JavaScript API - Measuring Widget Issue
2186
07-21-2016 12:55 PM
IanPeebles
I have tried to add in a measuring widget to my application and cannot get it to work, unless I add in a basemap property to the map.  There isn't much code.  Here is the error I am getting in console mode:
My application code is attached.  In the past, I used the same widget (at version 3.09 but did not have any issues).
Here is a brief snipped of the main application code:
// Define the default geometry service
esriConfig.defaults.geometryService = "http://gis.edmondok.com/arcgis/rest/services/Utilities/Geometry/GeometryServer";
        // Map - Initial Extent
        var initialExtent = new Extent(2097523, 220046, 2189056, 275030, new SpatialReference({wkid: 102724}));
        map = new Map("map", {
         extent: initialExtent,
var measurement = new Measurement({
          map: map,
  defaultAreaUnit: Units.SQUARE_FEET,
  defaultLengthUnit: Units.FEET
        }, dom.byId("measurementDiv"));
        measurement.startup();
var baseMap = new ArcGISDynamicMapServiceLayer("http://gis.edmondok.com/arcgis/rest/services/Base/BaseMap/MapServer", {
           visible: true
map.addLayers([baseMap]);
Any ideas on what could be the issue?  I am using the same geometry and services in other apps and they are working fine.
Thank you!  Ian
KellyHutchins
Esri Notable Contributor
Try creating a new GeometryService and passing in your service url. For example:
esriConfig.defaults.geometryService = new GeometryService("http://gis.edmondok.com/arcgis/rest/services/Utilities/Geometry/GeometryServer");
KellyHutchins
IanPeebles
Kelly, that worked.  BTW, how can I get the units to display as I am drawing a line to get the length?  I only get the units when the draw is completed.
