addAttachment on secure service using proxy returns 500 internal server error
4620
05-17-2016 09:13 AM
KathleenBrenkert
If I use an non-secured feature service, it does not use the proxy and I have no problem uploading an attachment.  As soon as I use a secure feature service, I get 500 internal server error.  I'm at a complete loss.  I've called support and they are researching it.  It seems to be a problem with the proxy, possibly in how I've set it up, but I can't figure it out.  Using the dotnet proxy from esri's github.
code below works if my service is not secure, but the fLayer I've plugged in here is secure and I get the 500 error.  Server 10.3.1, Javascript 3.13
html:
<form id="attachOne">
        <label class="file_upload">Select a file to attach:</label>
        <input type="file" name="attachment"  />
    </form>
    <input type="button" id="submitButton" value="Upload">
javascript:
require(["esri/config","esri/dijit/editing/Add",
"esri/layers/FeatureLayer", "esri/urlUtils","dojo/dom",  "dojo/on",
"dojo/domReady!"
], function (esriConfig, Add, FeatureLayer, urlUtils, dom, on){
    "use strict";
    urlUtils.addProxyRule({
                urlPrefix: "https://gis.northcharleston.org/arcgis/rest/services/Feature/OneStopShop/FeatureServer/",
                proxyUrl:"https://gis.northcharleston.org/DotNet/proxy.ashx"
    on(dom.byId("submitButton"), "click", uploadFile);
    function uploadFile(){
        var fLayer=new FeatureLayer("https://gis.northcharleston.org/arcgis/rest/services/Feature/OneStopShop/FeatureServer/0");
        fLayer.addAttachment(24404, document.getElementById("attachOne"), function(result){console.log(result);}, function(errorMessage){console.log(errorMessage);});
RobertScheitlin__GISP
Kathleen,
And you have a serverUrl added in your proxy.config for "https://gis.northcharleston.org​" right?
KathleenBrenkert
Yes, the proxy works as far as loading my secure service to a map and applying edits. It wasn't until I attempted to attach files that I started getting the error.
Sent from my iPhone
Kathleen,
  There must be an issue with the proxy not doing the attachment requests through the proxy then. Sorry I can not bee of more help.
KathleenBrenkert
Thanks for trying, I’m not having any luck with support yet either.
