Web AppBuilder not displaying map
4967
5
06-29-2016 02:16 AM
RachaelLee
Yesterday I tried to edit an app I built online however the map did not load, the configure pane did but the map area was blank. It was a map I created online, now when I try to load the app to just view it and it wont display there either.
The original web map will load in the map viewer but wont in the app.
I've tried to recreate the app again but it wont load the map or any map.
I have tried different browsers as well and didn't work on there either.
if I change the layout it pops up saying certain widgets aren't available but still no map.
Any ideas? is it just a bug from the upgrade? or am I doing something wrong?
UPDATE 30/06/2016
I fixed it by creating a new map with all the same data in as before and working fine now
JoanBiediger
Rachael is it possible that you have mixed content?  I have run into this problem before where layers draw up in the map viewer but not the Web AppBuilder.
RachaelLee
Hi Joan
All my point layers are on AGOL except for my basemap which was hosted off the server.
Strange thing is it worked fine last week as I was adding queries to the map but now it doesn't.
AdrianWelsh
MVP Honored Contributor
Hi Rachael,
Can you give more details to what you are doing? Are you using Web AppBuillder Developer edition? If so, it might be best to place this in Web AppBuilder for ArcGIS​ space.
Can you post a link to your web map?
Also, if using WAB Dev edition, be sure you have started your startup.bat file prior to opening your maps.
RachaelLee
Hi Adrian
I'm using the Web AppBuilder on AGOL
This is all I get when I try to edit it
AdrianWelsh
Rachael,
Can you go o the map tab towards the top in your screen shot and re-appropriate the web map (or use another web map)? Maybe it's a permissions issue? Can you verify that your maps are shared appropriately (mainly public)?
