I am relatively new to the WAB development. I have two widgets in my application which need to communicate with each other. So if the the attribute queries change in one widget, i need to pass the filters to another widget and update the query results when a click event is trigger on the first widget. How to achieve it?
Solved! Go to Solution.
Alex,
Sounds like you want to look into Widget Communication Communication between widgets—Web AppBuilder for ArcGIS (Developer Edition) | ArcGIS for Developers . Also in WAB 2.0 there is a sample of widget communication: client\stemapp\widgets\samplewidgets\WidgetCommunication
Alex,
