Is there any way to disable multipatch texturing in Pro?
2650
07-20-2016 08:11 AM
CyrusBlankinship
In arcscene, all you have to do is right click the layer--> properties --> rendering tab --> and select 'Disable material textures'. I can't find the equivalent in Pro
DanPatterson_Retired
strange, the only reference with those key words is  in What's new in ArcGIS Pro 1.1—ArcGIS Pro | ArcGIS for Desktop
and it is associated with Layer 3D To Feature Class—Help | ArcGIS for Desktop
but you could start in the latest 'whats new' and work your way back in case I missed something
What's new in ArcGIS Pro 1.3—ArcGIS Pro | ArcGIS for Desktop
CyrusBlankinship
I found a workaround by exporting the layer to a shapefile since shapefiles do not support layer texturing.
Artur_Ribeiro
Many years after, and without converting to shapefile, is possible to get rid of the texture in arcgis pro.
In the symbology menu, when you choose the symbol to edit, choose properties --> appearence. Material mode is set by default to Multiply. Just change to replace and the texture will be gone 🙂
SveinungBertnesRåheim
Thanks! This took me two hours of nonsense googling, trying and failing. And then the solution was that simple....!
