Creating a rectangle
7289
05-08-2016 10:26 PM
DaneCarlson1
Hi all--
I am trying to create a rectangle in ArcGIS Pro (the application) and totally failing.  I hesitate to ask here because I know the instructions are online, but please understand that I have been sitting here for two hours reading the instructions, trying and failing, rereading, etc etc in a continuous cycle.  All I'm trying to do is clip a bunch of really, really big shapefiles to a rectangle that I have to make.  I've opened the create features tab under edit, but it's empty.  I don't understand the relationship between feature classes and features.  Perhaps I'm wrong but this whole process seems so convoluted that I am just shaking with frustration.  If someone could kindly give me a step by step on how to create a rectangle and make it into a layer (I have the clip part under control) it would be so, so appreciated.  Thank you so very much for your help, understanding, and patience with an idiot.
Best-
Dane.
MervynLotter
MVP Regular Contributor
Hi Dane
I am on the road so difficult to reply in detail, but I had a similar
problem but solution is very easy.
With the create features side panel active, open the templates window and
there is an option to define the editing tools for that layer. Here you
simply click on the boxes that would activate drawing tools such as
rectangles, circles, etc.
I am not sure why they are not all activated by default.
Good luck.
DaneCarlson1
Thank you Mervyn--
I figured how to add rectangles within a layer, but have no idea how to make a rectangle on its own, separate layer.  I don't want to work within a layer that has existing features, I just need to make a rectangle on its own layer to act as a clipping mask.  Any ideas about that?  Thanks so much for your time and help.
Dane
MervynLotter
Hi Dane
So you would need to create a new shapefile or geodatabase feature, and
then to this add rectangles.
To do so you can run the Create Features Class geoprocessing tool. If you
to not direct output to a geodatabase, then the new file will be a
shapefile.
Cheers
leeparkerthanetdc
Hi Dane
Sounds like you need MapInfo!! It was so easy to create a clip boundary on a basemap. In esri you have to create a new feature class/shapefile so you can create features like shapes etc, so long winded
