Whats wrong with my logic?
5665
14
04-21-2016 11:25 AM
RachelAlbritton
I am trying to set the contents of an infoTemplate based on an if/else statement, however, its not giving me the results that I would expect. Certain fields in the 'thumbnails' field contain a field that is call 'NoImage2.jpg'. If the field contains this title I want this field removed from the infotemplate window. When I test the logic, the infotemplate always returns the else statement. If I remove the else statement and have the function only evaluate the if statement, the windows comeback blank, even for the objects that it should apply to. I'm clearly overlooking something but I can't figure it out. Thanks in advance.
 map = new Map("map",{
          basemap: "streets",
          center:[-111.836, 40.765], //long, lat
          zoom: 14
            bldgContentObject = {
            objectid: '${OBJECTID}',
            formalName: '"${formal_name:formatStructureNameForThumbnailModal}"',
            informalName: '"${informal_name:formatStructureNameForThumbnailModal}"',
            streetAddress: '${street_address}',
            city: '${city}',
            state: '${state}',
            zipCode: '${zip_code}',
            thumbnails: '${thumbnails}',
            buildingNumber: '${building_number}',
            abbreviation: '${abbreviation}',
            lattitude: '${lattitude:gsvLat}',
            longitude: '${longitude:gsvLon}',
            gsvHeading: '${gsv_heading:gsvHeading}',
            gsvPitch: '${gsv_pitch:gsvPitch}'
        symbol = new SimpleFillSymbol(SimpleFillSymbol.STYLE_NULL,
        new SimpleLineSymbol(SimpleLineSymbol.STYLE_SOLID)); //new Color([0,0,0])), new Color([0,0,0]));
        //infoTemplate = new InfoTemplate("${informal_name}", "<b>BN: </b>${building_number}<br><b>Abbrv: </b>${abbreviation}<br><b>Thumbnail: </b>${thumbnails}<br>");
        infoTemplate = new InfoTemplate();
        infoTemplate.setTitle (bldgContentObject.informalName);
        var infoContent1 = "<b>BN: </b>"+bldgContentObject.buildingNumber+"<br><b>Thumbnail: </b>"+bldgContentObject.thumbnails;
      var infoContent2 = "<b>BN: </b>"+bldgContentObject.buildingNumber;
        //infoTemplate.setContent("<b>BN: </b>${building_number}<br><b>Abbrv: </b>${abbreviation}<br><b>Thumbnail: </b>${thumbnails}<br>"); //Works
        //infoTemplate.setContent(infoContent1); //This logic works
        infoTemplate.setContent(templateContent());
        function templateContent (){
    //return bldgContentObject.thumbnails; //name in the thumbnails field (string)
        if (bldgContentObject.thumbnails === "'NoImage2.jpg'"){return infoContent2;} //returns a content window with only the title
        //if (bldgContentObject.thumbnails === "NoImage2.jpg"){return infoContent2;}) //same results as above
        //if bldgContentObject.thumbnails === '"NoImage2.jpg"'){return infoContent2;}// same results as above
    else {return infoContent1;}
        map.on("click", doQuery);
        queryTask = new QueryTask("http://fmags.fm.utah.edu/arcgis/rest/services/mapservices/public_basemap_2014/MapServer/41");
        queryTask.on("complete", addToMap);
        query = new Query();
        query.returnGeometry = true;
        query.outFields = ["*"];
          function doQuery(evt) {
        //clear currently displayed results
        map.graphics.clear();
        query.geometry = evt.mapPoint;
            query.outSpatialReference  = map.spatialReference;
        queryTask.execute(query);
        function addToMap(results) {
        var featureArray = results.featureSet.features;
            var feature = featureArray[0];
            map.graphics.add(feature.setSymbol(symbol).setInfoTemplate(infoTemplate));
    </script>
  </head>
  <body>
    <div id="map"></div>
  </body>
</html>
RobertScheitlin__GISP
Rachael,
You should look at the help docs for formatting infowindow content, specifically
Using custom functions:
Format info window content | Guide | ArcGIS API for JavaScript
Your line
should be:
infoTemplate.setContent(templateContent);
and in your
function you need to work with the graphic.
function templateContent (graphic){
var attrs = graphic.attributes;
KenBuja
MVP Esteemed Contributor
The if and else if statements both return infoContent2. Is that correct?
else {return infoContent2;}
RachelAlbritton
correct
KenBuja
Then what is the purpose of infoContent1?
RachelAlbritton
My mistake - thats a mistype and I've edited the original post (thank you for catching that).
It should read:
Rachael,
Your line
should be:
and in your
RachelAlbritton
thanks Robert - I'll take a look at the link you provided
As far as your suggestion for this:
Your line
should be:
I tried that, but your suggestion returns this:
whereas my statement returns the field value:
Rachel,
  Why either one of those images is displaying the thumbnail info does not make any sense to me. Supposedly your function is returning infoContent2. And infoContent2 should be "<b>BN: </b>"+bldgContentObject.buildingNumber. Have you changed your code since you posted what you did above to account for this difference in what code we can see and what is actually running on your end?
RachelAlbritton
Robert -
the images I posted were simply to show you that keeping my format : infoTemplate.setContent(templateContent());
gives my attribute information, but your suggestion of infoTemplate.setContent(templateContent); does not.
Keeping things within context, if I run the code using my format of infoTemplate.setContent(templateContent());
The following image defaults to infoConent1, but it should be recognizing infoContent2
if I use your suggested format: infoTemplate.setContent(templateContent); it still defaults to the infoContent1  (which it should not), but it does not give me the attribute value
I hope this provides some clarity.
EvelynHernandez
try to follow my logic to solve ur issue
First u need to do the query to pass the parameters to that function:
  function templateContent(graphic, infoTemplate){
          var attr = graphic.attributes['thumbnails'];
          if (attr = "NoImage2.jpg"){
            var infoContent1 = "<b>BN: </b>"+ bldgContentObject.buildingNumber +
                               "<br><b>Thumbnail: </b>" +
                               "<img>${thumbnails}</img>";
          }else{
            var infoContent2 = "<b>BN: </b>" + bldgContentObject.buildingNumber;
            infoTemplate.setContent(infoContent2);
