LayerListWidget on mobile
2525
06-01-2016 09:04 AM
MarcoRosa
Hello all,
im looking to editing mobile sample at the following address.
Attribute editing - mobile | ArcGIS API for JavaScript
Tried to custom that, adding LayerList legend , on new page opening after a button press.
Code for legend widget page is:
<data-role="page" id="ui-control-layer-dialog">
<div data-role="header">
<h2>Legend</h2>
</div>
<div class="ui-content">
<div id="control-layer-div" class="legend-container"></div>
<a href="#ui-map-page" data-role="button" class="ui-btn">Close</a>
</div>
</div>
.... and code for layer list is ...after adding feature layer
appGlobals.map.addLayers([appGlobals.citizenRequestLayer]);
var llWidget = new LayerList({
true,
true,
"feature layer citizen",
true
"control-layer-div");
llWidget.startup();
it works, but after opening page i can see two check boxes overlapped ... the top most doesnt work (if cheeck or uncheck nothing change) and the oter check box work but is under first and i cant work on that.
Any suggestion for that ?
Thanks in advance
GP
