Invalid redirect_URI Web Application Builder Deployment from Server?
6874
19
07-15-2016 02:52 PM
GeoffreyWest
I have configured an ArcGIS WebApplicationBuilder Map as an application in ArcGIS Online.  It is consumed by IIS6 on a Windows 2003 Server Machine.  When I hit the URL; I receive ERROR 400 Invalid URI_indirect.  My application was copied to my server from AGOL. What is the solution for this if I am not using WebAppBuilder in Development mode?  What should my URI be when I register the app in AGOL?
RobertScheitlin__GISP
Geoffrey,
  The url you should use to register the app is the url that you use to see the app (i.e. http://gisdev01/LifeSupportApplication/​).
Geoffrey,
GeoffreyWest
Thanks Robert,
What about the URI error?
On Fri, Jul 15, 2016 at 3:50 PM, Robert Scheitlin, GISP <[email protected]>
Geoffrey,
You have me confused again. I thought we were talking about properly registering the app so that you would not get a URI error.
GeoffreyWest
I am receiving an invalid URI error, but I have the correct correct URL configured in the app settings in AGOL.
Geoffrey,
OK for my testing purposes, let me see if I have your workflow correct.
  1. build WAB app using AGOL, configuring it as desired.
  2. download the app.
  3. extract the app to your local IIS
  4. open a browser and attempt to access the app and you receive invalid URI error
Is this correct?
GeoffreyWest
Robert,
That is correct, I am prompted for a sign-in. When I click "Ok" the invalid redirect_uri
error appears.  What should this be set to in AGOL?  I have gisdev01:80
On Tue, Jul 19, 2016 at 8:37 AM, Robert Scheitlin, GISP <[email protected]>
Geoffrey,
So your app has secured services in it then?
GeoffreyWest
It doesn't.  Once I click "Ok' as if I am going to sign in the error is thrown.  The only solution that I have seen for this is to remove the signon.json, but that is for the Dev Edition.
Geoffrey,
  OK so I created an WAB AGOL app that uses a web maps that is not shared publicly and downloaded it and deployed it to my local dev machine IIS and I was challenged by the identity manager and I entered my credentials and there was no issue at all the app came right up.
