I'm trying to modify the attribute editor sample (Using the attribute inspector | ArcGIS API for JavaScript ) to remove the query and simply open clicked points for editing. I think it has something to do with how I call the selected feature, but I cannot pin point it. Can someone point me in the right direction on how to populate the attribute inspector. code below.
<!DOCTYPE html>
<html>
<head>
<meta name="viewport" content="initial-scale=1,maximum-scale=1,user-scalable=no">
<title>Editable FeatureLayer with Attribute Inspector</title>
<link rel="stylesheet" href="https://js.arcgis.com/3.16/dijit/themes/claro/claro.css">
<link rel="stylesheet" href="https://js.arcgis.com/3.16/esri/css/esri.css">
<style>
html, body, #mapDiv{
height: 100%;
width: 100%;
margin: 0;
padding: 0;
overflow: hidden;
#detailPane{
padding: 6px;
height:20px;
color:#570026;
font-size:12pt;
font-weight:600;
overflow: hidden;
.dj_ie .infowindow .window .top .right .user .content { position: relative; }
.dj_ie .simpleInfoWindow .content {position: relative;}
.esriAttributeInspector .atiLayerName {display:none;}
#testFloatingPane {
-moz-border-radius: 6px;
-webkit-border-radius: 6px;
position: absolute;
top: 35px;
left: 60px;
width: 200px;
height: 300px;
z-index: 90;
.dojoxFloatingPaneContent {
font-family: Arial, Helvetica, sans-serif;
font-size: 8pt;
font-weight: bold;
overflow: auto;
.dojoxFloatingPaneTitle, .reportTitlePane {
color: white;
background-color: #76a2c5;
font-size: 12pt;
font-weight: bold;
overflow: auto;
</style>
<script src="https://js.arcgis.com/3.16/"></script>
<script>
var map, updateFeature;
require([
"esri/map",
"esri/layers/FeatureLayer",
"dojox/layout/FloatingPane",
"esri/dijit/AttributeInspector",
"dojo/parser",
"esri/dijit/editing/TemplatePicker",
"esri/symbols/SimpleLineSymbol",
"esri/symbols/SimpleMarkerSymbol",
"esri/Color",
"esri/config",
"esri/tasks/query",
"dojo/dom-construct",
"dijit/form/Button",
"dojo/domReady!"
], function(
Map, FeatureLayer, FloatingPane, AttributeInspector, parser, TemplatePicker,
SimpleLineSymbol, SimpleMarkerSymbol, Color,
esriConfig,
Query, domConstruct, Button
parser.parse();
// refer to "Using the Proxy Page" for more information: https://developers.arcgis.com/javascript/jshelp/ags_proxy.html
esriConfig.defaults.io.proxyUrl = "/proxy/";
map = new Map("mapDiv", {
basemap: "dark-gray",
center: [-97.395, 37.537],
zoom: 5
map.on("layers-add-result", initSelectToolbar);
//Feature Layer representing 2015 men's NCAA basketball tournament teams
var teamsFL = new FeatureLayer("https://services.arcgis.com/V6ZHFr6zdgNZuVG0/arcgis/rest/services/NCAA_Tourney_2015/FeatureServer/1", {
mode: FeatureLayer.MODE_ONDEMAND,
outFields: ["University", "WINPER", "Rd_64_Venue", "Rd_64_Result", "Rd_64_Margin"]
var selectionSymbol = new SimpleMarkerSymbol(
SimpleMarkerSymbol.STYLE_CIRCLE, 6,
new SimpleLineSymbol(
"solid",
new Color([255,0,0,0.5]),
new Color("ED3939")
var defaultSymbol = new SimpleMarkerSymbol(
SimpleMarkerSymbol.STYLE_CIRCLE, 7,
null,
new Color([255,255,255])
teamsFL.setSelectionSymbol(selectionSymbol);
map.addLayers([teamsFL]);
function initSelectToolbar(evt) {
console.log("initSelectToolbar started", evt);
var teamsFL = evt.layers[0].layer;
console.log("teamsFL started", teamsFL);
var selectQuery = new Query();
teamsFL.on("click", function(evt) {
console.log("start select");
updateFeature = teamsFL[0];
map.infoWindow.setTitle("cleanup site");
map.infoWindow.show(evt.screenPoint, map.getInfoWindowAnchor(evt.screenPoint));
map.infoWindow.on("hide", function() {
teamsFL.clearSelection();
var layerInfos = [
'featureLayer': teamsFL,
'showAttachments': false,
'isEditable': true,
'fieldInfos': [
{'fieldName': 'University', 'isEditable': false, 'label': 'School:'},
{'fieldName': 'WINPER', 'isEditable': true, 'tooltip': 'Win percentage', 'label': 'Win percentage:'},
{'fieldName': 'Rd_64_Venue', 'isEditable': false, 'label': 'Rd 1 Venue:'},
{'fieldName': 'Rd_64_Result', 'isEditable': true, 'tooltip': 'First round result (W/L)', 'label': 'Rd 1 Result:'},
{'fieldName': 'Rd_64_Margin', 'isEditable': true, 'tooltip': 'First round margin of victory/loss', 'label': 'Rd 1 Margin:'}
//Initialize Attribute Inspector
var attInspector = new AttributeInspector({
layerInfos: layerInfos
}, domConstruct.create("div"));
//add a save button next to the delete button
var saveButton = new Button({ label: "Save", "class": "saveButton"},domConstruct.create("div"));
domConstruct.place(saveButton.domNode, attInspector.deleteBtn.domNode, "after");
saveButton.on("click", function() {
updateFeature.getLayer().applyEdits(null, [updateFeature], null);
attInspector.on("attribute-change", function(evt) {
//store the updates to apply when the save button is clicked
updateFeature.attributes[evt.fieldName] = evt.fieldValue;
attInspector.on("next", function(evt) {
updateFeature = evt.feature;
console.log("Next " + updateFeature.attributes.OBJECTID);
attInspector.on("delete", function(evt) {
evt.feature.getLayer().applyEdits(null, null, [evt.feature]);
map.infoWindow.hide();
map.infoWindow.setContent(attInspector.domNode);
map.infoWindow.resize(350, 240);
</script>
</head>
<body class="claro">
<div id="main" data-dojo-type="dijit/layout/BorderContainer" data-dojo-props="design:'headline'" style="height:width:100%;height:100%;">
<div data-dojo-type="dijit/layout/ContentPane" id="header" data-dojo-props="region:'top'">
Click to display the attribute inspector for all NCAA men's basketball tournament teams within 50 miles of click.
</div>
<div id="mapDiv" div data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'left'" style="width:100%;height:100%;"></div>
<div id="testFloatingPane" data-dojo-type="dojox/layout/FloatingPane"
data-dojo-props="title:'Add Cleanup', closable:false, resizable:false, dockable:true, movable:false">
<div id="reportContainer" data-dojo-type="dijit/layout/ContentPane">
test
</div><!--endreportContainer-->
</div><!--end testFloatingPane-->
</div><!--end main-->
</body>
</html>
Solved! Go to Solution.
For the AttributeInspector to work you need the feature to be selected within the FeatureLayer. See the documentation
The AttributeInspector displays the attributes of selected features from one or more feature layers.
You could do one thing. use the ObjectID from the graphic returned from onclick and user query.objectIds instead of whereClause. But you must use FeatureLayer.selectFeatures to show the details in the AttributeInspector.
Thanks. I should have seen that hours ago. Is there a way to simply select a point?
Unfortunately no, the featureLayer needs to process and maintain the selected information. it has function to change the color it selection color is set. On the plus side, it will do a client side query as it already has the graphic with it.
I modified the code below (still needs to be cleaned up) and was able to open the infowin, thanks.
console.log("initSelectToolbar started", evt.graphic.attributes["OBJECTID"]);
var objectIds = evt.graphic.attributes["OBJECTID"];
var newID = [];
newID.push(objectIds);
console.log(newID);
selectQuery.objectIds = newID;
teamsFL.selectFeatures(selectQuery, FeatureLayer.SELECTION_NEW, function(features) {
if (features.length > 0) {
//store the current feature
updateFeature = features[0];
map.infoWindow.setTitle(features[0].getLayer().name);
else {
console.log("query finished");
