ArcGIS 10.3.x Python tool script - Error for required parameters when disabled
2457
06-28-2016 08:50 AM
FrancescoTonini2
In the python script tool I am programming (see code below), I am using a simple boolean checkbox to enable/disable certain parameters in the script GUI. However, even though the parameters get disabled correctly (greyed out, see screen capture), when I add points to my featureSet parameter interactively and click on OK to run, I receive error 000735 that the parameters I disabled are "required", impeding the run.
Is there any workaround to having to set inTable, X_field, and Y_field as "Optional"? In other words, can those 3 appear as Required and be correctly disabled without impeding script execution?
Code:
# Import all necessary module dependencies
import arcpy
import os
import sys
arcpy.env.outputCoordinateSystem = arcpy.SpatialReference(3857)
def DrawSystems():
   # Local variable:
   out_layer = "Systems_lyr"
   # Get the value of the input parameter
   isChecked = arcpy.GetParameter(0)
  inTable = arcpy.GetParameterAsText(1)
  X_field = arcpy.GetParameterAsText(2)
  Y_field = arcpy.GetParameterAsText(3)
  inFeatureSet = arcpy.GetParameterAsText(4)
  arcpy.SetProgressorLabel('Creating System Components ...')
  arcpy.AddMessage('Creating System Components ...')
   if isChecked == False:
       if inTable or inTable != "#":
           try:
              # Process: Make XY Event Layer (temporary)
              arcpy.MakeXYEventLayer_management(table=inTable,
        in_x_field=X_field, in_y_field=Y_field,
        out_layer=out_layer)
           except Exception:
               e = sys.exc_info()[1]
               arcpy.AddError('An error occurred: {}'.format(e.args[0]))
else:
       if inFeatureSet or inFeatureSet != "#":
           try:
               # Process: Make Feature Layer (temporary)
               arcpy.MakeFeatureLayer_management(in_features=inFeatureSet, out_layer=out_layer)
           except Exception:
             arcpy.AddError('An error occurred: {}'.format(e.args[0]))  # Process: Create Feature Class from Feature Layer
          #### Create Feature Class & Add Coordinates ####
          try:
              # Process: Copy Feature Class
              outSystems_fc = os.path.join(arcpy.env.scratchGDB, "Systems")
              outFC = arcpy.CopyFeatures_management(out_layer, outSystems_fc)
              arcpy.SetProgressorLabel('Adding XY Coordinates ...')
              arcpy.AddMessage('Adding XY Coordinates ...')
              # Process: Add Coordinates
              arcpy.AddXY_management(outFC)
          except:
              arcpy.AddIDMessage("ERROR", 930)
  #### Set Parameters ####
arcpy.SetParameter(5, outFC)
if __name__ == '__main__':
  DrawSystems()
WesMiller
You could try to use a python tool box and   if isChecked == False: then parameterType = "Optional"
Customizing tool behavior in a Python toolbox—Help | ArcGIS for Desktop
FrancescoTonini2
Wes, I thought that parameterType is a read-only property...so that would not work if that is the case.
