Select multiple features
4778
06-08-2016 11:15 PM
SadanandacharB1
Hi All,
               I am new to arcgis javascript api, I want to select multiple features on the map using polygon and show the resultent attributes in a datagrid, i need some examples for this , Please help on this issue
Thank You
Sadanand
PanagiotisPapadopoulos
first you have to allow to draw a polygon graphic in to the map.
see this sample how to use draw toolbar Add graphics to a map | ArcGIS API for JavaScript
then you have to use this polygon graphic in order to select features from an another layer
see this sample how to execute spatial queries Select features within a two minute drive time | ArcGIS API for JavaScript
finally the results form the query must be the data store for a dgrid object. Also you can use the Feature Table for this
DataGrid with zoom button | ArcGIS API for JavaScript
Using FeatureTable | ArcGIS API for JavaScript
