PROXY ERROR
6406
5
05-19-2016 05:47 AM
bharathreddy
HI
I am unable load query due to proxy issue please help.here is the attachement
error is
Unable to load /proxy?http://192.168.2.35/ArcGIS/rest/services/point/MapServer/25/query status: 12030
please help
RobertScheitlin__GISP
Bharath,
  I am not sure how we can help you with such limited information.
You should show your code, especially where you are defining and using the proxy.
bharathreddy
hi robert i am posting my code while i am trying draw a line and select features i am unable to get result in internet explorer it showing the error which i had attached in original post
dojo.require("dijit.layout.BorderContainer");
        dojo.require("dijit.layout.ContentPane");
        dojo.require("esri.map");
        dojo.require("esri.tasks.geometry");
        dojo.require("esri.toolbars.draw");
        dojo.require("esri.tasks.query");
        dojo.require("esri.layers.FeatureLayer");
        dojo.require("dojox.grid.DataGrid");
        dojo.require("dojo.data.ItemFileReadStore");
        dojo.require("dojo/_base/array");
        dojo.require("dojo/store/Memory");
        dojo.require("esri.tasks.find");
        var map, gsvc, tb, arrayUtils;
        var grid, store, data, OnDemandGrid, Memory;
        var findTask, findParams;
        function initialize() {
            map = new esri.Map("map", {
                center: [-111.5, 39.541],
                zoom: 7
            landBaseLayer = new esri.layers.ArcGISDynamicMapServiceLayer("http://192.168.2.35/ArcGIS/rest/services/point/MapServer", { opacity: 5.55 });
            map.addLayer(landBaseLayer);
            dojo.connect(map, "onLoad", initToolbar);
            gsvc = new esri.tasks.GeometryService("http://192.168.2.35/ArcGIS/rest/services/Geometry/GeometryServer");
            esri.config.defaults.io.proxyUrl = "/proxy";
            esri.config.defaults.io.alwaysUseProxy = false;
            function initToolbar(map) {
                tb = new esri.toolbars.Draw(map);
                dojo.connect(tb, "onDrawEnd", doBuffer);
            function doBuffer(geometry) {
                debugger;
                if (geometry.type == "point") {
                    var symbol = new esri.symbol.SimpleMarkerSymbol(esri.symbol.SimpleMarkerSymbol.STYLE_SQUARE, 10, new esri.symbol.SimpleLineSymbol(esri.symbol.SimpleLineSymbol.STYLE_SOLID, new dojo.Color([255, 0, 0]), 1), new dojo.Color([0, 255, 0, 0.25]));
                else if (geometry.type == "polyline") {
                    var symbol = new esri.symbol.SimpleLineSymbol(esri.symbol.SimpleLineSymbol.STYLE_DASH, new dojo.Color([255, 0, 0]), 1);
                else if (geometry.type == "polygon") {
                    var symbol = new esri.symbol.SimpleFillSymbol(esri.symbol.SimpleFillSymbol.STYLE_NONE, new esri.symbol.SimpleLineSymbol(esri.symbol.SimpleLineSymbol.STYLE_DASHDOT, new dojo.Color([255, 0, 0]), 2), new dojo.Color([255, 255, 0, 0.25]));
                var featureLayer = new esri.layers.FeatureLayer("http://192.168.2.35/ArcGIS/rest/services/point/MapServer/" + ddlViewBy.value, {
                    mode: esri.layers.FeatureLayer.MODE_SELECTION,
                    outFields: ["*"]
                map.addLayer(featureLayer);
                var symbol = new esri.symbol.SimpleMarkerSymbol().setColor(new dojo.Color([255, 0, 0]));
                featureLayer.setSelectionSymbol(symbol);
                var graphic = new esri.Graphic(geometry, symbol);
                //                map.graphics.add(graphic);
                //setup the buffer parameters
                var params = new esri.tasks.BufferParameters();
                params.distances = [dojo.byId("distance").value];
                params.bufferSpatialReference = new esri.SpatialReference({ wkid: dojo.byId("bufferSpatialReference").value });
                params.outSpatialReference = map.spatialReference;
                params.unit = eval("esri.tasks.GeometryService." + dojo.byId("unit").value);
                if (geometry.type === "polygon") {
                    debugger;
                    //if geometry is a polygon then simplify polygon.  This will make the user drawn polygon topologically correct.
                    gsvc.simplify([geometry], function (geometries) {
                        params.geometries = geometries;
                        gsvc.buffer(params, showBuffer);
                } else {
                    params.geometries = [geometry];
                    gsvc.buffer(params);
                //code used to set graphics for polygon buffer//////////////////////////////////////////////
                function showBuffer(bufferedGeometries) {
                    debugger;
        esri.symbol.SimpleFillSymbol.STYLE_SOLID,
                    dojo.forEach(bufferedGeometries, function (geometry) {
                    tb.deactivate();
                    map.showZoomSlider();
                var highlightSymbol = new esri.symbol.SimpleMarkerSymbol().setColor(new dojo.Color([255, 0, 0]));
                gsvc.on("buffer-complete", function (extent) {
                    //                  console.log(extent);
                    var results = [];
                    dojo.forEach(map.graphics.graphics, function (graphic) {
                gsvc.on("buffer-complete", function (result) {
                    //draw the buffer geometry on the map as a map graphic
                                      new dojo.Color([255, 0, 0, 0.65]), 2
                                    new dojo.Color([255, 0, 0, 0.35])
                    var bufferGeometry = result.geometries[0];
                    //                  console.log(bufferGeometry);
                    var graphic = new esri.Graphic(bufferGeometry, symbol);
                    //Select features within the buffered polygon. To do so we'll create a query to use the buffer graphic
                    //as the selection geometry.
                    var query = new esri.tasks.Query();
                    //                  console.log(query);
                    query.geometry = bufferGeometry;
                    featureLayer.selectFeatures(query, esri.layers.FeatureLayer.SELECTION_NEW, function (results, i) {
                        $("#getData").empty();
                        var c = featureLayer.getSelectedFeatures();
                        var raja = 0;
                        if (c.length > 0) {
                            for (n = 0; n < c.length; n++) {
                                var o = c.attributes,
                                o1 = JSON.stringify(o);
                                o2 = o1.replace("{", ""),
                                o3 = o2.replace("}", ""),
                                o4 = o3.split(",");
                                var c1 = "<table border='0' cellspacing='0' cellpadding='0'><tr>";
                                if (o4.length > 0) {
                                    if (raja == 0) {
                                        for (s = 0; s < o4.length; s++) {
                                            o5 = o4.split(":");
                                            o6 = o5[0].replace('"', '');
                                            o6 = o6.replace('"', '');
                                            o7 = o5[1];
                                            c1 += "<td style='border: solid 1px; background-color: #ccc;height:50px;'>" + o6 + "</td>";
                                        raja = 1;
                                    c1 += "</tr><tr>";
                                        o5 = o4.split(":");
                                        o7 = o5[1];
                                        c1 += "<td style='border: solid 1px;min-width: 250px;'><p>" + o7 + "</p></td>";
                                    c1 += "</tr></table>"
                                    $("#getData").append(c1);
                        var totalPopulation = sumPopulation(results);
                        var r = "";
                        r = "<b>The total Census Block population within the buffer is <i>" + totalPopulation + "</i>.</b>";
                        dojo.byId('messages').innerHTML = r;
        function errorMessage(error) {
            debugger;
            console.log(error);
        function sumPopulation(features) {
            var popTotal = 0;
            for (var x = 0; x < features.length; x++) {
                popTotal = popTotal + features.attributes["OBJECTID"];
            return popTotal;
Bharath,
  Have you tested your proxy to be sure it is working?
bharathreddy
I dont know how to test please give some information to test
Bharath,
  Testing the proxy is covered in the resourse proxy readme.md.
http://[yourmachine]/DotNet/proxy.ashx?ping
