Pre-Select Multiple Choice Questions Based on Pre-Populated CSV Data
1762
09-08-2016 12:25 AM
WengNg
I've successfully loaded up pre-populated CSV data onto Survey 123 and manage to show the values as a note/text/integer.
However, what I really want to do is pre-fill the multiple choice questions as well using the pre-populated data. I tried everything and it seems that the select_one type questions doesn't accept values that I have  previously calculated.
I have a row that calculates the results of a few categories based on the selected key field. Then, I tried using the results ${calculated_result} in the calculate field in one of my multiple choice question but it doesn't work. I even tried it in the default value column and that doesn't work as well. However, if I explicitly type the value in the default column, the answer is pre-selected !
Are calculated results not supported in a multiple choice question field?
Hopefully someone can enlighten me on this.
Weng
