Raster functions - Apparent Reflectance
3671
08-22-2016 02:53 PM
mikebaker1
In the "Apparent Reflectance" function, are the radiance gain and radiance bias values calculated or can they be found in the Landsat 8 metadata. If in the metadata under what labels are they? Thanks for your assistance.
DanPatterson_Retired
Mike, you didn't indicate whether you had read the topic on ...apparent reflectance ... which lists what you can use as imputs and what is available from the metadata
mikebaker1
Hi Dan,
Thank you for pointing to the help resource. For the most part it is
very helpful. It does state the image metadata file is read for input
values by the apparent reflectance function yet yet my ArcPro 1.3 version
does not. There is plenty of postings for Landsat 7 and ArcGIS 10.2, but
those are different animals. If you have any thoughts or experience why the
metadata file is not getting read I would appreciate them.
Take Care,
mike
Mike, specifically for landsat 8, this information had to be available in order for the function to be used.  You would have to check to see if this is the case in the metadata
Reflectance gain and reflectance bias (for Landsat 😎
mikebaker1
Hi Xander,
Thank you for pointing me to the information in the "Apparent
Reflectance function" document.What the information therein does say "All
the information required for the correction is extracted from the key
metadata properties for each image when the function is initialized.". So
am I to assume the reflectance function does not actually read the MLT.txt
file provided with Landsat 8 data? Reflectance gain and reflectance bias are
not labeled as such in the *_MLT.txt so are these values calculated prior
to entering in the function?
Thanks again for your help,
mike
