Election script help
6625
04-25-2016 07:26 PM
LeeMadison
Trying to modify the elections app where I can update results using one spreadsheet.
Its for a small local election with 20 districts and each district has  different number of candidates.
district 1 might have 5 candidates & district 3 may only have 3 candidates . I can do it with 20 spreadsheets but that will get messy. Any idea how to edit the script that if a candidate space is empty it will skip?
This is the error.
  File "<string>", line 1682, in execute
  File "<string>", line 897, in runElectionResults
TypeError: int() argument must be a string or a number, not 'NoneType'
The spread sheet shows what I'm trying to do
DanPatterson_Retired
the script doesn't accept blank cells, it is trying to convert a string to an integer so whatever the line of the script refers to doesn't allow for nulls/blanks and/or it doesn't check for them and skip them
LeeMadison
Yeah I guess I need to figure out in the script how to make it skip blanks
don't know what language but generically
if whatever != "":
    do something
if the variable whatever is not equal to "" (normally nothing, null, depending on language, database)
do the something part and it will skip it otherwise
LeeMadison
Its literally just using the ESRI elections script  http://links.esri.com/localgovernment/download/ElectionsResults/
So I'll have to brush up on my python!
