Layer List Widget - Looking to Expand Two Layers on Application Load
4320
05-11-2016 09:23 AM
IanPeebles
I have an application using the layer list with legend.  When the application loads, I am looking to have two of the layers automatically expanded.  So far, I can get one to expand on load, but I want another layer.  Here is what I have:
The code to accomplish this task is:
// Layers Widget - Choose Child to be Expanded on Load
layerList.on("load", function() {
  layerList._layersNode.firstElementChild.className += " esriListExpand";
When the application loads, I am wanting these layers to display like the screenshot below:
I was thinking something like this, but it does not seem to work.
//layerList.on("load", function() {
//  layerList._layersNode.secondElementChild.className += " esriListExpand";
Does someone know of another method I can use to have both layers expanded on map load?
Thank you!
RobertScheitlin__GISP
Ian,
  Here is a sample showing how I would do that:
<!DOCTYPE html>
<html>
<head>
<title>Layer List Dijit</title>
<link rel="stylesheet" href="https://js.arcgis.com/3.16/dijit/themes/claro/claro.css">
<link rel="stylesheet" href="https://js.arcgis.com/3.16/esri/css/esri.css">
<style>
html, body, .container, #map {
    height:100%;
    width:100%;
    margin:0;
    padding:0;
    margin:0;
    font-family: "Open Sans";
#map {
    padding:0;
#layerListPane{
    width:25%;
.esriLayer{
  background-color: #fff;
.esriLayerList .esriList{
    border-top:none;
.esriLayerList .esriTitle {
  border-bottom:none;
.esriLayerList .esriList ul{
</style>
<script>var dojoConfig = { parseOnLoad: true };</script>
<script src="https://js.arcgis.com/3.16/"></script>
<script>
require([
    "esri/map",
    "esri/layers/ArcGISDynamicMapServiceLayer",
    "esri/dijit/LayerList",
    "dojo/query",
    "dojo/dom-class",
    "dijit/layout/BorderContainer",
    "dijit/layout/ContentPane",
    "dojo/domReady!"
], function(
    Map,
    ArcGISDynamicMapServiceLayer,
    LayerList,
    query,
    domClass
  var map = new Map("map", {
    basemap: "topo",
    center: [-123, 47],
    zoom: 8,
    sliderStyle: "small"
  var atlasLayer = new ArcGISDynamicMapServiceLayer("http://sampleserver6.arcgisonline.com/arcgis/rest/services/Census/MapServer", {
    "id": "atlasLayer",
    "showAttribution": false
  var atlasLayer2 = new ArcGISDynamicMapServiceLayer("http://sampleserver6.arcgisonline.com/arcgis/rest/services/911CallsHotspot/MapServer", {
    "id": "911CallsHotspot",
  var atlasLayer3 = new ArcGISDynamicMapServiceLayer("http://sampleserver6.arcgisonline.com/arcgis/rest/services/CommunityAddressing/MapServer", {
    "id": "CommunityAddressing",
  map.addLayers([atlasLayer, atlasLayer2, atlasLayer3]);
  var llWidget = new LayerList({
    map: map,
    layers: [{
      layer: atlasLayer,
        subLayers: true
      layer: atlasLayer2,
        id: "911 Calls Hotspot",
        subLayers: true
      layer: atlasLayer3,
        id: "Community Addressing",
        subLayers: true
  },"layerList");
  llWidget.startup();
  llWidget.on('load', function(){
    expandLayerList();
  function expandLayerList() {
    query('.esriLayer').forEach(function(node, index){
      if(index < 2){
        domClass.add(node, "esriListExpand");
    query('.esriToggleButton').forEach(function(node, index){
      if(index < 2){
        domClass.replace(node, "esri-icon-down", "esri-icon-right");
</script>
</head>
<body class="claro">
<div class="container" data-dojo-type="dijit/layout/BorderContainer"
data-dojo-props="design:'headline',gutters:false">
<div id="layerListPane" data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'right'">
    <div id="layerList"></div>
</div>
<div id="map" data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'center'"></div>
</div>
</body>
</html>
Ian,
<!DOCTYPE html>
<html>
<head>
<style>
    height:100%;
    width:100%;
    margin:0;
    padding:0;
    margin:0;
#map {
    padding:0;
#layerListPane{
    width:25%;
.esriLayer{
    border-top:none;
  border-bottom:none;
</style>
<script>
require([
    "esri/map",
    "dojo/query",
    "dojo/dom-class",
    "dojo/domReady!"
], function(
    Map,
    LayerList,
    query,
    domClass
    basemap: "topo",
    center: [-123, 47],
    zoom: 8,
    "id": "atlasLayer",
    map: map,
    layers: [{
      layer: atlasLayer,
        subLayers: true
      layer: atlasLayer2,
        subLayers: true
      layer: atlasLayer3,
        subLayers: true
  },"layerList");
  llWidget.startup();
    expandLayerList();
      if(index < 2){
      if(index < 2){
</script>
</head>
</div>
</div>
</body>
</html>
IanPeebles
Thank you much Robert!  Always appreciate your feedback.  I found another way to do this:
This block of code also solves the issue.  The childNodes have an index number:
// Layers Widget - List of Layers to Include
var layers = [
  layer: airPhoto,
  showSubLayers: false,
  showLegend: false,
  visibility: false
  layer: baseMap,
  showSubLayers: true,
  showLegend: true,
  visibility: true
  layer: sewer,
  showLegend: true,
  visibility: true
  layer: wwlmMaintenance,
  showLegend: true,
  visibility: true,
// Layers Widget - Add List
var layerList = new LayerList({
  map: map,
  showLegend: true,
  showOpacitySlider: false,
  layers: layers
},"layerList");
// Layers Widget - Choose Child to be Expanded on Load [0] Indexing Number in Order
  layerList._layersNode.childNodes[0].className += " esriListExpand";
  layerList._layersNode.childNodes[1].className += " esriListExpand";
// Layers Widget - Start Up
layerList.startup();
James_001
Ian,
How to add turn on and off crime type layers. I want to add check on each type in WAB developer edition in layer list.  Right now if I will check in crime type it turns on all of them, I wonder it is possible to add a check for each type? If there is any option how I will configure in WAB Developer edition. Sorry, I am new to WAB.
RickeyFight
You could apply a definition query and add each definition individually. Or apply a filter
