AttributeInspector with a custom combobox
2729
06-07-2016 01:31 PM
InbalMiller
Hi everyone! I have a bit of a problem.
My att inspector needs to have two comboboxes in it - one is set by the layer's symbology and is working, and the other needs to be set by a table of consts, with a foreign key to the main table.
I have been trying to add this combobox for over a week, but to no avail.
I've tried using the customField attribute in the att inspector's fields with a dijit I made, containing the combobox and getting the values from a new layer, but it didn't work at all.
Then, I tried adding a domain to the field in the main table with all the values I need, and the combobox did appear but now I can't save changes. Tried to set the table as both versioned and unversioned, didn't work either way.
How can I place this combobox while still saving changes? Is there even a way to do that in att inpector?
Thanks a lot!
Inbal
PanagiotisPapadopoulos
try to add new values on the domain you created through a geoprocessing service which using the tool ADD CODED VALUE TO DOMAIN.
InbalMiller
Thank you for the answer, but I think you didn't understand what I meant.
I already have the values, this is not the problem. The problem is saving the changes to the main table... I want to do that using attribute inspector, but it's not working...
