Missing Analysis after setting hosting server?
1544
09-01-2016 02:15 PM
DarylHochhalter
If I use an admin URL with the port number while federating, I don't see analysis show up after setting the hosting server.
I must set the web adapter to allow admin access so that I can federate using the URL without the port number.
Is something wrong or do you have to have a web adapter with admin access enabled to use analysis with a hosting server?
by Anonymous User
Not applicable
You can use ArcGIS server manager using 6080 port or using web adapter port,
http://localhost:6080/arcgis/manager
http://localhost:7120/arcgis/manager
Which type of statics you want to check,
Map services related things you can check in logs>statics
DarylHochhalter
We are using a web adaptor and https only, but knowing the port number isn't the issue. If I use the port number 6443 for the admin URL when federating, the analysis isn't available after setting the hosting server.
by Anonymous User
Not applicable
Which type of analysis are you looking in ArcGIS server side,
its related to uses or with in map services analysis on features.
Please share more infomation
