Should I upgrade my SQL first?
1930
04-22-2016 06:54 AM
JamesFitzgerald
Should I upgrade my SQL Server 2008 R2  to SQL Server 2012 R2 first then upgrade to ArcGIS 10.3 for Desktop and ArcGIS 10.3 for Server? Or vice-versa? Does it matter? Any advice on the matter. Thanks
JakeSkinner
Esri Esteemed Contributor
Hi James,
I usually recommend to customers to upgrade their enterprise geodatabase last since the clients are usually backwards compatible to the geodatabase.  The order I upgrade is the following:
1.  One or two ArcGIS Desktop
2.  ArcGIS Server (if applicable)
3.  RDBMS and Geodatabase
