Help with code: 400 Publishing Error - "folder title not available"
21852
12
06-05-2016 09:09 AM
OscarSepulveda_III
I continually receive the following error message when trying to publish my survey from Survey123ConnectBeta v.1.4.30
Publishing Error  code: 400 ["Folder title 'Survey-Daily_Vehicle_Checkout' not available."
I looked over my xlsform and the survey and choices tabs follow all defined parameters.  The survey works in Survey123ConnectBeta, yet will not publish.  I looked over the GeoNet and it appears that code: 400 is a "catch all" for issues.
I have attached the excel spreadsheet as well.
Any help would be most appreciated.
IsmaelChivite
Esri Notable Contributor
Hi.
try the following:
  1. In ArcGIS.com, login and go to 'My Contents'
  2. Look for the 'Survey-Daily_Vehicle_Checkout' folder and delete it
  3. In Connect, select the Survey Daily Vehicle Checkout so you  can preview it
  4. Click on the yellow button (looks like a folder) to open your Survey's directory in a File Explorer
  5. Next delete the Daily_Vehicle_Checkout.iteminfo file
  6. Back in Connect, try Publishing again
It looks like you may have deleted manually the Form and Feature Service from ArcGIS.com and left Connect and ArcGIS.com out of sync. Let me know if the above works for you.
IsmaelChivite
Hi.
try the following:
OscarSepulveda_III
You were correct!  Thank you Ismael !
IsmaelChivite
Thanks for confirming.
Now you  know!   We will try to put some time into making the publishing process account better for this.
RebeccaStrauch__GISP
Oscar, since Ismael's step fixed your issue, please click on the "correct answer" on that comment to close out this thread. Thanks.
MahdiWehbi1
Dears,
I have a similar error but it couldn't be solved by the above suggested solution.
Thank you,
Regards
JamesTedrick
Esri Esteemed Contributor
Hi Mahdi,
While some parts of the error are similar, this publishing attempt failed at a different stage.  Can you provide the XLS file used to make the survey?
LeemTow_Shen
Same issue here.
Attached is the xls form used to create the survey
JamesTedrick
The first note has an extremely long name; the maximum field name length in ArcGIS Online is 128 characters.
AideenCroasdell
I have the same error and I tried the same steps above but my survey still failed to publish?
error400survey123connect
Not sure what to do next, I created the survey twice and I still get the same error?
Any ideas how I can fix this?
Aideen
