x&quot;:-58.526036999999974,&quot;y&quot;:-34.617528999999934}},{&quot;attributes&quot;:{&quot;ObjectID&quot;:37,&quot;Name&quot;:&quot;NASCIMBENERaquel_1039&quot;,&quot;RouteName&quot;:&quot;Chofer4Insitu_6&quot;,&quot;Sequence&quot;:3,&quot;TimeWindowStart&quot;:null,&quot;TimeWindowEnd&quot;:null,&quot;ArriveCurbApproach&quot;:1,&quot;DepartCurbApproach&quot;:1,&quot;SourceID&quot;:1,&quot;SourceOID&quot;:1331870,&quot;PosAlong&quot;:0.2457514013525962,&quot;SideOfEdge&quot;:2,&quot;CurbApproach&quot;:0,&quot;Status&quot;:0,&quot;Attr_Minutes&quot;:0,&quot;Attr_TravelTime&quot;:0,&quot;Attr_Miles&quot;:0,&quot;Attr_Kilometers&quot;:0,&quot;Attr_TimeAt1KPH&quot;:0,&quot;Attr_WalkTime&quot;:0,&quot;Attr_TruckTravelTime&quot;:0,&quot;Cumul_TravelTime&quot;:9.075478617361842,&quot;Cumul_Kilometers&quot;:4.316915211099714,&quot;Cumul_Miles&quot;:2.6824067515085117},&quot;geometry&quot;:{&quot;x&quot;:-58.54503699999998,&quot;y&quot;:-34.63770499999998}},{&quot;attributes&quot;:{&quot;ObjectID&quot;:38,&quot;Name&quot;:&quot;NASCIMBENERaquel_1200&quot;,&quot;RouteName&quot;:&quot;Chofer4Insitu_6&quot;,&quot;Sequence&quot;:2,&quot;TimeWindowStart&quot;:null,&quot;TimeWindowEnd&quot;:null,&quot;ArriveCurbApproach&quot;:1,&quot;DepartCurbApproach&quot;:1,&quot;SourceID&quot;:1,&quot;SourceOID&quot;:1331870,&quot;PosAlong&quot;:0.2457514013525962,&quot;SideOfEdge&quot;:2,&quot;CurbApproach&quot;:0,&quot;Status&quot;:0,&quot;Attr_Minutes&quot;:0,&quot;Attr_TravelTime&quot;:0,&quot;Attr_Miles&quot;:0,&quot;Attr_Kilometers&quot;:0,&quot;Attr_TimeAt1KPH&quot;:0,&quot;Attr_WalkTime&quot;:0,&quot;Attr_TruckTravelTime&quot;:0,&quot;Cumul_TravelTime&quot;:9.075478617361842,&quot;Cumul_Kilometers&quot;:4.316915211099714,&quot;Cumul_Miles&quot;:2.6824067515085117},&quot;geometry&quot;:{&quot;x&quot;:-58.54503699999998,&quot;y&quot;:-34.63770499999998}},{&quot;attributes&quot;:{&quot;ObjectID&quot;:39,&quot;Name&quot;:&quot;PROSAPIOAlfredoSM_1159&quot;,&quot;RouteName&quot;:&quot;Chofer4Insitu_6&quot;,&quot;Sequence&quot;:4,&quot;TimeWindowStart&quot;:null,&quot;TimeWindowEnd&quot;:null,&quot;ArriveCurbApproach&quot;:2,&quot;DepartCurbApproach&quot;:1,&quot;SourceID&quot;:1,&quot;SourceOID&quot;:1332105,&quot;PosAlong&quot;:0.22226508117127372,&quot;SideOfEdge&quot;:2,&quot;CurbApproach&quot;:0,&quot;Status&quot;:0,&quot;Attr_Minutes&quot;:0,&quot;Attr_TravelTime&quot;:0,&quot;Attr_Miles&quot;:0,&quot;Attr_Kilometers&quot;:0,&quot;Attr_TimeAt1KPH&quot;:0,&quot;Attr_WalkTime&quot;:0,&quot;Attr_TruckTravelTime&quot;:0,&quot;Cumul_TravelTime&quot;:12.721142921701766,&quot;Cumul_Kilometers&quot;:5.829970290925505,&quot;Cumul_Miles&quot;:3.622575590380619},&quot;geometry&quot;:{&quot;x&quot;:-58.55572399999994,&quot;y&quot;:-34.631599999999935}},{&quot;attributes&quot;:{&quot;ObjectID&quot;:40,&quot;Name&quot;:&quot;PEREZVicenteMiguel_1156&quot;,&quot;RouteName&quot;:&quot;Chofer4Insitu_6&quot;,&quot;Sequence&quot;:10,&quot;TimeWindowStart&quot;:null,&quot;TimeWindowEnd&quot;:null,&quot;ArriveCurbApproach&quot;:1,&quot;DepartCurbApproach&quot;:2,&quot;SourceID&quot;:1,&quot;SourceOID&quot;:1331172,&quot;PosAlong&quot;:0.17687026299446662,&quot;SideOfEdge&quot;:1,&quot;CurbApproach&quot;:0,&quot;Status&quot;:0,&quot;Attr_Minutes&quot;:0,&quot;Attr_TravelTime&quot;:0,&quot;Attr_Miles&quot;:0,&quot;Attr_Kilometers&quot;:0,&quot;Attr_TimeAt1KPH&quot;:0,&quot;Attr_WalkTime&quot;:0,&quot;Attr_TruckTravelTime&quot;:0,&quot;Cumul_TravelTime&quot;:47.45437487397901,&quot;Cumul_Kilometers&quot;:21.01021789685331,&quot;Cumul_Miles&quot;:13.055144143733902},&quot;geometry&quot;:{&quot;x&quot;:-58.596568107999985,&quot;y&quot;:-34.62089315099996}},{&quot;attributes&quot;:{&quot;ObjectID&quot;:41,&quot;Name&quot;:&quot;OCCHIUZZICarmen_1040&quot;,&quot;RouteName&quot;:&quot;Chofer4Insitu_6&quot;,&quot;Sequence&quot;:13,&quot;TimeWindowStart&quot;:null,&quot;TimeWindowEnd&quot;:null,&quot;ArriveCurbApproach&quot;:1,&quot;DepartCurbApproach&quot;:2,&quot;SourceID&quot;:1,&quot;SourceOID&quot;:1332862,&quot;PosAlong&quot;:0.3910225186463655,&quot;SideOfEdge&quot;:2,&quot;CurbApproach&quot;:0,&quot;Status&quot;:0,&quot;Attr_Minutes&quot;:0,&quot;Attr_TravelTime&quot;:0,&quot;Attr_Miles&quot;:0,&quot;Attr_Kilometers&quot;:0,&quot;Attr_TimeAt1KPH&quot;:0,&quot;Attr_WalkTime&quot;:0,&quot;Attr_TruckTravelTime&quot;:0,&quot;Cumul_TravelTime&quot;:99.64354898468756,&quot;Cumul_Kilometers&quot;:43.10814673152014,&quot;Cumul_Miles&quot;:26.78616052970661},&quot;geometry&quot;:{&quot;x&quot;:-58.58808696299997,&quot;y&quot;:-34.60707843299997}},{&quot;attributes&quot;:{&quot;ObjectID&quot;:42,&quot;Name&quot;:&quot;OCCHIUZZICarmen_1201&quot;,&quot;RouteName&quot;:&quot;Chofer4Insitu_6&quot;,&quot;Sequence&quot;:12,&quot;TimeWindowStart&quot;:null,&quot;TimeWindowEnd&quot;:null,&quot;ArriveCurbApproach&quot;:1,&quot;DepartCurbApproach&quot;:1,&quot;SourceID&quot;:1,&quot;SourceOID&quot;:1332862,&quot;PosAlong&quot;:0.3910225186463655,&quot;SideOfEdge&quot;:2,&quot;CurbApproach&quot;:0,&quot;Status&quot;:0,&quot;Attr_Minutes&quot;:0,&quot;Attr_TravelTime&quot;:0,&quot;Attr_Miles&quot;:0,&quot;Attr_Kilometers&quot;:0,&quot;Attr_TimeAt1KPH&quot;:0,&quot;Attr_WalkTime&quot;:0,&quot;Attr_TruckTravelTime&quot;:0,&quot;Cumul_TravelTime&quot;:99.64354898468756,&quot;Cumul_Kilometers&quot;:43.10814673152014,&quot;Cumul_Miles&quot;:26.78616052970661},&quot;geometry&quot;:{&quot;x&quot;:-58.58808696299997,&quot;y&quot;:-34.60707843299997}},{&quot;attributes&quot;:{&quot;ObjectID&quot;:43,&quot;Name&quot;:&quot;SALASSANTOSLuisSM_1052&quot;,&quot;RouteName&quot;:&quot;Chofer4Insitu_6&quot;,&quot;Sequence&quot;:14,&quot;TimeWindowStart&quot;:null,&quot;TimeWindowEnd&quot;:null,&quot;ArriveCurbApproach&quot;:2,&quot;DepartCurbApproach&quot;:1,&quot;SourceID&quot;:1,&quot;SourceOID&quot;:1332911,&quot;PosAlong&quot;:0.024240031595410317,&quot;SideOfEdge&quot;:2,&quot;CurbApproach&quot;:0,&quot;Status&quot;:0,&quot;Attr_Minutes&quot;:0,&quot;Attr_TravelTime&quot;:0,&quot;Attr_Miles&quot;:0,&quot;Attr_Kilometers&quot;:0,&quot;Attr_TimeAt1KPH&quot;:0,&quot;Attr_WalkTime&quot;:0,&quot;Attr_TruckTravelTime&quot;:0,&quot;Cumul_TravelTime&quot;:100.96433766266209,&quot;Cumul_Kilometers&quot;:43.820429539307725,&quot;Cumul_Miles&quot;:27.228752547191746},&quot;geometry&quot;:{&quot;x&quot;:-58.58258999999998,&quot;y&quot;:-34.606011999999964}},{&quot;attributes&quot;:{&quot;ObjectID&quot;:44,&quot;Name&quot;:&quot;BRUSADINMario_1111&quot;,&quot;RouteName&quot;:&quot;Chofer4Insitu_6&quot;,&quot;Sequence&quot;:9,&quot;TimeWindowStart&quot;:null,&quot;TimeWindowEnd&quot;:null,&quot;ArriveCurbApproach&quot;:2,&quot;DepartCurbApproach&quot;:2,&quot;SourceID&quot;:1,&quot;SourceOID&quot;:1332683,&quot;PosAlong&quot;:0.545301070966739,&quot;SideOfEdge&quot;:1,&quot;CurbApproach&quot;:0,&quot;Status&quot;:0,&quot;Attr_Minutes&quot;:0,&quot;Attr_TravelTime&quot;:0,&quot;Attr_Miles&quot;:0,&quot;Attr_Kilometers&quot;:0,&quot;Attr_TimeAt1KPH&quot;:0,&quot;Attr_WalkTime&quot;:0,&quot;Attr_TruckTravelTime&quot;:0,&quot;Cumul_TravelTime&quot;:38.09276458054344,&quot;Cumul_Kilometers&quot;:16.82774511455684,&quot;Cumul_Miles&quot;:10.45627604449815},&quot;geometry&quot;:{&quot;x&quot;:-58.562862999999936,&quot;y&quot;:-34.60587599999997}},{&quot;attributes&quot;:{&quot;ObjectID&quot;:45,&quot;Name&quot;:&quot;GALINDEZCarangeloElenaMaria_1131&quot;,&quot;RouteName&quot;:&quot;Chofer4Insitu_6&quot;,&quot;Sequence&quot;:7,&quot;TimeWindowStart&quot;:null,&quot;TimeWindowEnd&quot;:null,&quot;ArriveCurbApproach&quot;:1,&quot;DepartCurbApproach&quot;:1,&quot;SourceID&quot;:1,&quot;SourceOID&quot;:1333986,&quot;PosAlong&quot;:0.08248715567761666,&quot;SideOfEdge&quot;:2,&quot;CurbApproach&quot;:0,&quot;Status&quot;:0,&quot;Attr_Minutes&quot;:0,&quot;Attr_TravelTime&quot;:0,&quot;Attr_Miles&quot;:0,&quot;Attr_Kilometers&quot;:0,&quot;Attr_TimeAt1KPH&quot;:0,&quot;Attr_WalkTime&quot;:0,&quot;Attr_TruckTravelTime&quot;:0,&quot;Cumul_TravelTime&quot;:34.386671738859555,&quot;Cumul_Kilometers&quot;:15.621672900144752,&quot;Cumul_Miles&quot;:9.706857514704591},&quot;geometry&quot;:{&quot;x&quot;:-58.56016114399995,&quot;y&quot;:-34.60250124299995}},{&quot;attributes&quot;:{&quot;ObjectID&quot;:46,&quot;Name&quot;:&quot;CASTELLANODelia_1118&quot;,&quot;RouteName&quot;:&quot;Chofer4Insitu_6&quot;,&quot;Sequence&quot;:8,&quot;TimeWindowStart&quot;:null,&quot;TimeWindowEnd&quot;:null,&quot;ArriveCurbApproach&quot;:2,&quot;DepartCurbApproach&quot;:2,&quot;SourceID&quot;:1,&quot;SourceOID&quot;:1333086,&quot;PosAlong&quot;:0.03532376842581315,&quot;SideOfEdge&quot;:1,&quot;CurbApproach&quot;:0,&quot;Status&quot;:0,&quot;Attr_Minutes&quot;:0,&quot;Attr_TravelTime&quot;:0,&quot;Attr_Miles&quot;:0,&quot;Attr_Kilometers&quot;:0,&quot;Attr_TimeAt1KPH&quot;:0,&quot;Attr_WalkTime&quot;:0,&quot;Attr_TruckTravelTime&quot;:0,&quot;Cumul_TravelTime&quot;:35.664355247599715,&quot;Cumul_Kilometers&quot;:16.044444228407038,&quot;Cumul_Miles&quot;:9.969555438990687},&quot;geometry&quot;:{&quot;x&quot;:-58.56335967799998,&quot;y&quot;:-34.60122048899996}},{&quot;attributes&quot;:{&quot;ObjectID&quot;:47,&quot;Name&quot;:&quot;MACCHIAAntoniaSM_1195&quot;,&quot;RouteName&quot;:&quot;Chofer4Insitu_6&quot;,&quot;Sequence&quot;:16,&quot;TimeWindowStart&quot;:null,&quot;TimeWindowEnd&quot;:null,&quot;ArriveCurbApproach&quot;:2,&quot;DepartCurbApproach&quot;:2,&quot;SourceID&quot;:1,&quot;SourceOID&quot;:1333946,&quot;PosAlong&quot;:0.030748775639010868,&quot;SideOfEdge&quot;:2,&quot;CurbApproach&quot;:0,&quot;Status&quot;:0,&quot;Attr_Minutes&quot;:0,&quot;Attr_TravelTime&quot;:0,&quot;Attr_Miles&quot;:0,&quot;Attr_Kilometers&quot;:0,&quot;Attr_TimeAt1KPH&quot;:0,&quot;Attr_WalkTime&quot;:0,&quot;Attr_TruckTravelTime&quot;:0,&quot;Cumul_TravelTime&quot;:108.2843042919565,&quot;Cumul_Kilometers&quot;:46.8477493842238,&quot;Cumul_Miles&quot;:29.10984188851098},&quot;geometry&quot;:{&quot;x&quot;:-58.563233613999955,&quot;y&quot;:-34.59690079099994}},{&quot;attributes&quot;:{&quot;ObjectID&quot;:48,&quot;Name&quot;:&quot;MACCHIAAntoniaSM_1034&quot;,&quot;RouteName&quot;:&quot;Chofer4Insitu_6&quot;,&quot;Sequence&quot;:15,&quot;TimeWindowStart&quot;:null,&quot;TimeWindowEnd&quot;:null,&quot;ArriveCurbApproach&quot;:2,&quot;DepartCurbApproach&quot;:2,&quot;SourceID&quot;:1,&quot;SourceOID&quot;:1333946,&quot;PosAlong&quot;:0.030748775639010868,&quot;SideOfEdge&quot;:2,&quot;CurbApproach&quot;:0,&quot;Status&quot;:0,&quot;Attr_Minutes&quot;:0,&quot;Attr_TravelTime&quot;:0,&quot;Attr_Miles&quot;:0,&quot;Attr_Kilometers&quot;:0,&quot;Attr_TimeAt1KPH&quot;:0,&quot;Attr_WalkTime&quot;:0,&quot;Attr_TruckTravelTime&quot;:0,&quot;Cumul_TravelTime&quot;:108.2843042919565,&quot;Cumul_Kilometers&quot;:46.8477493842238,&quot;Cumul_Miles&quot;:29.10984188851098},&quot;geometry&quot;:{&quot;x&quot;:-58.563233613999955,&quot;y&quot;:-34.59690079099994}},{&quot;attributes&quot;:{&quot;ObjectID&quot;:49,&quot;Name&quot;:&quot;SANCHEZIsabel_1010&quot;,&quot;RouteName&quot;:&quot;Chofer4Insitu_6&quot;,&quot;Sequence&quot;:18,&quot;TimeWindowStart&quot;:null,&quot;TimeWindowEnd&quot;:null,&quot;ArriveCurbApproach&quot;:1,&quot;DepartCurbApproach&quot;:1,&quot;SourceID&quot;:1,&quot;SourceOID&quot;:1334043,&quot;PosAlong&quot;:0.6360085258946473,&quot;SideOfEdge&quot;:1,&quot;CurbApproach&quot;:0,&quot;Status&quot;:0,&quot;Attr_Minutes&quot;:0,&quot;Attr_TravelTime&quot;:0,&quot;Attr_Miles&quot;:0,&quot;Attr_Kilometers&quot;:0,&quot;Attr_TimeAt1KPH&quot;:0,&quot;Attr_WalkTime&quot;:0,&quot;Attr_TruckTravelTime&quot;:0,&quot;Cumul_TravelTime&quot;:110.84396586738359,&quot;Cumul_Kilometers&quot;:47.8691638236884,&quot;Cumul_Miles&quot;:29.74451939652953},&quot;geometry&quot;:{&quot;x&quot;:-58.559111058999974,&quot;y&quot;:-34.59421589999994}},{&quot;attributes&quot;:{&quot;ObjectID&quot;:50,&quot;Name&quot;:&quot;SANCHEZIsabel_1171&quot;,&quot;RouteName&quot;:&quot;Chofer4Insitu_6&quot;,&quot;Sequence&quot;:17,&quot;TimeWindowStart&quot;:null,&quot;TimeWindowEnd&quot;:null,&quot;ArriveCurbApproach&quot;:1,&quot;DepartCurbApproach&quot;:1,&quot;SourceID&quot;:1,&quot;SourceOID&quot;:1334043,&quot;PosAlong&quot;:0.6360085258946473,&quot;SideOfEdge&quot;:1,&quot;CurbApproach&quot;:0,&quot;Status&quot;:0,&quot;Attr_Minutes&quot;:0,&quot;Attr_TravelTime&quot;:0,&quot;Attr_Miles&quot;:0,&quot;Attr_Kilometers&quot;:0,&quot;Attr_TimeAt1KPH&quot;:0,&quot;Attr_WalkTime&quot;:0,&quot;Attr_TruckTravelTime&quot;:0,&quot;Cumul_TravelTime&quot;:110.84396586738359,&quot;Cumul_Kilometers&quot;:47.8691638236884,&quot;Cumul_Miles&quot;:29.74451939652953},&quot;geometry&quot;:{&quot;x&quot;:-58.559111058999974,&quot;y&quot;:-34.59421589999994}},{&quot;attributes&quot;:{&quot;ObjectID&quot;:51,&quot;Name&quot;:&quot;ALVAREZNormaSM_1100&quot;,&quot;RouteName&quot;:&quot;Chofer4Insitu_6&quot;,&quot;Sequence&quot;:19,&quot;TimeWindowStart&quot;:null,&quot;TimeWindowEnd&quot;:null,&quot;ArriveCurbApproach&quot;:2,&quot;DepartCurbApproach&quot;:1,&quot;SourceID&quot;:1,&quot;SourceOID&quot;:1334338,&quot;PosAlong&quot;:0.937355791664927,&quot;SideOfEdge&quot;:1,&quot;CurbApproach&quot;:0,&quot;Status&quot;:0,&quot;Attr_Minutes&quot;:0,&quot;Attr_TravelTime&quot;:0,&quot;Attr_Miles&quot;:0,&quot;Attr_Kilometers&quot;:0,&quot;Attr_TimeAt1KPH&quot;:0,&quot;Attr_WalkTime&quot;:0,&quot;Attr_TruckTravelTime&quot;:0,&quot;Cumul_TravelTime&quot;:115.51663438374776,&quot;Cumul_Kilometers&quot;:49.7387632831272,&quot;Cumul_Miles&quot;:30.906234641647295},&quot;geometry&quot;:{&quot;x&quot;:-58.56956765099994,&quot;y&quot;:-34.58766326299997}},{&quot;attributes&quot;:{&quot;ObjectID&quot;:52,&quot;Name&quot;:&quot;PEREAElsa_1046&quot;,&quot;RouteName&quot;:&quot;Chofer4Insitu_6&quot;,&quot;Sequence&quot;:20,&quot;TimeWindowStart&quot;:null,&quot;TimeWindowEnd&quot;:null,&quot;ArriveCurbApproach&quot;:2,&quot;DepartCurbApproach&quot;:2,&quot;SourceID&quot;:1,&quot;SourceOID&quot;:1334398,&quot;PosAlong&quot;:0.8655820675791013,&quot;SideOfEdge&quot;:2,&quot;CurbApproach&quot;:0,&quot;Status&quot;:0,&quot;Attr_Minutes&quot;:0,&quot;Attr_TravelTime&quot;:0,&quot;Attr_Miles&quot;:0,&quot;Attr_Kilometers&quot;:0,&quot;Attr_TimeAt1KPH&quot;:0,&quot;Attr_WalkTime&quot;:0,&quot;Attr_TruckTravelTime&quot;:0,&quot;Cumul_TravelTime&quot;:115.93560375146927,&quot;Cumul_Kilometers&quot;:49.902918252225945,&quot;Cumul_Miles&quot;:31.008235810507863},&quot;geometry&quot;:{&quot;x&quot;:-58.568315058999985,&quot;y&quot;:-34.58662256599996}},{&quot;attributes&quot;:{&quot;ObjectID&quot;:53,&quot;Name&quot;:&quot;PARAREDSM_1062&quot;,&quot;RouteName&quot;:&quot;Chofer4Insitu_6&quot;,&quot;Sequence&quot;:21,&quot;TimeWindowStart&quot;:null,&quot;TimeWindowEnd&quot;:null,&quot;ArriveCurbApproach&quot;:1,&quot;DepartCurbApproach&quot;:null,&quot;SourceID&quot;:1,&quot;SourceOID&quot;:1334618,&quot;PosAlong&quot;:0.5420851523741954,&quot;SideOfEdge&quot;:2,&quot;CurbApproach&quot;:0,&quot;Status&quot;:0,&quot;Attr_Minutes&quot;:0,&quot;Attr_TravelTime&quot;:0,&quot;Attr_Miles&quot;:0,&quot;Attr_Kilometers&quot;:0,&quot;Attr_TimeAt1KPH&quot;:0,&quot;Attr_WalkTime&quot;:0,&quot;Attr_TruckTravelTime&quot;:0,&quot;Cumul_TravelTime&quot;:124.79763503456506,&quot;Cumul_Kilometers&quot;:53.73929766310028,&quot;Cumul_Miles&quot;:33.39205145891761},&quot;geometry&quot;:{&quot;x&quot;:-58.538657873999966,&quot;y&quot;:-34.58060234799996}}]}">
    <textarea id="routes_sync2">{"fieldAliases":{"ObjectID":"ObjectID","Name":"Name","FirstStopID":"FirstStopID","LastStopID":"LastStopID","StopCount":"StopCount","Total_TravelTime":"Total_TravelTime","Total_Kilometers":"Total_Kilometers","Total_Miles":"Total_Miles","Shape_Length":"Shape_Length"},"geometryType":"esriGeometryPolyline","spatialReference":{"wkid":4326,"latestWkid":4326},"features":[{"attributes":{"ObjectID":1,"Name":"Truck_1","FirstStopID":3,"LastStopID":7,"StopCount":5,"Total_TravelTime":139.4225430913946,"Total_Kilometers":22.780896507959152,"Total_Miles":14.155392823385883,"Shape_Length":0.23782702410243908},"geometry":{"paths":[[[-122.48828795699995,37.754089430000079],[-122.48839999999996,37.755570000000034],[-122.48847999999998,37.757100000000037],[-122.48849999999999,37.757450000000063],[-122.48752999999999,37.75750000000005],[-122.48743999999999,37.757510000000025],[-122.48734999999999,37.757510000000025],[-122.48706999999996,37.757530000000031],[-122.48645999999997,37.757560000000069],[-122.48636999999997,37.757560000000069],[-122.48528999999996,37.757600000000025],[-122.48481999999996,37.757620000000031],[-122.48421999999999,37.757640000000038],[-122.48315999999994,37.757700000000057],[-122.48246999999998,37.757720000000063],[-122.48209999999995,37.757730000000038],[-122.48102999999998,37.757780000000025],[-122.47994999999997,37.75783000000007],[-122.47888999999998,37.757870000000025],[-122.47834999999998,37.757880000000057],[-122.47780999999998,37.757890000000032],[-122.47735999999998,37.757910000000038],[-122.47669999999999,37.757940000000076],[-122.47682999999995,37.759830000000079],[-122.47702999999996,37.761700000000076],[-122.47711999999996,37.762510000000077],[-122.47719999999998,37.763560000000041],[-122.47726999999998,37.764630000000068],[-122.47728999999998,37.76487000000003],[-122.47732999999999,37.765440000000069],[-122.47734999999994,37.765730000000076],[-122.47737999999998,37.766040000000032],[-122.47761999999994,37.766720000000078],[-122.47784999999999,37.767030000000034],[-122.47792999999996,37.76714000000004],[-122.47806999999995,37.76738000000006],[-122.47840999999994,37.769060000000025],[-122.47859999999997,37.769630000000063],[-122.47871999999995,37.769860000000051],[-122.47883999999999,37.770060000000058],[-122.47897999999998,37.770310000000052],[-122.47915999999998,37.770640000000071],[-122.47920999999997,37.770730000000071],[-122.47944999999999,37.771180000000072],[-122.47947999999997,37.771480000000054],[-122.47913999999997,37.772080000000074],[-122.47868999999997,37.772270000000049],[-122.47812999999996,37.772320000000036],[-122.47791999999998,37.772330000000068],[-122.47772999999995,37.772340000000042],[-122.47742999999997,37.77237000000008],[-122.47494999999998,37.772560000000055],[-122.47277999999994,37.772380000000055],[-122.47205999999994,37.772490000000062],[-122.47176999999999,37.772960000000069],[-122.47176999999999,37.773050000000069],[-122.47177999999997,37.773130000000037],[-122.47154999999998,37.773140000000069],[-122.47123999999997,37.773150000000044],[-122.46999999999997,37.773220000000038],[-122.46749999999997,37.773320000000069],[-122.46599999999995,37.773380000000031],[-122.46587999999997,37.773380000000031],[-122.46482999999995,37.773490000000038],[-122.46491737399998,37.774719957000059],[-122.46482999999995,37.773490000000038],[-122.46387999999996,37.773600000000044],[-122.46375999999998,37.773610000000076],[-122.46365999999995,37.773620000000051],[-122.46250999999995,37.773780000000045],[-122.46161999999998,37.773890000000051],[-122.46090999999996,37.773990000000026],[-122.46057999999999,37.774030000000039],[-122.45948999999996,37.774170000000026],[-122.45834999999994,37.774290000000065],[-122.45672999999999,37.774490000000071],[-122.45465999999999,37.77475000000004],[-122.45448999999996,37.77386000000007],[-122.45423999999997,37.77257000000003],[-122.45406999999994,37.771970000000067],[-122.45405999999997,37.771890000000042],[-122.45400999999998,37.771640000000048],[-122.45397999999994,37.771480000000054],[-122.45396,37.771350000000041],[-122.45383999999996,37.771400000000028],[-122.45221999999995,37.77123000000006],[-122.44156999999996,37.772600000000068],[-122.43907999999999,37.772910000000024],[-122.43798999999996,37.773060000000044],[-122.43742999999995,37.773140000000069],[-122.43576999999999,37.773330000000044],[-122.43409999999994,37.773540000000025],[-122.43245999999999,37.773750000000064],[-122.43153999999998,37.773870000000045],[-122.43080999999995,37.773970000000077],[-122.42912999999999,37.774170000000026],[-122.42753999999996,37.774400000000071],[-122.42743999999999,37.773920000000032],[-122.42734999999999,37.773450000000025],[-122.42726999999996,37.773130000000037],[-122.42725999999999,37.773000000000025],[-122.42716999999999,37.772530000000074],[-122.42706999999996,37.772070000000042],[-122.42696999999998,37.771610000000067],[-122.42677999999995,37.770670000000052],[-122.42512999999997,37.770880000000034],[-122.42485999999997,37.770750000000078],[-122.42581999999999,37.77010000000007],[-122.42598999999996,37.769970000000058],[-122.42639999999994,37.769630000000063],[-122.42667999999998,37.769390000000044],[-122.42682704499998,37.769268528000055],[-122.42690999999996,37.769200000000069],[-122.42689999999999,37.769020000000069],[-122.42674,37.769150000000025],[-122.42646999999999,37.769370000000038],[-122.42612999999994,37.769640000000038],[-122.42591999999996,37.769660000000044],[-122.42525999999998,37.769700000000057],[-122.42458999999997,37.76974000000007],[-122.42350999999996,37.769810000000064],[-122.42314999999996,37.76983000000007],[-122.42235999999997,37.769870000000026],[-122.42157999999995,37.769910000000039],[-122.42066999999997,37.769970000000058],[-122.42046999999997,37.769990000000064],[-122.42017999999996,37.769990000000064],[-122.41991999999999,37.769980000000032],[-122.41945999999996,37.769970000000058],[-122.41903999999994,37.76992000000007],[-122.41821999999996,37.769790000000057],[-122.41800999999998,37.769630000000063],[-122.41782999999998,37.769370000000038],[-122.41823999999997,37.768900000000031],[-122.41886,37.768990000000031],[-122.41900999999996,37.76932000000005],[-122.41886999999997,37.769580000000076],[-122.41850999999997,37.769720000000063],[-122.41777999999999,37.76965000000007],[-122.41728999999998,37.769660000000044],[-122.41636999999997,37.769550000000038],[-122.41599999999994,37.769530000000032],[-122.41558999999995,37.769520000000057],[-122.41446999999999,37.769490000000076],[-122.41405999999995,37.769480000000044],[-122.41340999999994,37.769450000000063],[-122.41246999999998,37.769440000000031],[-122.41196999999994,37.769420000000025],[-122.41155999999995,37.769400000000076],[-122.41110999999995,37.769350000000031],[-122.41081999999994,37.769310000000075],[-122.41044999999997,37.769260000000031],[-122.40924999999999,37.76905000000005],[-122.40782999999999,37.768790000000024],[-122.40749999999997,37.768750000000068],[-122.40661999999998,37.768480000000068],[-122.40640999999999,37.768370000000061],[-122.40577999999999,37.767920000000061],[-122.40547999999995,37.767370000000028],[-122.40525999999994,37.766240000000039],[-122.40522999999996,37.765910000000076],[-122.40513999999996,37.764970000000062],[-122.40510999999998,37.764650000000074],[-122.40516999999994,37.763630000000035],[-122.40542999999997,37.762900000000059],[-122.40582999999998,37.762200000000064],[-122.40595999999999,37.761990000000026],[-122.40643999999998,37.760950000000037],[-122.40633999999994,37.759670000000028],[-122.40573999999998,37.758750000000077],[-122.40372999999994,37.757010000000037],[-122.40335999999996,37.756200000000035],[-122.40315999999996,37.754650000000026],[-122.40313999999995,37.75434000000007],[-122.40300999999999,37.752540000000067],[-122.40307999999999,37.751810000000035],[-122.40350999999998,37.750330000000076],[-122.40377999999998,37.749500000000069],[-122.40381999999994,37.749380000000031],[-122.40389999999996,37.749140000000068],[-122.40391999999997,37.749060000000043],[-122.40403999999995,37.748620000000074],[-122.40419999999995,37.748160000000041],[-122.40445999999997,37.747310000000027],[-122.40519999999998,37.745000000000061],[-122.40577999999999,37.743960000000072],[-122.40734999999995,37.741990000000044],[-122.40766999999994,37.741370000000074],[-122.40792999999996,37.740630000000067],[-122.40824999999995,37.73965000000004],[-122.40822999999995,37.73720000000003],[-122.40845999999999,37.736360000000047],[-122.40917999999999,37.735390000000052],[-122.41000999999994,37.734680000000026],[-122.41102999999998,37.734070000000031],[-122.41210999999998,37.733500000000049],[-122.41329999999999,37.732910000000061],[-122.41462999999999,37.73237000000006],[-122.41594999999995,37.732090000000028],[-122.41995999999995,37.732020000000034],[-122.42360999999994,37.731560000000059],[-122.42476999999997,37.731530000000078],[-122.43062999999995,37.732360000000028],[-122.43196999999998,37.732260000000053],[-122.43536999999998,37.731610000000046],[-122.43589999999995,37.731560000000059],[-122.43651999999997,37.731580000000065],[-122.43720999999999,37.73159000000004],[-122.43744999999996,37.73159000000004],[-122.43787999999995,37.73159000000004],[-122.44074999999998,37.731600000000071],[-122.44095999999996,37.731600000000071],[-122.44427999999999,37.731560000000059],[-122.44840999999997,37.731550000000027],[-122.44886999999994,37.731550000000027],[-122.44887377399999,37.731840587000079],[-122.44886999999994,37.731550000000027],[-122.44917999999996,37.731550000000027],[-122.44939999999997,37.731550000000027],[-122.44962999999996,37.731550000000027],[-122.45112999999998,37.731540000000052],[-122.45339999999999,37.731520000000046],[-122.45365999999996,37.731520000000046],[-122.45576999999997,37.731370000000027],[-122.45750999999996,37.730990000000077],[-122.45763999999997,37.730990000000077],[-122.45791999999994,37.730930000000058],[-122.45811999999995,37.730890000000045],[-122.45837999999998,37.730860000000064],[-122.45889999999997,37.730850000000032],[-122.45928999999995,37.730840000000057],[-122.46038999999996,37.730550000000051],[-122.46058999999997,37.730420000000038],[-122.46135999999996,37.730040000000031],[-122.46222999999998,37.730120000000056],[-122.46327999999994,37.730670000000032],[-122.46369999999996,37.731480000000033],[-122.46375999999998,37.731580000000065],[-122.46411999999998,37.732060000000047],[-122.46533999999997,37.732940000000042],[-122.46564999999998,37.733190000000036],[-122.46584999999999,37.733400000000074],[-122.46608999999995,37.733840000000043],[-122.46614999999997,37.734010000000069],[-122.46625999999998,37.734950000000026],[-122.46648999999996,37.734940000000051],[-122.46714999999995,37.734900000000039],[-122.46779999999995,37.734880000000032],[-122.46798999999999,37.734970000000033],[-122.46812999999997,37.734870000000058],[-122.47099999999995,37.73473000000007],[-122.47119999999995,37.73473000000007],[-122.47152999999997,37.734760000000051],[-122.47175999999996,37.734800000000064],[-122.47325999999998,37.734770000000026],[-122.47453999999999,37.734740000000045],[-122.47512999999998,37.734720000000038],[-122.47521999999998,37.736010000000078],[-122.47525999999999,37.736720000000048],[-122.47538999999995,37.738660000000039],[-122.47539999999998,37.738790000000051],[-122.47540999999995,37.738960000000077],[-122.47542999999996,37.739310000000046],[-122.47556999999995,37.741190000000074],[-122.47565999999995,37.743030000000033],[-122.47462999999999,37.743100000000027],[-122.47355999999996,37.743150000000071],[-122.47359318499997,37.743624799000031]]]}},{"attributes":{"ObjectID":2,"Name":"Truck_2","FirstStopID":1,"LastStopID":2,"StopCount":2,"Total_TravelTime":34.475912487079142,"Total_Kilometers":3.9105423293230346,"Total_Miles":2.4298983494660158,"Shape_Length":0.042193453151630693},"geometry":{"paths":[[[-122.47359318499997,37.743624799000031],[-122.47355999999996,37.743150000000071],[-122.47274999999996,37.743180000000052],[-122.47225999999995,37.743200000000058],[-122.47166999999996,37.74323000000004],[-122.47022999999996,37.743290000000059],[-122.46915999999999,37.743340000000046],[-122.46402999999998,37.743740000000059],[-122.46392999999995,37.743750000000034],[-122.46372999999994,37.743560000000059],[-122.46350999999999,37.743690000000072],[-122.46355999999997,37.743880000000047],[-122.46350999999999,37.74392000000006],[-122.46300999999994,37.744300000000067],[-122.46035999999998,37.746360000000038],[-122.45952999999997,37.747010000000046],[-122.45928999999995,37.747200000000078],[-122.45918999999998,37.747270000000071],[-122.45886999999999,37.746890000000064],[-122.45849999999996,37.746800000000064],[-122.45716999999996,37.746690000000058],[-122.45463999999998,37.746100000000069],[-122.45389999999998,37.745700000000056],[-122.45332999999999,37.745630000000062],[-122.45269999999999,37.745650000000069],[-122.45215999999999,37.745660000000044],[-122.45177999999999,37.74559000000005],[-122.45160999999996,37.745480000000043],[-122.45117999999997,37.745620000000031],[-122.45022999999998,37.745890000000031],[-122.44978999999995,37.74595000000005],[-122.44867999999997,37.746160000000032],[-122.44825999999995,37.746260000000063],[-122.44741999999997,37.746470000000045],[-122.44667999999996,37.74664000000007],[-122.44579999999996,37.746790000000033],[-122.44469999999995,37.746680000000026],[-122.44446999999997,37.746660000000077],[-122.44421999999997,37.746700000000033],[-122.44400999999999,37.746760000000052],[-122.44389999999999,37.746840000000077],[-122.44372999999996,37.746990000000039],[-122.44352999999995,37.747190000000046],[-122.44331999999997,37.747400000000027],[-122.44313999999997,37.747590000000059],[-122.44294999999994,37.747760000000028],[-122.44266999999996,37.748010000000079],[-122.44252999999998,37.74813000000006],[-122.44206999999994,37.748410000000035],[-122.44134999999994,37.748620000000074],[-122.44006999999999,37.74864000000008],[-122.43960999999996,37.74864000000008],[-122.43864999999994,37.748660000000029],[-122.43843999999996,37.748660000000029],[-122.43824999999998,37.748660000000029],[-122.43813999999998,37.747830000000079],[-122.43806999999998,37.747040000000027],[-122.43801999999999,37.746320000000026],[-122.43800999999996,37.746240000000057],[-122.43921999999998,37.746170000000063]]]}}]}</textarea>
    <textarea id="routes_sync">{"fieldAliases":{"ObjectID":"ObjectID","Name":"Name","FirstStopID":"FirstStopID","LastStopID":"LastStopID","StopCount":"StopCount","Total_TravelTime":"Total_TravelTime","Total_Kilometers":"Total_Kilometers","Total_Miles":"Total_Miles","Shape_Length":"Shape_Length"},"geometryType":"esriGeometryPolyline","spatialReference":{"wkid":4326,"latestWkid":4326},"features":[{"attributes":{"ObjectID":1,"Name":"Truck_1","FirstStopID":1,"LastStopID":7,"StopCount":7,"Total_TravelTime":176.80624391071112,"Total_Kilometers":22.01418772880416,"Total_Miles":13.678982075183528,"Shape_Length":0.22677712934548278},"geometry":{"paths":[[[-122.42682704499998,37.769268528000055],[-122.42690999999996,37.769200000000069],[-122.42808999999994,37.768290000000036],[-122.42829999999998,37.768130000000042],[-122.42882999999995,37.767710000000079],[-122.42893999999995,37.767610000000047],[-122.43047999999999,37.766390000000058],[-122.43121999999994,37.765790000000038],[-122.43228999999997,37.764930000000049],[-122.43258999999995,37.76469000000003],[-122.43382999999994,37.763740000000041],[-122.43402999999995,37.763580000000047],[-122.43469999999996,37.763030000000072],[-122.43515999999994,37.762640000000033],[-122.43587999999994,37.76231000000007],[-122.43623999999994,37.762140000000045],[-122.43729999999999,37.761900000000026],[-122.43718999999999,37.760740000000055],[-122.43716999999998,37.76055000000008],[-122.43708999999996,37.759840000000054],[-122.43706999999995,37.759620000000041],[-122.43701999999996,37.759150000000034],[-122.43693999999999,37.758090000000038],[-122.43688999999995,37.757560000000069],[-122.43673999999999,37.755970000000048],[-122.43658999999997,37.754360000000077],[-122.43649999999997,37.753540000000044],[-122.43643999999995,37.752770000000055],[-122.43636999999995,37.75198000000006],[-122.43629999999996,37.751160000000027],[-122.43622999999997,37.750360000000057],[-122.43613999999997,37.749550000000056],[-122.43606999999997,37.748780000000068],[-122.43806999999998,37.748670000000061],[-122.43824999999998,37.748660000000029],[-122.43813999999998,37.747830000000079],[-122.43806999999998,37.747040000000027],[-122.43801999999999,37.746320000000026],[-122.43800999999996,37.746240000000057],[-122.43921999999998,37.746170000000063],[-122.43800999999996,37.746240000000057],[-122.43792999999999,37.745430000000056],[-122.44010999999995,37.745310000000075],[-122.43991999999997,37.744870000000049],[-122.43954999999994,37.74461000000008],[-122.43872999999996,37.744140000000073],[-122.43748999999997,37.743400000000065],[-122.43733999999995,37.743310000000065],[-122.43654999999995,37.742760000000033],[-122.43606999999997,37.742210000000057],[-122.43578999999994,37.741760000000056],[-122.43562999999995,37.741510000000062],[-122.43550999999997,37.74114000000003],[-122.43550999999997,37.74094000000008],[-122.43565999999998,37.740490000000079],[-122.43572999999998,37.740350000000035],[-122.43581999999998,37.74016000000006],[-122.43601999999998,37.739850000000047],[-122.43640999999997,37.739220000000046],[-122.43649999999997,37.739070000000027],[-122.43694999999997,37.738470000000063],[-122.43734999999998,37.738300000000038],[-122.43809999999996,37.738390000000038],[-122.43845999999996,37.738460000000032],[-122.43868999999995,37.738510000000076],[-122.43989999999997,37.738600000000076],[-122.44015999999999,37.738100000000031],[-122.43993999999998,37.737770000000069],[-122.43969999999996,37.737190000000055],[-122.43972999999994,37.73553000000004],[-122.43995999999999,37.734870000000058],[-122.44034999999997,37.734810000000039],[-122.44106999999997,37.734980000000064],[-122.44114999999999,37.734780000000057],[-122.44077999999996,37.734400000000051],[-122.44111999999996,37.734400000000051],[-122.44200999999998,37.734410000000025],[-122.44201999999996,37.733830000000069],[-122.44202999999999,37.733080000000029],[-122.44202999999999,37.732330000000047],[-122.44202999999999,37.73159000000004],[-122.44427999999999,37.731560000000059],[-122.44840999999997,37.731550000000027],[-122.44886999999994,37.731550000000027],[-122.44887377399999,37.731840587000079],[-122.44886999999994,37.731550000000027],[-122.44917999999996,37.731550000000027],[-122.44939999999997,37.731550000000027],[-122.44962999999996,37.731550000000027],[-122.45112999999998,37.731540000000052],[-122.45339999999999,37.731520000000046],[-122.45365999999996,37.731520000000046],[-122.45576999999997,37.731370000000027],[-122.45750999999996,37.730990000000077],[-122.45763999999997,37.730990000000077],[-122.45791999999994,37.730930000000058],[-122.45811999999995,37.730890000000045],[-122.45837999999998,37.730860000000064],[-122.45889999999997,37.730850000000032],[-122.45928999999995,37.730840000000057],[-122.46038999999996,37.730550000000051],[-122.46058999999997,37.730420000000038],[-122.46135999999996,37.730040000000031],[-122.46222999999998,37.730120000000056],[-122.46327999999994,37.730670000000032],[-122.46369999999996,37.731480000000033],[-122.46375999999998,37.731580000000065],[-122.46411999999998,37.732060000000047],[-122.46533999999997,37.732940000000042],[-122.46564999999998,37.733190000000036],[-122.46584999999999,37.733400000000074],[-122.46608999999995,37.733840000000043],[-122.46614999999997,37.734010000000069],[-122.46625999999998,37.734950000000026],[-122.46648999999996,37.734940000000051],[-122.46714999999995,37.734900000000039],[-122.46779999999995,37.734880000000032],[-122.46798999999999,37.734970000000033],[-122.46812999999997,37.734870000000058],[-122.47099999999995,37.73473000000007],[-122.47119999999995,37.73473000000007],[-122.47152999999997,37.734760000000051],[-122.47175999999996,37.734800000000064],[-122.47325999999998,37.734770000000026],[-122.47453999999999,37.734740000000045],[-122.47512999999998,37.734720000000038],[-122.47521999999998,37.736010000000078],[-122.47525999999999,37.736720000000048],[-122.47538999999995,37.738660000000039],[-122.47539999999998,37.738790000000051],[-122.47540999999995,37.738960000000077],[-122.47542999999996,37.739310000000046],[-122.47556999999995,37.741190000000074],[-122.47565999999995,37.743030000000033],[-122.47462999999999,37.743100000000027],[-122.47355999999996,37.743150000000071],[-122.47359318499997,37.743624799000031],[-122.47368999999998,37.745010000000036],[-122.47383999999994,37.746850000000052],[-122.47487999999998,37.746810000000039],[-122.47499999999997,37.748690000000067],[-122.47604999999999,37.74864000000008],[-122.47715999999997,37.748590000000036],[-122.47826999999995,37.748540000000048],[-122.47929999999997,37.748490000000061],[-122.48036999999999,37.748440000000073],[-122.48145,37.748410000000035],[-122.48150999999996,37.749250000000075],[-122.48158999999998,37.750280000000032],[-122.48166999999995,37.751370000000065],[-122.48171999999994,37.75198000000006],[-122.48172999999997,37.752140000000054],[-122.48187999999999,37.752140000000054],[-122.48277999999999,37.752110000000073],[-122.48383999999999,37.752060000000029],[-122.48394999999999,37.752060000000029],[-122.48493999999999,37.752010000000041],[-122.48524999999995,37.75198000000006],[-122.48546999999996,37.751970000000028],[-122.48580999999996,37.751950000000079],[-122.48597999999998,37.751940000000047],[-122.48705999999999,37.75189000000006],[-122.48811999999998,37.751860000000079],[-122.48825999999997,37.753720000000044],[-122.48828795699995,37.754089430000079],[-122.48839999999996,37.755570000000034],[-122.48847999999998,37.757100000000037],[-122.48849999999999,37.757450000000063],[-122.48752999999999,37.75750000000005],[-122.48743999999999,37.757510000000025],[-122.48734999999999,37.757510000000025],[-122.48706999999996,37.757530000000031],[-122.48645999999997,37.757560000000069],[-122.48636999999997,37.757560000000069],[-122.48528999999996,37.757600000000025],[-122.48481999999996,37.757620000000031],[-122.48421999999999,37.757640000000038],[-122.48315999999994,37.757700000000057],[-122.48246999999998,37.757720000000063],[-122.48209999999995,37.757730000000038],[-122.48102999999998,37.757780000000025],[-122.47994999999997,37.75783000000007],[-122.47888999999998,37.757870000000025],[-122.47834999999998,37.757880000000057],[-122.47780999999998,37.757890000000032],[-122.47735999999998,37.757910000000038],[-122.47669999999999,37.757940000000076],[-122.47682999999995,37.759830000000079],[-122.47702999999996,37.761700000000076],[-122.47711999999996,37.762510000000077],[-122.47719999999998,37.763560000000041],[-122.47726999999998,37.764630000000068],[-122.47728999999998,37.76487000000003],[-122.47732999999999,37.765440000000069],[-122.47734999999994,37.765730000000076],[-122.47737999999998,37.766040000000032],[-122.47761999999994,37.766720000000078],[-122.47784999999999,37.767030000000034],[-122.47792999999996,37.76714000000004],[-122.47806999999995,37.76738000000006],[-122.47840999999994,37.769060000000025],[-122.47859999999997,37.769630000000063],[-122.47871999999995,37.769860000000051],[-122.47883999999999,37.770060000000058],[-122.47897999999998,37.770310000000052],[-122.47915999999998,37.770640000000071],[-122.47920999999997,37.770730000000071],[-122.47944999999999,37.771180000000072],[-122.47947999999997,37.771480000000054],[-122.47913999999997,37.772080000000074],[-122.47868999999997,37.772270000000049],[-122.47812999999996,37.772320000000036],[-122.47791999999998,37.772330000000068],[-122.47772999999995,37.772340000000042],[-122.47742999999997,37.77237000000008],[-122.47494999999998,37.772560000000055],[-122.47277999999994,37.772380000000055],[-122.47205999999994,37.772490000000062],[-122.47176999999999,37.772960000000069],[-122.47176999999999,37.773050000000069],[-122.47177999999997,37.773130000000037],[-122.47154999999998,37.773140000000069],[-122.47123999999997,37.773150000000044],[-122.46999999999997,37.773220000000038],[-122.46749999999997,37.773320000000069],[-122.46599999999995,37.773380000000031],[-122.46587999999997,37.773380000000031],[-122.46482999999995,37.773490000000038],[-122.46491737399998,37.774719957000059],[-122.46482999999995,37.773490000000038],[-122.46387999999996,37.773600000000044],[-122.46375999999998,37.773610000000076],[-122.46365999999995,37.773620000000051],[-122.46250999999995,37.773780000000045],[-122.46161999999998,37.773890000000051],[-122.46090999999996,37.773990000000026],[-122.46057999999999,37.774030000000039],[-122.45948999999996,37.774170000000026],[-122.45834999999994,37.774290000000065],[-122.45672999999999,37.774490000000071],[-122.45465999999999,37.77475000000004],[-122.45448999999996,37.77386000000007],[-122.45423999999997,37.77257000000003],[-122.45406999999994,37.771970000000067],[-122.45405999999997,37.771890000000042],[-122.45400999999998,37.771640000000048],[-122.45397999999994,37.771480000000054],[-122.45396,37.771350000000041],[-122.45383999999996,37.771400000000028],[-122.45221999999995,37.77123000000006],[-122.44156999999996,37.772600000000068],[-122.43907999999999,37.772910000000024],[-122.43798999999996,37.773060000000044],[-122.43742999999995,37.773140000000069],[-122.43576999999999,37.773330000000044],[-122.43409999999994,37.773540000000025],[-122.43245999999999,37.773750000000064],[-122.43153999999998,37.773870000000045],[-122.43080999999995,37.773970000000077],[-122.42912999999999,37.774170000000026],[-122.42753999999996,37.774400000000071],[-122.42743999999999,37.773920000000032],[-122.42734999999999,37.773450000000025],[-122.42726999999996,37.773130000000037],[-122.42725999999999,37.773000000000025],[-122.42716999999999,37.772530000000074],[-122.42706999999996,37.772070000000042],[-122.42696999999998,37.771610000000067],[-122.42677999999995,37.770670000000052],[-122.42512999999997,37.770880000000034],[-122.42485999999997,37.770750000000078],[-122.42581999999999,37.77010000000007],[-122.42598999999996,37.769970000000058],[-122.42639999999994,37.769630000000063],[-122.42667999999998,37.769390000000044],[-122.42682704499998,37.769268528000055]]]}}]}</textarea>
    <textarea id="routes">{"paramName":"out_routes","dataType":"GPFeatureRecordSetLayer","value":{"displayFieldName":"","geometryType":"esriGeometryPolyline","spatialReference":{"wkid":4326,"latestWkid":4326},"fields":[{"name":"ObjectID","type":"esriFieldTypeOID","alias":"ObjectID"},{"name":"Name","type":"esriFieldTypeString","alias":"Name","length":128},{"name":"ViolatedConstraints","type":"esriFieldTypeInteger","alias":"ViolatedConstraints"},{"name":"OrderCount","type":"esriFieldTypeInteger","alias":"OrderCount"},{"name":"TotalCost","type":"esriFieldTypeDouble","alias":"TotalCost"},{"name":"RegularTimeCost","type":"esriFieldTypeDouble","alias":"RegularTimeCost"},{"name":"OvertimeCost","type":"esriFieldTypeDouble","alias":"OvertimeCost"},{"name":"DistanceCost","type":"esriFieldTypeDouble","alias":"DistanceCost"},{"name":"TotalTime","type":"esriFieldTypeDouble","alias":"TotalTime"},{"name":"TotalOrderServiceTime","type":"esriFieldTypeDouble","alias":"TotalOrderServiceTime"},{"name":"TotalBreakServiceTime","type":"esriFieldTypeDouble","alias":"TotalBreakServiceTime"},{"name":"TotalTravelTime","type":"esriFieldTypeDouble","alias":"TotalTravelTime"},{"name":"TotalDistance","type":"esriFieldTypeDouble","alias":"TotalDistance"},{"name":"StartTime","type":"esriFieldTypeDate","alias":"StartTime","length":16},{"name":"EndTime","type":"esriFieldTypeDate","alias":"EndTime","length":16},{"name":"TotalWaitTime","type":"esriFieldTypeDouble","alias":"TotalWaitTime"},{"name":"TotalViolationTime","type":"esriFieldTypeDouble","alias":"TotalViolationTime"},{"name":"RenewalCount","type":"esriFieldTypeInteger","alias":"RenewalCount"},{"name":"TotalRenewalServiceTime","type":"esriFieldTypeDouble","alias":"TotalRenewalServiceTime"},{"name":"Shape_Length","type":"esriFieldTypeDouble","alias":"Shape_Length"}],"features":[{"attributes":{"ObjectID":1,"Name":"Truck_1","ViolatedConstraints":null,"OrderCount":2,"TotalCost":61.372967743908021,"RegularTimeCost":29.170764600858092,"OvertimeCost":0,"DistanceCost":32.202203143049928,"TotalTime":145.85382300429046,"TotalOrderServiceTime":38,"TotalBreakServiceTime":0,"TotalTravelTime":47.853823004290462,"TotalDistance":21.468135428699952,"StartTime":1355241600000,"EndTime":1355250351229,"TotalWaitTime":0,"TotalViolationTime":0,"RenewalCount":0,"TotalRenewalServiceTime":0,"Shape_Length":0.35199405937070793},"geometry":{"paths":[[[-122.39476499999995,37.796235000000024],[-122.39485999999999,37.796330000000069],[-122.39498999999995,37.796470000000056],[-122.39528999999999,37.796780000000069],[-122.39555999999999,37.796640000000025],[-122.39544999999998,37.796510000000069],[-122.39527999999996,37.796320000000037],[-122.39521999999999,37.796250000000043],[-122.39430999999996,37.794990000000041],[-122.39374999999995,37.79454000000004],[-122.39337999999998,37.794330000000059],[-122.39274999999998,37.793840000000046],[-122.39262999999994,37.793710000000033],[-122.39249999999998,37.793600000000026],[-122.39218999999997,37.793320000000051],[-122.39157999999998,37.792800000000057],[-122.39135999999996,37.792580000000044],[-122.39119999999997,37.792330000000049],[-122.39071999999999,37.791280000000029],[-122.39015999999998,37.790760000000034],[-122.39001999999999,37.790650000000028],[-122.38956999999999,37.790290000000027],[-122.38877999999994,37.789670000000058],[-122.38860999999997,37.789500000000032],[-122.38818999999995,37.788770000000056],[-122.38809999999995,37.788470000000075],[-122.38796999999994,37.787460000000067],[-122.38800999999995,37.787090000000035],[-122.38807999999995,37.786180000000058],[-122.38814999999994,37.785330000000044],[-122.38818999999995,37.784780000000069],[-122.38827999999995,37.783590000000061],[-122.38829999999996,37.783170000000041],[-122.38833999999997,37.782670000000053],[-122.38834999999995,37.782550000000072],[-122.38840999999996,37.781810000000064],[-122.38848999999999,37.78123000000005],[-122.38881999999995,37.780660000000069],[-122.38925999999998,37.780280000000062],[-122.38948999999997,37.780110000000036],[-122.38969999999995,37.779960000000074],[-122.38987999999995,37.779820000000029],[-122.39039999999994,37.779410000000041],[-122.39056999999997,37.779270000000054],[-122.39132999999998,37.778680000000065],[-122.39194999999995,37.778200000000027],[-122.39354999999995,37.776920000000075],[-122.39414999999997,37.776430000000062],[-122.39484999999996,37.77586000000008],[-122.39607999999998,37.774870000000078],[-122.39634999999998,37.77466000000004],[-122.39763999999997,37.773650000000032],[-122.39793999999995,37.773270000000025],[-122.39811999999995,37.772700000000043],[-122.39812999999998,37.772350000000074],[-122.39786999999995,37.770380000000046],[-122.39761999999996,37.769270000000063],[-122.39713999999998,37.768490000000043],[-122.39640999999995,37.767720000000054],[-122.39623999999998,37.767590000000041],[-122.39577999999995,37.767250000000047],[-122.39433999999994,37.766110000000026],[-122.39355999999998,37.765170000000069],[-122.39340999999996,37.764920000000075],[-122.39317999999997,37.76451000000003],[-122.39301999999998,37.764080000000035],[-122.39292999999998,37.763770000000079],[-122.39256999999998,37.760650000000055],[-122.39252999999997,37.760250000000042],[-122.39247999999998,37.759400000000028],[-122.39248999999995,37.757700000000057],[-122.39246999999995,37.757010000000037],[-122.39243999999997,37.756210000000067],[-122.39222999999998,37.755170000000078],[-122.39210999999995,37.754840000000058],[-122.39200999999997,37.754570000000058],[-122.39173999999997,37.753680000000031],[-122.39157999999998,37.752620000000036],[-122.39162999999996,37.751920000000041],[-122.39193999999998,37.750860000000046],[-122.39217999999994,37.750320000000045],[-122.39228999999995,37.750060000000076],[-122.39362999999997,37.747300000000052],[-122.39519999999999,37.744910000000061],[-122.39578999999998,37.744290000000035],[-122.39633999999995,37.743650000000059],[-122.39676999999995,37.743180000000052],[-122.39699999999999,37.742920000000026],[-122.39743999999996,37.742440000000045],[-122.39801999999997,37.741790000000037],[-122.39858999999996,37.741160000000036],[-122.39911999999998,37.740540000000067],[-122.39969999999994,37.739930000000072],[-122.40025999999995,37.73929000000004],[-122.40083999999996,37.738680000000045],[-122.40145999999999,37.738060000000075],[-122.40192999999999,37.737650000000031],[-122.40205999999995,37.737550000000056],[-122.40215999999998,37.737480000000062],[-122.40226999999999,37.737400000000036],[-122.40419999999995,37.736280000000079],[-122.40675999999996,37.735330000000033],[-122.40855999999997,37.734950000000026],[-122.41055999999998,37.734280000000069],[-122.41102999999998,37.734070000000031],[-122.41210999999998,37.733500000000049],[-122.41329999999999,37.732910000000061],[-122.41414999999995,37.73255000000006],[-122.41594999999995,37.732090000000028],[-122.41995999999995,37.732020000000034],[-122.42360999999994,37.731560000000059],[-122.42476999999997,37.731530000000078],[-122.43062999999995,37.732360000000028],[-122.43196999999998,37.732260000000053],[-122.43536999999998,37.731610000000046],[-122.43589999999995,37.731560000000059],[-122.43651999999997,37.731580000000065],[-122.43720999999999,37.73159000000004],[-122.43744999999996,37.73159000000004],[-122.43787999999995,37.73159000000004],[-122.44074999999998,37.731600000000071],[-122.44095999999996,37.731600000000071],[-122.44427999999999,37.731560000000059],[-122.44840999999997,37.731550000000027],[-122.44886999999994,37.731550000000027],[-122.44917999999996,37.731550000000027],[-122.44929999999999,37.731550000000027]],[[-122.44929999999999,37.731550000000027],[-122.44939999999997,37.731550000000027],[-122.44962999999996,37.731550000000027],[-122.45112999999998,37.731540000000052],[-122.45112999999998,37.730660000000057],[-122.45111999999995,37.729860000000031],[-122.45116999999999,37.729050000000029],[-122.45120999999995,37.728350000000034],[-122.45162999999997,37.728350000000034],[-122.45224999999999,37.72825000000006],[-122.45229999999998,37.728200000000072],[-122.45237999999995,37.727770000000078],[-122.45237999999995,37.727320000000077],[-122.45236999999997,37.726330000000075],[-122.45235999999994,37.725750000000062],[-122.45235999999994,37.725620000000049],[-122.45235999999994,37.725160000000074],[-122.45235999999994,37.724720000000048],[-122.45235999999994,37.724530000000073],[-122.45235999999994,37.724200000000053],[-122.45233999999999,37.723380000000077],[-122.45232999999996,37.723070000000064],[-122.45162999999997,37.722640000000069],[-122.45127999999994,37.722500000000025],[-122.45027999999996,37.722110000000043],[-122.45011999999997,37.722080000000062],[-122.44973999999996,37.721920000000068],[-122.44919999999996,37.721700000000055],[-122.44841999999994,37.72142000000008],[-122.44846999999999,37.721090000000061],[-122.44849999999997,37.720760000000041],[-122.44852999999995,37.720320000000072],[-122.44839999999999,37.719740000000058],[-122.44842999999997,37.719500000000039],[-122.44854999999995,37.71855000000005],[-122.44856999999996,37.718350000000044],[-122.44874999999996,37.717340000000036],[-122.44912999999997,37.716440000000034],[-122.44955999999996,37.715810000000033],[-122.45036999999996,37.715020000000038],[-122.45151999999996,37.714030000000037],[-122.45283999999998,37.712920000000054],[-122.45408999999995,37.711890000000039],[-122.45531999999997,37.711200000000076],[-122.45673999999997,37.710750000000075],[-122.45799999999997,37.710600000000056],[-122.46254999999996,37.710570000000075],[-122.46449999999999,37.710500000000025],[-122.46564999999998,37.710290000000043],[-122.46698999999995,37.709930000000043],[-122.46721999999994,37.709810000000061],[-122.46841999999998,37.708920000000035],[-122.46882999999997,37.708570000000066],[-122.46900999999997,37.708410000000072],[-122.46913999999998,37.708290000000034],[-122.47050999999999,37.707100000000025],[-122.47081999999995,37.706770000000063],[-122.47094999999996,37.70602000000008],[-122.47086999999999,37.705490000000054],[-122.47079999999994,37.705110000000047],[-122.47103999999996,37.705100000000073],[-122.47122999999999,37.705090000000041],[-122.47142999999994,37.705070000000035],[-122.47171999999995,37.705030000000079],[-122.47332999999998,37.704700000000059],[-122.47373999999996,37.704610000000059],[-122.47411999999997,37.704530000000034],[-122.47429999999997,37.704490000000078],[-122.47470999999996,37.704390000000046],[-122.47505999999998,37.704310000000078],[-122.48103999999995,37.702570000000037],[-122.48127999999997,37.702490000000068],[-122.48229999999995,37.702180000000055],[-122.48252999999994,37.702110000000062],[-122.48279999999994,37.702030000000036],[-122.48330999999996,37.701890000000049],[-122.48347999999999,37.701840000000061],[-122.48342999999994,37.70172000000008],[-122.48322272599995,37.70119109400008]],[[-122.48322272599995,37.70119109400008],[-122.48342999999994,37.70172000000008],[-122.48325999999997,37.701770000000067],[-122.48300999999998,37.701850000000036],[-122.48274999999995,37.701930000000061],[-122.48222999999996,37.70210000000003],[-122.47609999999997,37.703900000000033],[-122.47480999999999,37.704270000000065],[-122.47452999999996,37.704340000000059],[-122.47408999999999,37.704420000000027],[-122.47384999999997,37.704470000000072],[-122.47348999999997,37.704530000000034],[-122.47299999999996,37.70464000000004],[-122.47260999999997,37.70473000000004],[-122.47235999999998,37.70479000000006],[-122.47177999999997,37.704910000000041],[-122.47144999999995,37.704960000000028],[-122.47107999999997,37.704980000000035],[-122.47086999999999,37.704980000000035],[-122.47075999999998,37.704980000000035],[-122.47079999999994,37.705110000000047],[-122.47036999999995,37.705920000000049],[-122.46916999999996,37.707710000000077],[-122.46868999999998,37.708180000000027],[-122.46856999999994,37.708290000000034],[-122.46835999999996,37.70849000000004],[-122.46776999999997,37.709020000000066],[-122.46658999999994,37.709720000000061],[-122.46546999999998,37.710120000000074],[-122.46446999999995,37.710320000000024],[-122.46253999999999,37.710390000000075],[-122.45765999999998,37.710430000000031],[-122.45543999999995,37.710930000000076],[-122.45391999999998,37.711750000000052],[-122.45316999999994,37.712360000000047],[-122.45135999999997,37.713910000000055],[-122.44991999999996,37.715140000000076],[-122.44905999999997,37.716160000000059],[-122.44858999999997,37.717100000000073],[-122.44834999999995,37.718380000000025],[-122.44830999999999,37.718720000000076],[-122.44821999999999,37.719510000000071],[-122.44818999999995,37.719740000000058],[-122.44801999999999,37.721090000000061],[-122.44799999999998,37.721270000000061],[-122.44797999999997,37.721450000000061],[-122.44772999999998,37.722840000000076],[-122.44769999999994,37.722970000000032],[-122.44764999999995,37.723100000000045],[-122.44715999999994,37.724270000000047],[-122.44649999999996,37.72536000000008],[-122.44601999999998,37.726020000000062],[-122.44561999999996,37.726490000000069],[-122.44538999999997,37.726740000000063],[-122.44364999999999,37.728120000000047],[-122.44334999999995,37.728310000000079],[-122.44095999999996,37.729380000000049],[-122.43959999999998,37.729910000000075],[-122.43938999999995,37.729990000000043],[-122.43930999999998,37.730020000000025],[-122.43676999999997,37.730830000000026],[-122.43549999999999,37.731190000000026],[-122.43543999999997,37.731210000000033],[-122.43515999999994,37.731270000000052],[-122.43454999999994,37.731430000000046],[-122.43180999999998,37.732090000000028],[-122.43094999999994,37.732160000000079],[-122.43061999999998,37.732170000000053],[-122.42821999999995,37.73186000000004],[-122.42671999999999,37.731540000000052],[-122.42477999999994,37.731350000000077],[-122.42324999999994,37.731390000000033],[-122.41902999999996,37.73186000000004],[-122.41827999999998,37.73186000000004],[-122.41626999999994,37.73186000000004],[-122.41516999999999,37.732030000000066],[-122.41456999999997,37.73219000000006],[-122.41409999999996,37.732350000000054],[-122.41253999999998,37.733030000000042],[-122.41240999999997,37.733090000000061],[-122.41231999999997,37.733130000000074],[-122.41220999999996,37.733180000000061],[-122.41079999999999,37.733710000000031],[-122.40802999999994,37.734760000000051],[-122.40719999999999,37.735040000000026],[-122.40668999999997,37.735200000000077],[-122.40657999999996,37.735240000000033],[-122.40634999999997,37.735320000000058],[-122.40415999999999,37.736240000000066],[-122.40319,37.736790000000042],[-122.40294999999998,37.736950000000036],[-122.40226999999999,37.737400000000036],[-122.40215999999998,37.737480000000062],[-122.40205999999995,37.737550000000056],[-122.40192999999999,37.737650000000031],[-122.40145999999999,37.738060000000075],[-122.40083999999996,37.738680000000045],[-122.40025999999995,37.73929000000004],[-122.39969999999994,37.739930000000072],[-122.39911999999998,37.740540000000067],[-122.39858999999996,37.741160000000036],[-122.39801999999997,37.741790000000037],[-122.39743999999996,37.742440000000045],[-122.39699999999999,37.742920000000026],[-122.39676999999995,37.743180000000052],[-122.39633999999995,37.743650000000059],[-122.39580999999998,37.744030000000066],[-122.39498999999995,37.744860000000074],[-122.39328999999998,37.747280000000046],[-122.39173999999997,37.750110000000063],[-122.39151999999996,37.750590000000045],[-122.39129999999994,37.751460000000066],[-122.39124999999996,37.752640000000042],[-122.39195999999998,37.755180000000053],[-122.39216999999996,37.756140000000073],[-122.39224999999999,37.757020000000068],[-122.39222999999998,37.759100000000046],[-122.39234999999996,37.760830000000055],[-122.39244999999994,37.761690000000044],[-122.39263999999997,37.763540000000035],[-122.39273999999995,37.764090000000067],[-122.39295999999996,37.764660000000049],[-122.39331999999996,37.765280000000075],[-122.39416999999997,37.766330000000039],[-122.39598999999998,37.767780000000073],[-122.39671999999996,37.768350000000055],[-122.39737999999994,37.769110000000069],[-122.39774999999997,37.770490000000052],[-122.39793999999995,37.772170000000074],[-122.39776999999998,37.772870000000069],[-122.39737999999994,37.773510000000044],[-122.39615999999995,37.774500000000046],[-122.39587999999998,37.774710000000027],[-122.39519999999999,37.775230000000079],[-122.39463999999998,37.775650000000041],[-122.39389999999997,37.776210000000049],[-122.39347999999995,37.776550000000043],[-122.39304999999996,37.776900000000069],[-122.39288999999997,37.777030000000025],[-122.39270999999997,37.777170000000069],[-122.39253999999994,37.777310000000057],[-122.39170999999999,37.778000000000077],[-122.39006999999998,37.779300000000035],[-122.38964999999996,37.779620000000079],[-122.38945999999999,37.779760000000067],[-122.38878999999997,37.780320000000074],[-122.38820999999996,37.781240000000025],[-122.38813999999996,37.781800000000032],[-122.38810999999998,37.782300000000077],[-122.38809999999995,37.782660000000078],[-122.38795999999996,37.78410000000008],[-122.38788999999997,37.785040000000038],[-122.38779999999997,37.786100000000033],[-122.38770999999997,37.787070000000028],[-122.3877,37.787660000000074],[-122.38784999999996,37.788640000000044],[-122.38793999999996,37.788960000000031],[-122.38837999999998,37.789650000000051],[-122.38934999999998,37.790470000000028],[-122.38991999999996,37.790950000000066],[-122.39048999999994,37.791810000000055],[-122.39092999999997,37.792520000000025],[-122.39199999999994,37.793440000000032],[-122.39256999999998,37.793970000000058],[-122.39356999999995,37.794940000000054],[-122.39373999999998,37.795110000000079],[-122.39381999999995,37.795180000000073],[-122.39406999999994,37.795460000000048],[-122.39435999999995,37.795790000000068],[-122.39466999999996,37.796140000000037],[-122.39476499999995,37.796235000000024]]]}},{"attributes":{"ObjectID":2,"Name":"Truck_2","ViolatedConstraints":null,"OrderCount":2,"TotalCost":57.649171345261117,"RegularTimeCost":33.60107070691884,"OvertimeCost":0,"DistanceCost":24.048100638342277,"TotalTime":168.00535353459418,"TotalOrderServiceTime":49,"TotalBreakServiceTime":0,"TotalTravelTime":59.005353534594178,"TotalDistance":16.032067092228186,"StartTime":1355241600000,"EndTime":1355251680321,"TotalWaitTime":0,"TotalViolationTime":0,"RenewalCount":0,"TotalRenewalServiceTime":0,"Shape_Length":0.28106443716003016},"geometry":{"paths":[[[-122.39476499999995,37.796235000000024],[-122.39485999999999,37.796330000000069],[-122.39498999999995,37.796470000000056],[-122.39528999999999,37.796780000000069],[-122.39740999999998,37.799160000000029],[-122.39754999999997,37.799290000000042],[-122.39775999999995,37.799180000000035],[-122.39820999999995,37.798960000000079],[-122.39985999999999,37.798740000000066],[-122.40103999999997,37.798600000000079],[-122.40222999999997,37.798450000000059],[-122.40307999999999,37.798340000000053],[-122.40348999999998,37.798280000000034],[-122.40383999999995,37.798240000000078],[-122.40424999999999,37.798180000000059],[-122.40663999999998,37.797890000000052],[-122.40859999999998,37.797660000000064],[-122.41023999999999,37.79741000000007],[-122.41075999999998,37.797330000000045],[-122.41121999999996,37.79723000000007],[-122.41515999999996,37.796730000000025],[-122.41725999999994,37.796460000000025],[-122.41739999999999,37.796440000000075],[-122.41753999999997,37.796420000000069],[-122.41831999999999,37.796340000000043],[-122.41863999999998,37.796300000000031],[-122.41958999999997,37.796160000000043],[-122.42011999999994,37.796080000000075],[-122.42116999999996,37.796000000000049],[-122.42332999999996,37.795750000000055],[-122.42349999999999,37.795730000000049],[-122.42306999999994,37.793520000000058],[-122.42286999999999,37.792620000000056],[-122.42257999999998,37.791280000000029],[-122.42240999999996,37.790350000000046],[-122.42215999999996,37.789040000000057],[-122.42183999999997,37.787530000000061],[-122.42154999999997,37.786150000000077],[-122.42145999999997,37.78568000000007],[-122.42264999999998,37.785530000000051],[-122.42409999999995,37.785370000000057],[-122.42468999999994,37.78541000000007],[-122.42560999999995,37.785350000000051],[-122.42644999999999,37.785240000000044],[-122.42799999999994,37.785040000000038],[-122.42834999999997,37.78499000000005],[-122.42875999999995,37.784940000000063],[-122.42964999999998,37.784840000000031],[-122.42985999999996,37.78481000000005],[-122.43004999999999,37.784780000000069],[-122.43101999999999,37.784660000000031],[-122.43113999999997,37.784650000000056],[-122.43127999999996,37.78463000000005],[-122.43455999999998,37.78421000000003],[-122.43470999999994,37.784190000000081],[-122.43519999999995,37.784130000000062],[-122.43568999999997,37.784070000000042],[-122.43635999999998,37.783980000000042],[-122.43784999999997,37.783790000000067],[-122.43817999999999,37.783710000000042],[-122.43876999999998,37.78350000000006],[-122.43947999999995,37.783360000000073],[-122.44344999999998,37.782870000000059],[-122.44387999999998,37.78281000000004],[-122.44445999999999,37.782670000000053],[-122.44584999999995,37.782510000000059],[-122.44684999999998,37.782440000000065],[-122.44730999999996,37.782430000000033],[-122.44755999999995,37.782420000000059],[-122.44906999999995,37.782240000000058],[-122.44944999999996,37.782250000000033],[-122.45011999999997,37.782180000000039],[-122.45071999999999,37.782100000000071],[-122.45274999999998,37.781840000000045],[-122.45415999999994,37.781660000000045],[-122.45495999999997,37.78156000000007],[-122.45591999999999,37.781460000000038],[-122.45630999999997,37.781440000000032],[-122.45628999999997,37.781320000000051],[-122.45619999999997,37.780820000000062],[-122.45606999999995,37.780240000000049],[-122.45564999999999,37.779660000000035],[-122.45558999999997,37.779450000000054],[-122.45529999999997,37.777970000000039],[-122.45522999999997,37.777590000000032],[-122.45545999999996,37.777560000000051],[-122.45819999999998,37.777250000000038],[-122.45858999999996,37.777250000000038],[-122.45855999999998,37.77675000000005],[-122.45843999999994,37.775190000000066],[-122.45840999999996,37.774920000000066],[-122.45838999999995,37.774690000000078],[-122.45836999999995,37.774500000000046],[-122.45834999999994,37.774290000000065],[-122.46090999999996,37.773990000000026],[-122.46250999999995,37.773780000000045],[-122.46365999999995,37.773620000000051],[-122.46387999999996,37.773600000000044],[-122.46599999999995,37.773380000000031],[-122.46749999999997,37.773320000000069],[-122.46999999999997,37.773220000000038],[-122.47123999999997,37.773150000000044],[-122.47154999999998,37.773140000000069],[-122.47177999999997,37.773130000000037],[-122.47231999999997,37.773100000000056],[-122.47539999999998,37.772960000000069],[-122.47597999999999,37.772930000000031],[-122.47777999999994,37.772850000000062],[-122.47862999999995,37.772820000000024],[-122.47882999999996,37.77281000000005],[-122.47926999999999,37.772790000000043],[-122.48072999999999,37.772720000000049],[-122.48303999999996,37.772620000000074],[-122.48357999999996,37.772600000000068],[-122.48404999999997,37.77257000000003],[-122.48417999999998,37.77257000000003],[-122.48435999999998,37.772560000000055],[-122.48822999999999,37.77239000000003],[-122.49596999999994,37.772030000000029],[-122.49690999999996,37.772000000000048],[-122.49917999999997,37.771890000000042],[-122.50306999999998,37.771690000000035],[-122.50345999999996,37.77168000000006],[-122.50936999999999,37.771420000000035],[-122.50991999999997,37.771390000000054],[-122.50995999999998,37.772110000000055],[-122.50997798499998,37.772401359000071]],[[-122.50997798499998,37.772401359000071],[-122.50995999999998,37.772110000000055],[-122.50991999999997,37.771390000000054],[-122.50936999999999,37.771420000000035],[-122.50345999999996,37.77168000000006],[-122.50306999999998,37.771690000000035],[-122.49917999999997,37.771890000000042],[-122.49690999999996,37.772000000000048],[-122.49596999999994,37.772030000000029],[-122.48822999999999,37.77239000000003],[-122.48435999999998,37.772560000000055],[-122.48417999999998,37.77257000000003],[-122.48404999999997,37.77257000000003],[-122.48357999999996,37.772600000000068],[-122.48303999999996,37.772620000000074],[-122.48072999999999,37.772720000000049],[-122.47926999999999,37.772790000000043],[-122.47862999999995,37.772820000000024],[-122.47777999999994,37.772850000000062],[-122.47597999999999,37.772930000000031],[-122.47539999999998,37.772960000000069],[-122.47231999999997,37.773100000000056],[-122.47177999999997,37.773130000000037],[-122.47154999999998,37.773140000000069],[-122.47123999999997,37.773150000000044],[-122.46999999999997,37.773220000000038],[-122.46749999999997,37.773320000000069],[-122.46599999999995,37.773380000000031],[-122.46587999999997,37.773380000000031],[-122.46482999999995,37.773490000000038],[-122.46491587599996,37.774698872000045]],[[-122.46491587599996,37.774698872000045],[-122.46495999999996,37.775320000000079],[-122.46387999999996,37.775370000000066],[-122.46388999999999,37.775470000000041],[-122.46390999999994,37.775700000000029],[-122.46398999999997,37.776850000000024],[-122.46402999999998,37.777220000000057],[-122.46414999999996,37.779100000000028],[-122.46306999999996,37.779140000000041],[-122.46199999999999,37.779190000000028],[-122.46092999999996,37.779230000000041],[-122.45987999999994,37.779270000000054],[-122.45874999999995,37.779350000000079],[-122.45824999999996,37.779400000000066],[-122.45776999999998,37.779460000000029],[-122.45686999999998,37.779580000000067],[-122.45650999999998,37.779680000000042],[-122.45584999999994,37.779950000000042],[-122.45499999999998,37.780100000000061],[-122.45481999999998,37.780120000000068],[-122.45384999999999,37.780230000000074],[-122.45286999999996,37.780370000000062],[-122.45185999999995,37.780490000000043],[-122.45081999999996,37.780640000000062],[-122.45029999999997,37.780700000000024],[-122.44980999999996,37.780760000000043],[-122.44951999999995,37.780790000000025],[-122.44940999999994,37.780800000000056],[-122.44908999999996,37.780840000000069],[-122.44879999999995,37.780880000000025],[-122.44826999999998,37.780950000000075],[-122.44753999999995,37.781040000000075],[-122.44758999999999,37.781280000000038],[-122.44759999999997,37.781430000000057],[-122.44741999999997,37.781930000000045],[-122.44740999999999,37.782250000000033],[-122.44730999999996,37.782430000000033],[-122.44726999999995,37.782520000000034],[-122.44717999999995,37.782690000000059],[-122.44731999999999,37.78374000000008],[-122.44738999999998,37.784080000000074],[-122.44744999999995,37.784410000000037],[-122.44748999999996,37.784610000000043],[-122.44752999999997,37.78481000000005],[-122.44758999999999,37.785090000000025],[-122.44641999999999,37.785370000000057],[-122.44596999999999,37.785420000000045],[-122.44263999999998,37.785840000000064],[-122.44251999999994,37.785860000000071],[-122.44004999999999,37.786190000000033],[-122.43763999999999,37.786490000000072],[-122.43668999999994,37.786620000000028],[-122.43344999999999,37.787040000000047],[-122.42852999999997,37.787650000000042],[-122.42523999999997,37.788070000000062],[-122.42357999999996,37.788280000000043],[-122.42377999999997,37.789210000000026],[-122.42396999999994,37.790160000000071],[-122.42486999999994,37.794700000000034],[-122.42495999999994,37.795160000000067],[-122.42502999999999,37.795530000000042],[-122.42410999999998,37.79565000000008],[-122.42349999999999,37.795730000000049],[-122.42332999999996,37.795750000000055],[-122.42116999999996,37.796000000000049],[-122.42011999999994,37.796080000000075],[-122.41958999999997,37.796160000000043],[-122.41863999999998,37.796300000000031],[-122.41831999999999,37.796340000000043],[-122.41753999999997,37.796420000000069],[-122.41739999999999,37.796440000000075],[-122.41725999999994,37.796460000000025],[-122.41515999999996,37.796730000000025],[-122.41121999999996,37.79723000000007],[-122.41075999999998,37.797330000000045],[-122.41023999999999,37.79741000000007],[-122.40969999999999,37.797520000000077],[-122.40901999999994,37.797610000000077],[-122.40859999999998,37.797660000000064],[-122.40663999999998,37.797890000000052],[-122.40424999999999,37.798180000000059],[-122.40222999999997,37.798450000000059],[-122.40103999999997,37.798600000000079],[-122.39985999999999,37.798740000000066],[-122.39866999999998,37.798890000000029],[-122.39820999999995,37.798960000000079],[-122.39775999999995,37.799180000000035],[-122.39767999999998,37.79908000000006],[-122.39736999999997,37.798740000000066],[-122.39692999999994,37.798240000000078],[-122.39649999999995,37.797720000000027],[-122.39614999999998,37.797310000000039],[-122.39596999999998,37.797120000000064],[-122.39582999999999,37.79696000000007],[-122.39544999999998,37.796510000000069],[-122.39527999999996,37.796320000000037],[-122.39521999999999,37.796250000000043],[-122.39496999999994,37.795950000000062],[-122.39483999999999,37.795790000000068],[-122.39430999999996,37.794990000000041],[-122.39374999999995,37.79454000000004],[-122.39337999999998,37.794330000000059],[-122.39318999999995,37.79436000000004],[-122.39318999999995,37.794550000000072],[-122.39356999999995,37.794940000000054],[-122.39373999999998,37.795110000000079],[-122.39381999999995,37.795180000000073],[-122.39406999999994,37.795460000000048],[-122.39435999999995,37.795790000000068],[-122.39466999999996,37.796140000000037],[-122.39476499999995,37.796235000000024]]]}},{"attributes":{"ObjectID":3,"Name":"Truck_3","ViolatedConstraints":null,"OrderCount":2,"TotalCost":62.224549477817575,"RegularTimeCost":32.957510674744846,"OvertimeCost":0,"DistanceCost":29.267038803072733,"TotalTime":164.78755337372422,"TotalOrderServiceTime":43,"TotalBreakServiceTime":0,"TotalTravelTime":61.787553373724222,"TotalDistance":19.511359202048489,"StartTime":1355241600000,"EndTime":1355251487253,"TotalWaitTime":0,"TotalViolationTime":0,"RenewalCount":0,"TotalRenewalServiceTime":0,"Shape_Length":0.323000998130058},"geometry":{"paths":[[[-122.39476499999995,37.796235000000024],[-122.39485999999999,37.796330000000069],[-122.39498999999995,37.796470000000056],[-122.39528999999999,37.796780000000069],[-122.39555999999999,37.796640000000025],[-122.39544999999998,37.796510000000069],[-122.39527999999996,37.796320000000037],[-122.39521999999999,37.796250000000043],[-122.39430999999996,37.794990000000041],[-122.39374999999995,37.79454000000004],[-122.39337999999998,37.794330000000059],[-122.39274999999998,37.793840000000046],[-122.39262999999994,37.793710000000033],[-122.39249999999998,37.793600000000026],[-122.39218999999997,37.793320000000051],[-122.39157999999998,37.792800000000057],[-122.39135999999996,37.792580000000044],[-122.39119999999997,37.792330000000049],[-122.39071999999999,37.791280000000029],[-122.39015999999998,37.790760000000034],[-122.39001999999999,37.790650000000028],[-122.38956999999999,37.790290000000027],[-122.38877999999994,37.789670000000058],[-122.38860999999997,37.789500000000032],[-122.38906999999995,37.789130000000057],[-122.38982999999996,37.788530000000037],[-122.39031999999997,37.78815000000003],[-122.39159999999998,37.787150000000054],[-122.39205999999996,37.786790000000053],[-122.39242999999999,37.786510000000078],[-122.39295999999996,37.786090000000058],[-122.39324999999997,37.785860000000071],[-122.39344999999997,37.785700000000077],[-122.39363999999995,37.785540000000026],[-122.39383999999995,37.785380000000032],[-122.39405999999997,37.785210000000063],[-122.39409999999998,37.785180000000025],[-122.39457999999996,37.78481000000005],[-122.39473999999996,37.784690000000069],[-122.39630999999997,37.783430000000067],[-122.39738999999997,37.782550000000072],[-122.39765999999997,37.782340000000033],[-122.39876999999996,37.78147000000007],[-122.39919999999995,37.781120000000044],[-122.39962999999995,37.78078000000005],[-122.39963999999998,37.78045000000003],[-122.39993999999996,37.779910000000029],[-122.40042999999997,37.779440000000079],[-122.40089999999998,37.77902000000006],[-122.40123999999997,37.778670000000034],[-122.40131999999994,37.77860000000004],[-122.40328,37.777190000000076],[-122.40364999999997,37.776960000000031],[-122.40429999999998,37.776570000000049],[-122.40526999999997,37.775980000000061],[-122.40592999999996,37.77544000000006],[-122.40600999999998,37.775340000000028],[-122.40609999999998,37.775240000000053],[-122.40668999999997,37.774280000000033],[-122.40682999999996,37.773100000000056],[-122.40678999999994,37.772770000000037],[-122.40676999999999,37.77266000000003],[-122.40661999999998,37.772080000000074],[-122.40640999999999,37.771630000000073],[-122.40635999999995,37.771520000000066],[-122.40625999999997,37.771340000000066],[-122.40598999999997,37.770830000000046],[-122.40588999999994,37.770560000000046],[-122.40587999999997,37.770400000000052],[-122.40582999999998,37.769890000000032],[-122.40583999999996,37.76965000000007],[-122.40623999999997,37.769100000000037],[-122.40736999999996,37.768930000000069],[-122.40785999999997,37.768970000000024],[-122.40864999999997,37.76905000000005],[-122.40919999999994,37.76914000000005],[-122.40946999999994,37.769190000000037],[-122.41056999999995,37.769400000000076],[-122.41080999999997,37.769440000000031],[-122.41098,37.769460000000038],[-122.41157999999996,37.769520000000057],[-122.41183999999998,37.769540000000063],[-122.41227999999995,37.76956000000007],[-122.41269999999997,37.769570000000044],[-122.41331999999994,37.769580000000076],[-122.41409999999996,37.769620000000032],[-122.41477999999995,37.769640000000038],[-122.41516999999999,37.76965000000007],[-122.41554999999994,37.769660000000044],[-122.41597999999999,37.769670000000076],[-122.41620999999998,37.769690000000026],[-122.41699999999997,37.769780000000026],[-122.41773999999998,37.769860000000051],[-122.41819999999996,37.76992000000007],[-122.41855999999996,37.769990000000064],[-122.41896999999994,37.770050000000026],[-122.41932999999995,37.770080000000064],[-122.41953999999998,37.77010000000007],[-122.41989999999998,37.770110000000045],[-122.42018999999999,37.770130000000051],[-122.42042999999995,37.770120000000077],[-122.42162999999999,37.770350000000064],[-122.42212999999998,37.770600000000059],[-122.42268999999999,37.771010000000047],[-122.42336999999998,37.771950000000061],[-122.42346999999995,37.772060000000067],[-122.42391999999995,37.773900000000026],[-122.42411999999996,37.774820000000034],[-122.42428999999998,37.775630000000035],[-122.42430999999999,37.775750000000073],[-122.42437999999999,37.775740000000042],[-122.42447999999996,37.775720000000035],[-122.43234999999999,37.774720000000059],[-122.43292999999994,37.774650000000065],[-122.43355999999994,37.77457000000004],[-122.43593999999996,37.774270000000058],[-122.43706999999995,37.774130000000071],[-122.43759999999997,37.774060000000077],[-122.44104999999996,37.773610000000076],[-122.44510999999994,37.773090000000025],[-122.44570999999996,37.773010000000056],[-122.44758999999999,37.772800000000075],[-122.45160999999996,37.772250000000042],[-122.45240999999999,37.772150000000067],[-122.45386999999999,37.771530000000041],[-122.45397999999994,37.771480000000054],[-122.45428999999996,37.771360000000072],[-122.45459999999997,37.77123000000006],[-122.45519999999999,37.770970000000034],[-122.45541999999995,37.770710000000065],[-122.45539999999994,37.770330000000058],[-122.45498999999995,37.769490000000076],[-122.45484999999996,37.769020000000069],[-122.45488999999998,37.76863000000003],[-122.45516999999995,37.768260000000055],[-122.45567999999997,37.768100000000061],[-122.45728999999994,37.767620000000079],[-122.45757999999995,37.767530000000079],[-122.45791999999994,37.767420000000072],[-122.45855999999998,37.76723000000004],[-122.45867999999996,37.767190000000028],[-122.45874999999995,37.767160000000047],[-122.45923999999997,37.766890000000046],[-122.45936999999998,37.766790000000071],[-122.45987999999994,37.766400000000033],[-122.46023999999994,37.766220000000033],[-122.46056999999996,37.766180000000077],[-122.46107999999998,37.76616000000007],[-122.46212999999995,37.766110000000026],[-122.46215999999998,37.766110000000026],[-122.46322999999995,37.76607000000007],[-122.46429999999998,37.766040000000032],[-122.46534999999994,37.76598000000007],[-122.46643999999998,37.765930000000026],[-122.46869999999996,37.765820000000076],[-122.47071999999997,37.765740000000051],[-122.47219999999999,37.765670000000057],[-122.47304999999994,37.765630000000044],[-122.47618999999997,37.765490000000057],[-122.47714999999999,37.765450000000044],[-122.47732999999999,37.765440000000069],[-122.47784999999999,37.765420000000063],[-122.47832999999997,37.765400000000056],[-122.47941999999995,37.765360000000044],[-122.48046999999997,37.765310000000056],[-122.48155999999994,37.765250000000037],[-122.48140999999998,37.763390000000072],[-122.48126999999999,37.761520000000075],[-122.48114999999996,37.759650000000079],[-122.48102999999998,37.757780000000025],[-122.48209999999995,37.757730000000038],[-122.48246999999998,37.757720000000063],[-122.48315999999994,37.757700000000057],[-122.48421999999999,37.757640000000038],[-122.48481999999996,37.757620000000031],[-122.48528999999996,37.757600000000025],[-122.48515999999995,37.755730000000028],[-122.48624999999998,37.755690000000072],[-122.48611999999997,37.753810000000044],[-122.48718999999994,37.753770000000031],[-122.48825999999997,37.753720000000044],[-122.48846999999995,37.753710000000069],[-122.48919999999998,37.753680000000031],[-122.48919999999998,37.753850000000057],[-122.48890159399997,37.753858176000051]],[[-122.48890159399997,37.753858176000051],[-122.48919999999998,37.753850000000057],[-122.48919999999998,37.753680000000031],[-122.48846999999995,37.753710000000069],[-122.48825999999997,37.753720000000044],[-122.48718999999994,37.753770000000031],[-122.48611999999997,37.753810000000044],[-122.48597999999998,37.751940000000047],[-122.48580999999996,37.751950000000079],[-122.48546999999996,37.751970000000028],[-122.48524999999995,37.75198000000006],[-122.48493999999999,37.752010000000041],[-122.48394999999999,37.752060000000029],[-122.48383999999999,37.752060000000029],[-122.48277999999999,37.752110000000073],[-122.48187999999999,37.752140000000054],[-122.48172999999997,37.752140000000054],[-122.48171999999994,37.75198000000006],[-122.48166999999995,37.751370000000065],[-122.48158999999998,37.750280000000032],[-122.48051999999996,37.750300000000038],[-122.48042999999996,37.749180000000024],[-122.48036999999999,37.748440000000073],[-122.47929999999997,37.748490000000061],[-122.47826999999995,37.748540000000048],[-122.47715999999997,37.748590000000036],[-122.47703999999999,37.746720000000039],[-122.47688999999997,37.744860000000074],[-122.47579999999999,37.74490000000003],[-122.47473999999994,37.744960000000049],[-122.47462999999999,37.743100000000027],[-122.47389692799999,37.743134256000076]],[[-122.47389692799999,37.743134256000076],[-122.47355999999996,37.743150000000071],[-122.47274999999996,37.743180000000052],[-122.47247999999996,37.743190000000027],[-122.47236999999996,37.74132000000003],[-122.47220999999996,37.739450000000033],[-122.46997999999996,37.739540000000034],[-122.46894999999995,37.739930000000072],[-122.46799999999996,37.740010000000041],[-122.46701999999999,37.73974000000004],[-122.46625999999998,37.739230000000077],[-122.46618999999998,37.739160000000027],[-122.46613999999994,37.739080000000058],[-122.46584999999999,37.738530000000026],[-122.46548999999999,37.738330000000076],[-122.46524999999997,37.738190000000031],[-122.46464999999995,37.737860000000069],[-122.46445999999997,37.737750000000062],[-122.46313999999995,37.737010000000055],[-122.46205999999995,37.736360000000047],[-122.46176999999994,37.736140000000034],[-122.46159999999998,37.736020000000053],[-122.46125999999998,37.735770000000059],[-122.46066999999999,37.735360000000071],[-122.45984999999996,37.73464000000007],[-122.45907999999997,37.733650000000068],[-122.45862999999997,37.73255000000006],[-122.45804999999996,37.732490000000041],[-122.45769999999999,37.732110000000034],[-122.45750999999996,37.730990000000077],[-122.45576999999997,37.731370000000027],[-122.45365999999996,37.731520000000046],[-122.45339999999999,37.731520000000046],[-122.45112999999998,37.731540000000052],[-122.44962999999996,37.731550000000027],[-122.44939999999997,37.731550000000027],[-122.44917999999996,37.731550000000027],[-122.44886999999994,37.731550000000027],[-122.44840999999997,37.731550000000027],[-122.44427999999999,37.731560000000059],[-122.44095999999996,37.731600000000071],[-122.44074999999998,37.731600000000071],[-122.43787999999995,37.73159000000004],[-122.43744999999996,37.73159000000004],[-122.43720999999999,37.73159000000004],[-122.43651999999997,37.731580000000065],[-122.43613999999997,37.731470000000058],[-122.43577999999997,37.731320000000039],[-122.43549999999999,37.731190000000026],[-122.43490999999995,37.731120000000033],[-122.43374999999997,37.731490000000065],[-122.43218999999999,37.732030000000066],[-122.43180999999998,37.732090000000028],[-122.43094999999994,37.732160000000079],[-122.43061999999998,37.732170000000053],[-122.42821999999995,37.73186000000004],[-122.42671999999999,37.731540000000052],[-122.42477999999994,37.731350000000077],[-122.42324999999994,37.731390000000033],[-122.41902999999996,37.73186000000004],[-122.41827999999998,37.73186000000004],[-122.41588999999999,37.731900000000053],[-122.41516999999999,37.732030000000066],[-122.41456999999997,37.73219000000006],[-122.41409999999996,37.732350000000054],[-122.41253999999998,37.733030000000042],[-122.41240999999997,37.733090000000061],[-122.41231999999997,37.733130000000074],[-122.41220999999996,37.733180000000061],[-122.41079999999999,37.733710000000031],[-122.40802999999994,37.734760000000051],[-122.40719999999999,37.735040000000026],[-122.40668999999997,37.735200000000077],[-122.40657999999996,37.735240000000033],[-122.40634999999997,37.735320000000058],[-122.40415999999999,37.736240000000066],[-122.40319,37.736790000000042],[-122.40294999999998,37.736950000000036],[-122.40226999999999,37.737400000000036],[-122.40215999999998,37.737480000000062],[-122.40205999999995,37.737550000000056],[-122.40192999999999,37.737650000000031],[-122.40145999999999,37.738060000000075],[-122.40083999999996,37.738680000000045],[-122.40025999999995,37.73929000000004],[-122.39969999999994,37.739930000000072],[-122.39911999999998,37.740540000000067],[-122.39858999999996,37.741160000000036],[-122.39801999999997,37.741790000000037],[-122.39743999999996,37.742440000000045],[-122.39699999999999,37.742920000000026],[-122.39676999999995,37.743180000000052],[-122.39633999999995,37.743650000000059],[-122.39580999999998,37.744030000000066],[-122.39498999999995,37.744860000000074],[-122.39328999999998,37.747280000000046],[-122.39173999999997,37.750110000000063],[-122.39151999999996,37.750590000000045],[-122.39129999999994,37.751460000000066],[-122.39124999999996,37.752640000000042],[-122.39195999999998,37.755180000000053],[-122.39216999999996,37.756140000000073],[-122.39224999999999,37.757020000000068],[-122.39222999999998,37.759100000000046],[-122.39234999999996,37.760830000000055],[-122.39244999999994,37.761690000000044],[-122.39263999999997,37.763540000000035],[-122.39273999999995,37.764090000000067],[-122.39295999999996,37.764660000000049],[-122.39331999999996,37.765280000000075],[-122.39416999999997,37.766330000000039],[-122.39598999999998,37.767780000000073],[-122.39671999999996,37.768350000000055],[-122.39737999999994,37.769110000000069],[-122.39774999999997,37.770490000000052],[-122.39793999999995,37.772170000000074],[-122.39776999999998,37.772870000000069],[-122.39737999999994,37.773510000000044],[-122.39615999999995,37.774500000000046],[-122.39587999999998,37.774710000000027],[-122.39519999999999,37.775230000000079],[-122.39463999999998,37.775650000000041],[-122.39389999999997,37.776210000000049],[-122.39347999999995,37.776550000000043],[-122.39304999999996,37.776900000000069],[-122.39288999999997,37.777030000000025],[-122.39270999999997,37.777170000000069],[-122.39253999999994,37.777310000000057],[-122.39170999999999,37.778000000000077],[-122.39006999999998,37.779300000000035],[-122.38964999999996,37.779620000000079],[-122.38945999999999,37.779760000000067],[-122.38878999999997,37.780320000000074],[-122.38820999999996,37.781240000000025],[-122.38813999999996,37.781800000000032],[-122.38810999999998,37.782300000000077],[-122.38809999999995,37.782660000000078],[-122.38795999999996,37.78410000000008],[-122.38788999999997,37.785040000000038],[-122.38779999999997,37.786100000000033],[-122.38770999999997,37.787070000000028],[-122.3877,37.787660000000074],[-122.38784999999996,37.788640000000044],[-122.38793999999996,37.788960000000031],[-122.38837999999998,37.789650000000051],[-122.38934999999998,37.790470000000028],[-122.38991999999996,37.790950000000066],[-122.39048999999994,37.791810000000055],[-122.39092999999997,37.792520000000025],[-122.39199999999994,37.793440000000032],[-122.39256999999998,37.793970000000058],[-122.39356999999995,37.794940000000054],[-122.39373999999998,37.795110000000079],[-122.39381999999995,37.795180000000073],[-122.39406999999994,37.795460000000048],[-122.39435999999995,37.795790000000068],[-122.39466999999996,37.796140000000037],[-122.39476499999995,37.796235000000024]]]}}],"exceededTransferLimit":false}}</textarea>
    <div class="redButton Button" id="redBtn">on/off</div>
    <div class="blueButton Button" id="blueBtn">on/off</div>
</body>
</html>
