I tried https://developers.arcgis.com/javascript/3/jssamples/fl_hover.html
1941
06-13-2016 12:20 PM
BulbulMajumder1
It is almost what I am looking for. Only the difference what I would like "to hover on point-objects on the map, instead of area-boundary (as shown in this sample code)". Please help.
FC_Basson
In the sample the FeatureLayer source is of geometry type polygon, so if you change the sample code to use a point geometry layer as source, then it should do exactly what you require.  You just need to supply a point feature source.
