Display documents in datagrid
2327
06-15-2016 03:30 AM
SadanandacharB1
Hi All,
        I have one feature class with columns like ID, STATION_NAME, ATT1,ATT2,..,LAT,LONG,PDF, etc.
And i have created one mapservice for this "http://xxx/Arcgis/rest/services/NSDL/mapserver".
My question is how to display all the attribute information on map click using Identify task and also depending on the point i have selected , I need to display the pdf document of that point feature, stored in the server folder(It may be  local or externel). I am storing only pdf names in the PDF columns.
My result should be like this,
One side my map and beside that i need to display resultant attributes with pdf documet.
Can you people please help me on this issue
Thanks!
PanagiotisPapadopoulos
you can prepare a spatial view on SDE geodatabase with a field containing the full path. Full path can be constructed using SQL.
An alternative is to create this path on Web App level (with javascript + HTML) when you creating the Pop - Up info.
SadanandacharB1
Hi thank you for your kind replay,
Sorry, but can you show me simple example
