How do I make filtering select work when using dojo dialog popup?
1739
05-25-2016 01:03 PM
RobertKirkwood
I have a popup window that is a dialog box. When it is open the filtering select drop downs do not work. I know this has to do with modal/non-modal. I have made the box non-modal so the map and other buttons can be used. However, the filtering select functionality does not work. Any suggestions?
p.s. i have also used the floating pane window but this does not work with other functionality i need. The filtering select will eventually work if you hold the down arrow but the users will not know this.
