Edit only a selection of features
2937
06-16-2016 12:07 PM
deleted-user-x7XmeRtVHyGE
Hello all,
I have an app with a dynamic query of a feature service that changes depending on user input. This adjusts what is displayed to the user depending on their needs. We deploy the editor widget then to work on that feature class. We run into issues with data not part of the original query showing up. Is there a solution to only edit the selectedfeatures from the original query?
Enjoy the day,
Mike
RickeyFight
Mike,
Are you using WAB? Or a custom Script?
Rickey,
We are using a custom script.
Mike
RickeyFight
If I understand you right, you want to definition query a layer and edit the resulting features?
Possibly, if we could apply a geometric query to the layer. We are using the geometry engine to create a selection that is then displayed to the user.
Thanks for your help,
Mike
