Consuming web service REST JSON with esriRequest
698
08-23-2016 05:26 AM
AlbertoLópez
Hello;
I want to create a widget   with a function (function _invoqueWS) that retrieves data from a web service REST JSON with  esriRequest.
This function must be invoked from other functions of the widget (startup función for example an others).
I created the following functions but when I try to return the JSON content variable, the variable in the startup function is undefined or null. I have also tried to initialize a global variable in the function _invoqueWS  and recover the value in function startup , but without results. What am I doing wrong. In the  invoqueWS function the JSON data is correct.
I am using  API  3.17 javascript
Thank you very much, greetings.
startup: function()
//other code
        var resultado= this_ invoqueWS ();
//other code
_invoqueWS: function() {
           var resultado
           var  url_servicio="XXXXX";
            var layersRequest = esriRequest({
            url: url_servicio,
            handleAs: "json",
           load: function (result)
          resultado = result.ElementosEstacionOutput[0].ID_ESTADOS_INST_EXPRESION;
           error: function (error)
                  resultado= error;
                     return resultado
