arcgis javascript how to layer`s custom field & value rendering
4405
6
09-28-2016 03:42 AM
ParkSeungHyun
I try to rendering. To add custom statistics data to the layer.
when... returnGeometry = true
customdata added in the layer.
however, an error occurred when data was many layers
" Error: Error performing query operation(…)"
so the retrungeometry changed to false.
Then the data is not added to the layer.
How should I add?
var layer = new FeatureLayer(url, {
outFields: ["*"],
mode: FeatureLayer.MODE_SNAPSHOT
var tempObject = new esri.layers.Field ({
alias : "STATISTICS",
type : "esriFieldTypeInteger"
var randArr = [];
for(var i=0;i<17;i++){
randArr = (Math.floor(Math.random() * 100 )+1);
mapObject.Layers.addLayerObject(layer);
mapObject.addEvent('layer-add',lang.hitch(this,function(evt){
console.log("layer.fields ======",layer.fields);
layer.fields.push(tempObject);
queryTask = new QueryTask(url);
var query = new Query();
query.where = "1=1";
query.outFields = ["*"];
query.returnGeometry = true;
console.log("query ====",query);
layer.queryFeatures(query, function (featureSet) {
// queryTask.execute(query, function(featureSet){
resultObject = featureSet.features;
for(var i = 0, length = resultObject.length; i < length; i++){
resultObject.attributes.STATISTICS = randArr;
console.log("resultObject.attributes.STATISTICS======",resultObject.attributes.STATISTICS);
// console.log("layer.graphics =====",layer.graphics);
var symbol = new SimpleFillSymbol();
symbol.setColor(new Color([0, 216, 255, 0.5]));
var renderer = new ClassBreaksRenderer(null, "STATISTICS");
renderer.addBreak(0, 10, new SimpleFillSymbol().setColor(new Color([56, 168, 0, 0.5])));
renderer.addBreak(11, 30, new SimpleFillSymbol().setColor(new Color([139, 209, 0, 0.5])));
renderer.addBreak(31, 50, new SimpleFillSymbol().setColor(new Color([255, 255, 0, 0.5])));
renderer.addBreak(51, 90, new SimpleFillSymbol().setColor(new Color([255, 128, 0, 0.5])));
renderer.addBreak(91, Infinity, new SimpleFillSymbol().setColor(new Color([255, 0, 0, 0.5])));
layer.setRenderer(renderer);
layer.redraw();
RobertScheitlin__GISP
Park,
   I believe you issue was your random number generation was only going to 17. When I set the random number to 2001 (because a featurelayer by default will return a max feature count of 2000) it worked for me. I also changed some of your other code to be more conventional:
<!DOCTYPE html>
<html>
<head>
    <meta charset="utf-8">
    <meta name="viewport" content="initial-scale=1,maximum-scale=1,user-scalable=no">
    <title>FeatureLayer</title>
    <link rel="stylesheet" href="https://js.arcgis.com/3.18/esri/css/esri.css">
    <script src="https://js.arcgis.com/3.18/"></script>
    <style>
        html,
        body,
        #map {
            padding: 0;
            margin: 0;
            height: 100%;
            width: 100%;
    </style>
    <script>
        require([
                "esri/map",
                "esri/layers/FeatureLayer",
                "esri/layers/Field",
                "esri/tasks/query",
                "esri/tasks/QueryTask",
                "esri/symbols/SimpleFillSymbol",
                "esri/graphic",
                "esri/Color",
                "esri/renderers/ClassBreaksRenderer",
                "dojo/_base/lang",
                "dojo/domReady!"
            function(
                Map,
                FeatureLayer,
                Field,
                Query,
                QueryTask,
                SimpleFillSymbol,
                Graphic,
                Color,
                ClassBreaksRenderer,
                lang
                var map = new Map("map", {
                    basemap: "hybrid",
                    center: [-122.304568, 47.608492],
                    zoom: 13
                var url = "https://services.arcgis.com/V6ZHFr6zdgNZuVG0/arcgis/rest/services/Puget_Sound_BG_Food/FeatureServer/...";
                    outFields: ["*"],
                var tempObject = new Field({
                    alias: "STATISTICS",
                    type: "esriFieldTypeInteger"
                var randArr = [];
                for (var i = 0; i < 2001; i++) {
                    randArr[i] = (Math.floor(Math.random() * 100) + 1);
                map.on("layer-add", lang.hitch(this, function(evt) {
                    layer.queryFeatures(query, lang.hitch(this, function(featureSet) {
                        for (var i = 0, length = resultObject.length; i < length; i++) {
                            resultObject[i].attributes.STATISTICS = randArr[i];
                            console.log("resultObject.attributes.STATISTICS======", resultObject[i].attributes.STATISTICS);
                        layer.redraw();
                map.addLayer(layer);
    </script>
</head>
<body>
    <div id="map"></div>
</body>
</html>
ParkSeungHyun
i was changed Max Record Count 25000.
but... Still it occurred error.
How Can I fix the error?
I try to perform a query, 6000
this is my mapserver.
Single Fused Map Cache: false
Initial Extent:
      XMin: -139536.26633984904
      YMin: 170894.84468518946
      XMax: 746819.6730386964
      YMax: 590921.7264056195
      Spatial Reference: PROJCS["Korean_1985_Korea_Central_Belt",GEOGCS["GCS_Korean_Datum_1985",DATUM["D_Korean_Datum_1985",SPHEROID["Bessel_1841",6377397.155,299.1528128]],PRIMEM["Greenwich",0.0],UNIT["Degree",0.0174532925199433]],PROJECTION["Transverse_Mercator"],PARAMETER["False_Easting",200000.0],PARAMETER["False_Northing",500000.0],PARAMETER["Central_Meridian",127.0028902777778],PARAMETER["Scale_Factor",1.0],PARAMETER["Latitude_Of_Origin",38.0],UNIT["Meter",1.0]]
Full Extent:
      XMin: -759134.2284
      YMin: -1539691.9265
      XMax: 978542.9778000009
      YMax: 568690.1628000122
Units: esriMeters
Supported Image Format Types: PNG32,PNG24,PNG,JPG,DIB,TIFF,EMF,PS,PDF,GIF,SVG,SVGZ,BMP
Document Info:
      Title:
      Author:
      Comments: IndexMap
      Subject: IndexMap
      Category:
      Keywords: IndexMap
      AntialiasingMode: None
      TextAntialiasingMode: Force
Supports Dynamic Layers: false
MaxRecordCount: 25000
MaxImageHeight: 4096
MaxImageWidth: 4096
Supported Query Formats: JSON, AMF
Min Scale: 0
Max Scale: 0
Park,
   You are asking for something beyond the capability of the API and client browser. You can not expect the API to draw 25000 complex polygons on the client. When using FeatureLayer the actual geometry has to be rendered by the client (that means each vertex that makes up the polygon has to transferred to the client and processed). You will need to limit your returned features or do this rendering work on the server side by using a ArcGISDynamicMapService and configuring the renderer in your map services MXD instead.
ParkSeungHyun
I want to receiving the customized statistical data to render it featurelayer.
I looked in the example source.
Class breaks renderer with dynamic layer | ArcGIS API for JavaScript 3.18
If I could see the examples can perform the function that I want?
Park,
  That sample uses a dynamic layer which renders on the server so yes that would work. You just need to enable your map service for dynamic layer support.
ParkSeungHyun
Thanks.  I'll test it~!!!
