Can I display Zip Code points from CSV in WAB?
3111
07-21-2016 01:27 PM
deleted-user-8zpXkQfV8bQC
I like the new 'Add Data' Widget in AGOL-WAB, but it wants to open from http: (URL).  All I have is AGOL, desktop, and WAB site I created.  I have a .csv file with a field called 'ZIP' and I have a feature class that has over 33,000 zip code centroids.  What I would like to do, is load the .csv into the WAB site and have the zip code centroids appear as a symbol.  I don't have a LAT/LON, just City, State, and Zip.  No address.  the .csv file changes daily as well.  Any ideas are welcome.  I know geoprocessing can work, I just cannot afford ArcGIS server.  thank you
DanPatterson_Retired
a row or two would help describe visually your table.
Are you looking to geocode first?
Geocode Addresses—Help | ArcGIS for Desktop
assuming you don't have coordinates, since I am not sure what you mean by zip code centroids
Dan,
No, I am not looking to geocode first.  I don't have enough credits for AGOL.  I get 2 or 3 of these csv files a day that I would like to load to my WAB site.  They are operational or temporary layers.
Example of CSV file
ID  Name  City State ZIP
1   Pine Lake Lincoln NE 68512
2   Wahoo Wahoo NE 68066
3  Taylor  Taylor NE 68879
I'd like to upload this csv file.  Need to find the upload.
that could be an issue if you don't have arcmap available to do the geocoding prior to upload.  I know of no alternative to free geocoding
Dan,
I appreciate the attempt.  I am not asking for free geocoding, I am simply asking for a quick way to display a .CSV file with zip codes to place a symbol on zip code centroid - OR - a way in WAB to compare the .csv file with another table full of zip codes, find the matches, and display.   I know in the MAP side of ArcGIS Online when creating the MAP before the APP, I can drop a .CSV file in the MAP with the zip code and symbols will appear it attempt to locate.  It would be cool if I could DROP .CSV to WAB.
Appreciate the response.
