Javascript Sample: Feature table - related records -> 404 error
1284
09-22-2016 05:37 AM
GeraldSilva
The ArcGIS Javascript 3.17 latest sample site:
Samples | ArcGIS API for JavaScript 3.17
shows already several days a Feature table with related records sample, but clicking the example results in "404 -not found".
https://developers.arcgis.com/javascript/3/jssamples/featuretable_relatedrecords.html
I'm very interested  in this solution sample, is there anything wrong with this link?
LauraYetter
I tried using the same Feature Table - related records example (ArcGIS API for JavaScript Sandbox).I copied the code to my text editor and ran it on my computer. I pasted in my own rest url for the feature layer. I didn't change anything else in the code, except for removing the definitionExpression filter. I run the code, select a polygon and click on "show" on the feature table column to view the related table. The related table shows up correctly. I select another polygon. The related table does not update. In the Beverly Hills example, the related table updates when a new block is selected.  Why is it not working with my data?
