Cannot read property 'transparency' of undefined
891
09-20-2016 06:29 AM
LukeSteadman
Using the following code and passing a public map GUID produces the following error when I've created a Layer with notes (the notes contain a symbol (point / marker)).
Note: If I convert the below to use version 3.x of the API, the layer is rendered correctly.
<script>
require([
  "esri/WebMap",
  "esri/views/MapView",
  "dojo/domReady!"
], function(WebMap, MapView){
  var guid = "PUBLIC_WEB_MAP_GUID";
  var map = new WebMap({
    portalItem: {
  var view = new MapView({
    container: "map",  // Reference to the scene div created in step 5
    map: map,  // Reference to the map object created before the scene
</script>
Is there a resolution to the above using JS API 4.x
Tags (4)
