SourceUri and TemplateUri binding in MVVM
458
05-26-2016 12:24 PM
KeithGemeinhart
Working in ArcGIS runtime for .NET version 10.2.7 ....
I've noticed that WebTiledLayer's TemplateUri property and KmlLayer's SourceUri property don't respond to updates when using data binding with via MVVM pattern. Is this a known bug, or has it been designed this way, or am I possibly doing something wrong?
If I use the following code, the layer is updated:
var layer = MapView.Map.Layers["weather"] as WebTiledLayer;
layer.TemplateUri = "...." + "/" + "{level}/{col}_{row}.png"; // working
However, if I do something like this, it doesn't update:
In xaml ...
<esri:WebTiledLayer ID="AccuWeather" TemplateUri="{Binding WeatherUri, UpdateSourceTrigger=PropertyChanged}" />
In C# view model ...
WeatherUri = "...." + "/" + "{level}/{col}_{row}.png"; // not working
And I have confirmed that property changed event fires when WeatherUri is updated.
There is similar behavior with KmlLayer's SourceUri property. It doesn't work with data binding either. Instead I have to delete and add the layer again which is causing flickering on my map.
