LayerList reload not working
2683
05-11-2016 02:42 PM
DougCollins
I have an application where I need to switch out layers when a user makes a selection from a dropdownlist.  I have the switching of the layers working fine, but I cannot get the LayerList to refresh with the newly selected layer.  The LayerList works fine when the application loads, but when a layer is switched it does not work.  I have tried to use the refresh method but that does not seem to work.  Perhaps I am doing something wrong.  I have a simplified version of what I am trying to do in the Javascript code below.   I am using JS API version 3.16.
Charlie
require([
  "dojo/dom", "dojo/parser", "dojo/on", "dojo/query", "dojo/dom-class",
  "dojo/dom-style", "dojo/dom-construct",
   "esri/map",
  "esri/layers/ArcGISDynamicMapServiceLayer",
  "dijit/registry",
  "esri/dijit/LayerList",
  "dijit/form/Button",
  "dijit/layout/BorderContainer",
  "dijit/layout/TabContainer",
  "dijit/layout/ContentPane",
  "dijit/TitlePane",
  "dijit/Dialog",
  "dijit/form/TextBox",
  "dijit/form/ComboBox",
  "dojo/domReady!"
], function(
  dom, parser, on, query, domClass,
  domStyle, domConstruct,
   Map, ArcGISDynamicMapServiceLayer,
   registry, LayerList )
  parser.parse();
  // Define layers and URL variables
  var dynamicLayer;
  var staticLayer;
  var dynLayerURL;
  var staticURL = "https://sampleserver6.arcgisonline.com/arcgis/rest/services/NapervilleShelters/MapServer";
  var layer1URL = "https://sampleserver6.arcgisonline.com/arcgis/rest/services/DamageAssessment/MapServer";
  var layer2URL = "https://sampleserver6.arcgisonline.com/arcgis/rest/services/CommercialDamageAssessment/MapServer";
  // Get the layer drop down list
  var selectedLayer = registry.byId('layerDropDown');
  selectedLayer.on('change', setLayer);
  // Start out with layer selected in dropdownList
  var layerValue = selectedLayer.get('value');
  if (layerValue == '1') {
  dynLayerURL = layer1URL;
  else if (layerValue == '2') {
  dynLayerURL = layer2URL;
  map = new Map("mapPanel", {
        center: [-98.2, 40.05],
        zoom: 5,
        basemap: "national-geographic"
  // Define layers as ArcGISDynamicMapServiceLayers
  dynamicLayer = new ArcGISDynamicMapServiceLayer(dynLayerURL, { visible: true });
  staticLayer = new ArcGISDynamicMapServiceLayer(staticURL, { visible: true });
  // Add the LayerList
  var layerList = new LayerList({
       map: map,
       showLegend: true,
       layers: [ {layer: staticLayer, id: "Shelters", sublayers: true}, {layer: dynamicLayer, id: "Assessment", sublayers: true}]
  }, "legendDiv");
  layerList.startup();
  layerList.on('load', function(){
  expandLayerList();
  // ADD the LAYERS
  map.addLayers([staticLayer, dynamicLayer]);
  function loadDynamicLayer() {
  // Remove the current dyamicLayer
  map.removeLayer(dynamicLayer);
  // Point the new Dynamic Layer URL to the dynamicLayer
  map.addLayer(dynamicLayer);
// REFRESH the layerList  (DOES NOT WORK)
  //  If I click on the layerList checkboxs, it gives me the error:
  //   TypeError: t.byId(...) is null    ???
  layerList.refresh();
  function setLayer() {
  var lyrValue = selectedLayer.get('value');
  if (lyrValue == '1') {
  else if (lyrValue == '2') {
  // Load the newly selected dynamic layer
  loadDynamicLayer();
  function expandLayerList() {
  query('.esriLayer').forEach(function(node){
  domClass.add(node, "esriListExpand");
  query('.esriToggleButton').forEach(function(node){
  domClass.replace(node, "esri-icon-down", "esri-icon-right");
KenBuja
MVP Esteemed Contributor
It may be that the dynamic layer isn't ready by the time the legend is refreshed. Try something like this (which needs the module "dojo/on" added)
on.once(dynamicLayer, "load", function(){
