Modelbuilder question
2498
7
09-12-2016 01:57 AM
tumishopascal
Depiction of the Model before Calculations
I would like to multiple values from one column to another and divide by 100 using calculate value (Model Builder), how do I go about that? Say one column in a shapefile has Area and another one Rating and empty field column for the results. How can I do that
Hi. This is the model I have been doing. It is basically a wetland based model to generate condition of a wetland based on the landcover extent. I basically want to make use of calculator to multiply the field values (say frequency and landcover extent) and be able to divide them by 100 so I can get the results in an unfilled field. Having a challenge making use of calculate value tool from Model builder. Any help will be appreciated and further advice in taking this forward
DanPatterson_Retired
simplified question title and moved its content to the body of the question... it was way too long
tumishopascal
The Calculate Value tool contains an example, just emulate it, substituting your field names in as appropriate.
tumishopascal
Hi Dan.
I tried to write the expressions from field names of the the table wetland tool but it gives me error.
Tumisho... you need to copy and report the errors... saying that there is an error, won't help in solving the problem.  Perhaps, you are using VB syntax instead of Python or vice versa
tumishopascal
The error is giving me is 000539: SyntaxError. Can I forward you the tool and shapefile?
It would be easier for all if you just recorded your syntax and a screengrab if needed
