Create SDE featureclass without username as prefix
1836
08-25-2016 06:22 AM
DharmaRajan
When I create a new featureclass in SDE, it was created with the username as prefix by default.
Example:     user1.testFeatureClass
But I want to create a featureclass without having the username as prefix. How to accomplish this?
Thanks in Advance.
JayantaPoddar
The Feature Name can not be changed. Although you can change the Alias. This would make sure when you add the feature to ArcMap, the alias name would be assigned as the layer name.
Think Location
JoshuaBixby
MVP Esteemed Contributor
In case you are interested in learning a bit more about why you can't do what you want to do:
Transact-SQL Syntax Conventions (Transact-SQL)
SQL Server Best Practices – Implementation of Database Object Schemas
