dojo grid on click showing error
2322
05-11-2016 10:23 AM
ADITYAKUMAR1
HI Users,
  I am following this example.Show find task results in a DataGrid | ArcGIS API for JavaScript
But after some number of search if i click on the grid it throws me the following error.
0x800a138f - JavaScript runtime error: Unable to get property 'toJson' of undefined or null reference
And I am not able to zoom to the location.
Any idea what is creating trouble here.
Aditya Kumar
Tags (1)
thejuskambi
The sample does not contain the use of "toJson" function. And I am not able to reproduce the behaviour you mentioned with the sample.
Does your code use it anywhere? Could you share that.
ADITYAKUMAR1
function onRowClickHandler(evt) {
    var clickedId = evt.grid.getItem(evt.rowIndex).OBJECTID;
    if (AssetSelected == "XXX") {
        var selectedFeature1 = new dojo._base.array.filter(DREAM_2D_Feature_Well.getSelectedFeatures(), function (graphic) {
            return ((graphic.attributes) && graphic.attributes.OBJECTID === clickedId);
KenBuja
MVP Esteemed Contributor
Can you post your full code?
