I have a large mosaic dataset with time-based raster with lots of overlap. My application allows users to specify lots of options and then I use a mosaic rule to shuffle the imagery and produce a mosaic.based on the user's query.
Because of the amount of imagery and how I use the entire stack of historic dates to "fill in the mosaic" I do not know from the user's options which rasters are participating in the mosaic.
So my question is, is there any way to know which rasters were used to generate a given mosaic in a ArcGISImageServiceLayer? I need just the ones visible, not all the others that weren't used because they were at the bottom of the stack.
Thanks!
Layth
Solved! Go to Solution.
When performing an ImageServiceIdentifyTask (ImageServiceIdentifyTask | API Reference | ArcGIS API for JavaScript 3.17 ), you can define the ImageServiceIdentifyParameters (ImageServiceIdentifyParameters | API Reference | ArcGIS API for JavaScript 3.17 ) where you can set the mosaicRule (ImageServiceIdentifyParameters | API Reference | ArcGIS API for JavaScript 3.17 and MosaicRule | API Reference | ArcGIS API for JavaScript 3.17 ) and use the METHOD_LOCKRASTER method to list the participating raster IDs. The first one from the resulting list should be the one you are looking for.
