Print Widget (JSON based web map print)
3428
06-29-2016 12:00 AM
AnjulPandey
Hi, I want to change map service url in Web map as JSON  before printing the web map? in other words , I don't want to print map object and want specify other map service url in JSON print parameter?
Tags (1)
FC_Basson
Not sure if I'm understanding your question 100%, but you can change the parameters of any GP task request before it is sent to the server with the setRequestPreCallback funciton: esri/request | API Reference | ArcGIS API for JavaScript 3.17
To change the URL of an operational layer you can add this to your code where you are specifying the print task:
esriRequest.setRequestPreCallback(function(ioArgs){
  // check if request is a web map print request
  if (ioArgs.content && ioArgs.content.Web_Map_as_JSON){
    var webMapAsJson = ioArgs.content.Web_Map_as_JSON;
    var webMapObj = JSON.parse(webMapAsJson);
    // iterate through operational layers on the map
    for (o in webMapObj.operationalLayers) {
      var wmo = webMapObj.operationalLayers;
      if (wmo.title = "MyLayer"){
        wmo.url = "http://newurl";
  return ioArgs;
FC_Basson
  return ioArgs;
