How to pass filters between widgets?
3375
06-20-2016 08:51 AM
Alexwang
I am relatively new to the WAB development. I have two widgets in my application which need to communicate with each other. So if the the attribute queries change in one widget, i need to pass the filters to another widget and update the query results when a click event is trigger on the first widget. How to achieve it?
Tags (1)
RobertScheitlin__GISP
Alex,
  Sounds like you want to look into Widget Communication Communication between widgets—Web AppBuilder for ArcGIS (Developer Edition) | ArcGIS for Developers . Also in WAB 2.0 there is a sample of widget communication: client\stemapp\widgets\samplewidgets\WidgetCommunication
Alex,
Alexwang
thank you!
KisakyeM
@Alexwang how did you access the click event of the filter widget?
