Unable to access Server directories using Virtual Path
2032
06-23-2016 11:11 PM
PrasadG
Hi....
Can anyone please Help me ????
We are Using ArcGIS Server Manager 10.3.1 version to run our services. We need to access the server directories of ArcGIS Server Using the Virtual Path. In Esri Help it was said that Once you create a server directory, it is automatically exposed through a URL when u deploy it in web server.
But we are not able to do it. Can anyone please tell us where we are doing wrong?
Please tell us the procedure to do it.....
Thank you
RebeccaStrauch__GISP
Hi, you have this question in the Developer area.  If you are trying to do this as a part of a script or program, you may want to supply some additional into.  If you are just installing, I suggest moving this tothe ArcGIS for Server​ area for more exposure.
I will assume you are just setting this up?  Have you checked out  Log in to Manager—Documentation (10.4) | ArcGIS for Server  , specifically the logging in for the first time?   You can access the admin/manager from within ArcCatalog, or in a browser with
     http://<machinename>:6080/arcgis/manager
until you set up access in your web server (IIS for example) and a web adaptor.  Once you go thru the web adaptor setup and use the web path, you will not be using the 6080 (default is 80 and assumed, unless you set up security, sugin https  in which case it is 443)
If you are at a step beyond that and are still having issues, it may help us to know what step you are on, and whether you are getting an error or not.  Also, a link to the line that you quoted might help us determine where you are in the process.
