Selecting Points and assigning value
3542
06-03-2016 07:04 AM
TimHayes1
I know how to do this in ArcGIS for Desktop. But, is it possible to do this in WAB?
- Select 300 to 500 points and assign a value to them all at once. For example, I select 300 points and assign a value of "C" to all of them in the "POINT VALUE" field in the attribute table. (Note: the "POINT VALUE" field would have already been created beforehand outside the WAB). Then export the attribute table as a CSV or .xlsx?
Which widget would you recommend I use? My guess is the query widget?
RobertScheitlin__GISP
Tim,
  You will want to look at the batch attribute editor widget in WAB 2.0.
Tim,
