Edit Form PHP PDO
7972
09-01-2016 08:31 AM
SarojThapa1
I have a table in SQL Server database. I created an "edit.php" where we can update the database. The database connection is established using PDO. The issue is: I have a lot of Null values in the table. When I click "Edit" option, the form pops out. If I completely fill the records, the database gets updated. Otherwise I get this error message. SQLSTATE[42000]: [Microsoft][ODBC Driver 11 for SQL Server][SQL Server]Error converting data type nvarchar to numeric.
The codes for my edit.php are included below:
require_once('database.php');
if (isset($_POST['btn_submit'])) {
   $id = $_POST['txt_id'];
   $site = $_POST['txt_site_code'];
   $location = $_POST['txt_location_name'];
try {
$stmt = $conn->prepare("UPDATE MATRIX SET Site_Code=:site,
               Location_name=:location WHERE OBJECTID =:id");
$stmt->execute(array(':site' => $site, ':location' => $location,':id' => $id));
if ($stmt) {
   header('Location:index.php');
} catch (PDOException $e) {
echo $e->getMessage();
$object_id = '';
$site = '';
$location = '';
if (isset($_GET['id'])) {
      $id = $_GET['id'];
      $stmt = $conn->prepare("SELECT * FROM MATRIX WHERE OBJECTID=:id");
      $stmt->execute(array(':id' => $id));
      $row = $stmt->fetch();
      $object_id = $row['OBJECTID'];
      $site = $row['Site_Code'];
      $location = $row['Location_name'];
<h2>Edit the records</h2>
<form action="" method="post">
   <table border="3px" cellpadding="5px">
   <tr>
      <td>Site Code</td>
      <td><input type="text" name="txt_site_code"  value="<?= $site; ?>"></td>
   </tr>
   <tr>
      <td>Location Name</td>
      <td><input type="text" name="txt_location_name" value="<?= $location; ?>"></td>
   </tr>
   <tr>
   <td><input type="hidden" name="txt_id" value="<?= $object_id; ?>"></td>
   <td><input type="submit" name="btn_submit" value="Submit"></td>
   </tr>
</table>
</form>
KristenVarney
Saroj Thapa‌ Did you ever figure this out? How has it been working for you?
SarojThapa1
Hi Kristen, I did figure this one out. It's been a while, I even forgot about this post. Will find how I solved it and share it here shortly.
SarojThapa1
I added empty strings "" with else clause. Something like this:
    if (isset($_POST['txt_id'])) {
    } else {
        $id = '';
KristenVarney
Thanks for your reply!
